Installing all-in-one series configuring product box is taking forever to configure. Current progress kbps number keeps going up and down nothing more is happening and overall progress stuck at 96% what should I do now?
  • Anonymous Jun 30, 2008
    I need the cd to install my Lexmark X3350 lost it when I move
  • Aaron Yawo Dec 28, 2008
    unable to confugurate product of HP Photosmart all in one series
I need a software to install my printer lexmark X3350 I lost my cd when I move.
Posted on Jun 30, 2008
I had the same problem with CD installation, you should download drivers from lexmark site and then try again like me, now it is working properly
Posted on Apr 17, 2008
I have HP Color LaserJet CP1515n Printer wanted to configure on domain base network . Just need to know the IP address of this printer????
Status TheStatusfolder contains links to the following main pages.
  • Device Status. This page indicates product conditions such as a jam or an empty tray. After you correct a problem, clickRefresh statusto update the product status.
  • Supplies Status. View details such as the estimated percent of toner remaining in the print cartridge and the number of pages that have been printed with the current print cartridges. This page also has links for ordering supplies and for finding recycling information.
  • Device Configuration. View a detailed description of the current product configuration, including the amount of memory installed and whether optional trays are installed.
  • Network Summary. View a detailed description of the current network configuration, including the IP address and network status.
  • Print Info Pages. Print the Configuration page and other information pages, such as the Supplies status page.
Dec 13, 2014 | HP Office Equipment & Supplies
Tip
How can I disable the Auto Connect to GPRS?
<p>General Packet Radio Service (GPRS) is a standard for wireless communication at speeds up to 111 kilobits per second (Kbps), faster than the current Global System for Mobile Communications (GSM), which runs at 9.6 kbps. GPRS uses a limited amount of bandwidth and is useful for sending and receiving minimal amounts of data to surf the Internet and e-mail contains. The self-adjustment in a GPRS connection enables you to automatically connect to the Internet, but if you do not want this setting to do this, you can disable the automatic connection, downloading a configuration tool. <br /> <p><br /> <p>1. Download and install Advanced Configuration Tool for Windows Mobile (see Resources). <br /> <p><br /> <p>2. Start the advanced configuration tool for your phone. <br /> <p><br /> <p>3. Click on "Data Connections" tab and find the "Auto Attach GPRS enabled." <br /> <p><br /> <p>4. Click on "GPRS Auto Attach Enabled 'to disable Auto Connect to GPRS. <br /> <p><br /> <p>5. Click "Done" and leave the advanced configuration tool. <br />
on Jun 26, 2011 | Computers & Internet
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
In my office we have linksys RV082 as our internet router, we use VSAT C-Band type with 1.5 Mbps ratio 1:4. The problem is when we try to test internet speed from client (Modem -&gt;Router RV082...
I think that this is a configuration issue, which can be resolved by re-configuring the router.
Please refer to the Product Manual for details about configuration and management of bandwidth.
Hope it helps!
CreativeTECH
Nov 25, 2010 | Linksys RV082 Router (RV082-AU)
I have loaded and activated Microsoft Office 2007 full version (Professional). Every time I go to start an Office application I get a configuration window. It's a bargraph showing Configuration Progress,...
Click Start- type msconfig- choose selective start up and uncheck Load Startup Items, then click on tab Services, cjoose check box "Hide all microsoft services" at the bottom left and click disable all.
Then clecik on apply and ok, restart the system and check
Feb 18, 2010 | Microsoft Office Professional 2007 Full...
MY Draytek router V2900vg is not going back to Factory reset. Printer light keeps flashing (nothing connected) no wireless or LAN activity taking place.. Please help
According to this, http://www.bartek.com.tw/product/vigor/2900/doc/manual/ch20_reboot%20system.pdf
you restore the router to factory configuration in the reboot menu. One option is to reboot with the current config and another option is to reboot with the factory configuration.
If this does not work for you regarding getting the router back to factory config I'd call or e-mail Draytek. They have a good rep - high quality products and service at a higher price, so try them directly. When a factory restore does not work, only the manufacturer is left in a lot of cases, unless there are unbricking procedures,
Jan 09, 2010 | Dell Computers & Internet
My Belkin easy transfer cable is having problems installing. It has been stuck inspecting my current configuration forever. Is something wrong?
i use windows live messenger 14.0 , if anybody send an webcam request , my cam open but not always connected , plz i need some solution , thx a lot for u
Dec 30, 2009 | Belkin Easy-Transfer Cable for Windows XP...
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scann
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
HP product assistant
I have problem with my hp laptop, when ever i restart the system it is asking insert the hp product assistant disc and then click ok to install, i dont have any other disc other than the one which comes along with printer. please kindly let me how to solve this........
thanks
kishore
Aug 29, 2008 | HP Deskjet 6940 InkJet Printer
Configuration progress
If the "Configuration Progress box" is coming up every time you run and Office 2007 product, Click on "Start" -> "Control panel "->"Add or Remove Programs ". Check to see if you Still have a previous version of the Microsoft product installed. For example, "Microsoft Word " from "Microsoft Office 2007" takes 2 to 3 minutes to load because the "Configuration Progress box" comes up, checking the "Add or Remove Programs", showed "Microsoft Office 2003 " was still installed. After remove "Microsoft Office 2003", "Microsoft Word 2007" opened quickly without the configuration bar.
Jul 30, 2008 | Computers & Internet
721 people viewed this question
jasbo
jasbo
