Question about Refrigerators
The light came on filter bad .replaced filter but the lightstayed on.
  • 4,070 Answers
You can post your model number is someone may can find a owners manual to look for the info or look in your manual to see how it says to reset the light after the filter is changed.
Posted on Jul 05, 2010
Airbag & abs lightstay on, handbrake light flashes
When you turn the ignition key on there are all sorts
of lights & symbols lite
You should know what they are
Once the engine starts they all should go out
or you have a system failure
This technology is 32 years old, so why you don't
know about checking for codes is beyond me
Once you get any codes, you use them to diagnose
the failed system & then component test, before replacing
any parts
Codes, if you have any, only point you in some direction,they don't
tell you what is wrong,have to test for that
Should Google OBD Vehicle Systems & brush up & read
an owners manual,anybodys manual will help you
Jan 30, 2013 | Cars & Trucks
Red lightstays on no power how to fix
Sounds like something is shorting out and it is protection mode. Check that the wiring is correct and there are no bad spot on the power wires
May 25, 2011 | Performance Teknique ICBM-774 Car Audio...
Airbag lightstays on,worry it might deploy.
it may warning light tells you there is a problem and even in an accident airbag may fail/or go off at any time have that checked soon.by a professional.
Mar 18, 2011 | 2002 Ford Explorer
No power response, replaced battery and charger still no power
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jan 31, 2011 | Acer Aspire 4720 Notebook
My red lightstay on and well not stay on
If your ps3 doesnt turn on at all and its just a red light. You need a new internal power supply. If the ps3 turns on for just a few seconds and beeps you need to reflow your cpu and gpu on the motherboard. You have yellow light of death.
Nov 24, 2010 | Sony Playstation 3 (PS3) Console
Rollers won't turn?
DO a powerflee
here are the steps
1) unplug all the cables from the printer including power cable.
2) press and hold the on/off button on the printer for 30 seconds (this will release all the static from the printer)
3) plug back the cables and then try
May 10, 2010 | Samsung CLP 300 Laser Printer
Doorwillnot go up or down ,lightstays on in the motor unit, one sencer works properly, the other stays green even when blocked
It sounds like you have a bad drive gear. Remove the cover and you will find it just in front of the motor. Most likely stripped.
May 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
