Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing the clothes and the washer came up with code f2
It came with code f2 drain issue. Drain is fine, was doing wash with no issue and this just suddenly happened. Tried the drain and spin cycle and it locks the door---adds water---and then you hear a relay click and no draining. Just sits and does nothing. Also came up with SUD if left alone.
Tried another cycle and it just doesn't allow me to do much. Tries to empty the washer on drain but pump does not come on.
Will not drain or spin. Haven't tried any other cycles....any help is appreicated. Its the Kenmore HE3T version of the front loader.
thanks
  • 5,911 Answers
"F02" as well know by now, is a Long Drain error. This is usually an indication of an obstruction somewhere in the drainage system, or a failed drain pump. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
NOTE: A "SUD" error code can also often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
IMPORTANT: It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: For an explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Posted on Jul 05, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
F2 Code???
Probably blockage in pump or sump
Jun 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
What does f2 messege mean?
F2 This error code indicates that drain times are longer than expected.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Oct 08, 2012 | Maytag MHN30PDAWW High-Efficiency...
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not complete the cycle or drain the clothes. It just stops and beeps then flashes an error code like F2.
And F2 translates to: long drain. Make sure the drain hose from the machine is not kinked or plugged. Do you hear the pump running when it is supposed to? Check the drain-pump filter for debris. Replace the pump if it doesn't seem to run. Hope this helps!
Feb 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
ERROR CODES ON MY WASHING MACHINE
join todays crowd!!! im in the same issue it is f2 error thatfollowedf suds error huh?
f2 is long drain issue after 8 minutes occurs anf the water valves to machine can be not fully iopoen; unplug ist
next keep off 2-5 minutes tpo clear memory
replug in
check drain hose not kimked
check drain pump inside is the next issue for prom is filled with foriegn objects that is known for this unit!!!! their a tech online kctech thats great try his answer online to use a shop vac and **** out any water in the inside and the hoes: and the drain pump inside the machine: see solution #6 may 2008 posted by washer gut in knasas that is eceptional to follow great day danw.
Mar 19, 2009 | Kenmore Elite 45986 Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer code
the drain sump area is clogged axcess through front panel. F02 is telling you its taking too long to drain the water pretty soon it wont drain at all.
Sep 29, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
107 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
