Question about Plumbing
Ashfield f-049-yw1k quick connect "center connector" fitting leaks. Also how is the fitting removed?
  • 760 Answers
Here is a link to the Prince Pfister web site, and your specific model. I'm not sure what you mean by quick connect as this faucet doesn't appear to have any quick connect. Note two links one for parts list and the other for install manual
http://www.pricepfister.com/product_catalog/product_detail.aspx?id=107589#tab:1
Posted on Jul 05, 2010
What does trough mean
Trough is the shape of the spout delivering water. As in a water trough. Open on top
Feb 17, 2015 | Price Pfister 049-YP1E Ashfield Widespread...
How do I remove a fuel tank from a 2004 Buick Rendezvous
First of all, there is a recall for gas tank replacement for your vehicle. The dealer will replace it free. The link will get you to the document in PDF form
Redirect Notice
It looks like there is a bracket on one end of the tank hidden by a heat shield
FUEL SUPPLY SYSTEM Fits Buick Rendezvous
Feb 08, 2015 | 2004 Buick Rendezvous
Purge solenoid location 2008 torent
Evaporative Emission Canister Purge Solenoid Valve Replacement
Remove the fuel injector sight shield. Refer to Fuel Injector Sight Shield Replacement. Disconnect the engine wiring harness electrical connector (4) from the evaporative emission (EVAP) purge solenoid.
Remove the oil fill cap. Lift upward and remove cover from ball studs.
The purge solenoid is under the plastic cover on top of the engine .
Disconnect the EVAP pipe quick connect fitting (1) from the EVAP purge solenoid. Refer to Plastic Collar Quick Connect Fitting Service.
Disconnect the EVAP pipe quick connect fitting (2) from the EVAP purge solenoid. Refer to Plastic Collar Quick Connect Fitting Service. Remove the EVAP purge solenoid bracket bolt (3). Remove the EVAP purge solenoid.
the purge
Sep 20, 2014 | 2008 Pontiac Torrent
Fuel leak quick connector leak
Seeping like a connection at the quick disconnect is loose on one of the fittings? Or leaks alot like not connected all the way and a fuel injected Harley wont start? Or leaks alot like the quick connect fitting is broken internaly or has dirt in it?
Oct 11, 2013 | Harley Davidson Motorcycles
Where is the fuel filter located on a 2000 Chevy Cavalier 4cyl?
Fuel Filter REMOVAL & INSTALLATION Fig. 1: Remove the quick connect fitting from the filter 91141p82.jpg
Fig. 2: Using a 21mm back-up wrench and a 16mm wrench on the line, loosen the feed line from the filter 91141p83.jpg
Fig. 3: Carefully unthread the feed line from the filter and . . . 91141p84.jpg
Fig. 4: . . . remove the filter from the retaining bracket by pulling the filter outward 91141p85.jpg
NOTE: The vehicles covered in this manual are equipped with "Quick Connect'' fuel fittings. For more information regarding these fittings, please refer to Section 5 of this manual. An inline filter can be found in the fuel feed line attached to the rear crossmember of the vehicle. CAUTION
Before disconnecting any component of the fuel system, refer to the fuel pressure release procedures found in Section 5.
  1. Properly relieve the fuel system pressure as outlined in Section 5.
  2. Raise and safely support the vehicle with jackstands.
  3. Grasp the filter and nylon fuel line fitting on the tank-to-filter line. Twist the "quick-connect'' fitting 1?4 or a turn in each direction to loosen any dirt within the fitting. Use compressed air to blow out the dirt from the fittings at the end of the fuel filter.
  4. Detach the quick-connect fitting by pushing inward toward the filter and grasping the plastic tab around the connector and pull apart. If additional assistance is required to disconnect the fitting, tool J 38778 or equivalent can be placed between the filter and the fitting release mechanism to carefully force the two apart. Be careful not to bend the special tool. NOTE: Always use a back-up wrench anytime the fuel filter is removed or installed.
  5. Using a backup wrench (where possible) to prevent overtorquing the lines or fittings, loosen and disconnect the feed line from the filter. Be sure to position a rag in order to catch any remaining fuel which may escape when the fittings are loosened.
  6. Remove the fuel filter from the retaining bracket. To install:
  7. Before installing a new filter, apply a few drops of clean engine oil to the male tube end of the filter. This will ensure proper attachment and prevent a fuel leak.
  8. Position the filter into the retaining bracket with the directional arrow facing away from the fuel tank, towards the throttle body. NOTE: The filter has an arrow (fuel flow direction) on the side of the case, be sure to install it correctly in the system, with the arrow facing away from the fuel tank.
  9. Push the connectors on the quick-connect fitting together to cause the retaining tabs/fingers to snap into place. Pull on both ends of the connection to be sure they are secure.
  10. Connect the fuel feed line to the filter, then tighten, using a backup wrench to prevent damage, to 20-22 ft. lbs. (27-30 Nm).
  11. Carefully lower the vehicle.
  12. Connect the negative battery cable and tighten the fuel filler cap, then start the engine and check for leaks.
Nov 18, 2010 | 2000 Chevrolet Cavalier
How do i remove gas tank
NOTE Always maintain cleanliness when servicing fuel system components.
  1. Relieve the fuel system fuel pressure.
  2. Drain the fuel tank.
  3. Raise the vehicle.
  4. Disconnect the fuel tank wiring harness connector at the body pass through.
  5. For 3.4L engines, disconnect the quick-connect fitting at the inlet side of the in-pipe fuel filter.
  6. For 3.4L engines, disconnect the quick-connect fitting on the fuel return pipe, near the fuel filter.
  7. Disconnect the fuel tank evaporative emission (EVAP) pipe quick-connect fitting near the fuel filter.
  8. Remove the fuel feed, the fuel return, and the EVAP lines from the fuel pipe retainer.
  9. Remove the retaining nut for the EVAP canister bracket.
  10. Loosen the fuel tank filler pipe hose clamp.
  11. Disconnect the fuel tank filler pipe from the fuel tank.
  12. For 3.5L engines, disconnect the EVAP vent pipe near the fill pipe hose.
    NOTE Do not bend the fuel tank straps. Bending the fuel tank straps may damage the straps.
  13. With the aid of an assistant, support the fuel tank and remove the fuel tank strap attaching bolts.
  14. Remove the fuel tank from the vehicle and place the fuel tank in a suitable work area.
  15. If the fuel tank is not being replaced, go to the Installation Procedure.
  16. Disconnect the fuel tank wiring harness from the fuel sender assembly.
  17. Remove the fuel sender shield from the fuel tank.
  18. Disconnect the fuel feed and return pipe quick-connect fittings at the fuel sender.
  19. Disconnect the EVAP vapor pipe assembly from the fuel sender.
  20. Remove the fuel and/or EVAP pipe assembly from the fuel tank.
  21. Remove the fuel sender assembly.
  22. Remove the EVAP vent solenoid valve.
  23. Remove the EVAP canister.
To install:
  1. Install the EVAP canister.
  2. Install the EVAP vent solenoid valve.
  3. Install the fuel sender assembly.
  4. Install the fuel and/or EVAP pipe assembly.
  5. Connect the EVAP vapor pipe to the fuel sender assembly.
  6. Connect the fuel feed and fuel return pipes at the fuel sender.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  7. Install the fuel sender shield to the fuel tank and tighten the shield nuts to 53 inch lbs. (6 Nm).
  8. Connect the fuel tank wiring harness to the fuel sender assembly.
  9. With the aid of an assistant, position and support the fuel tank.
  10. Install the fuel tank retaining strap attaching bolts and tighten the fuel tank retaining strap bolts to 35 ft. lbs. (47 Nm).
  11. Install the EVAP canister retaining nut and tighten the retaining nut to 53 inch lbs. (6 Nm).
  12. Connect the fuel tank filler pipe to the fuel tank and tighten the fuel tank filler pipe hose clamp to 22 inch lbs. (2.5 Nm).
  13. Connect the fuel feed pipe quick-connect fitting at the inlet side of the fuel filter.
  14. Connect the fuel return pipe quick-connect fitting near the fuel filter.
  15. Connect the fuel tank EVAP pipe quick-connect fitting near the fuel filter.
  16. Connect the fuel tank wiring harness connector at the body pass-through.
  17. Lower the vehicle.
  18. Add fuel and reinstall the fuel tank filler pipe cap.
  19. Connect the negative battery cable.
  20. Inspect for fuel leaks with the following procedure:
    1. Turn ON the ignition for 2 seconds.
    2. Turn OFF the ignition for 10 seconds.
    3. Turn ON the ignition.
    4. Inspect for fuel leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 15, 2010 | 2001 Pontiac Aztek
New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
I had the same problem. I simply removed the small brass fitting that the water supply screws onto.i removed the screen that is inside the brass fitting. Now the pressure is fine.
Feb 15, 2010 | Price Pfister Pfister Ashfield Wide Satin...
How to replace fuel pump on chevy malibu 2000
First you should check your trunk. some newer chevy's have an access pannel uner the trunk liner inside the trunk. you remove the liner, remove the bolts and panel, and the pump is right there. it may take some effort to get it wiggled through, but trust me, it will fit. you must remove the fuel lines and wire harness first, then remove the lock ring completely before attempting to pull the pump through the access hole. if that fails then you need to drop you fuel tank to access the pump. there are instructions for removal and installation of the tank below.
  1. Disconnect the negative battery cable.
  2. Drain the fuel tank, using a hand-operated pump device to drain as much fuel through the filler tube as possible.
0900c1528026905d.jpg Fig. View of fuel tank mounting
0900c1528026905e.jpg Fig. The fuel filler pipe is attached to the body with a bracket and retaining bolt
0900c1528026905f.jpg Fig. The fuel filler pipe is attach to the tank by a hose clamp
  1. Raise and safely support the vehicle.
  2. Unfasten the muffler hanger bolts.
  3. Remove the rubber exhaust hangers, then allow the exhaust system to rest on the rear axle.
  4. Disconnect the hoses from the fuel tank sender. Grasp the filter and one nylon fuel connection line fitting. Twist the quick-connect fitting 1 / 4 turn in each direction to loosen any dirt within the fitting. Repeat for the other fitting. Using compressed air, blow out the dirt from the quick-connect fittings at the end of the fuel filter.
  5. Detach the quick-connect fittings by pulling the release tabs back on the fuel line quick connector and pulling apart.
  6. Disconnect the hoses at the tank from the filler, vent and vapor pipes.
  7. With the help of an assistant, support the fuel tank, then disconnect the two tank retaining straps and carefully lower the tank.
  8. Detach the fuel sender electrical connector.
  9. Unplug the fuel pressure sensor connector.
  10. Remove the fuel tank from the vehicle.
To install:
  1. If the tank is being replaced, perform the following:
    1. Remove the sound insulators.
    2. Remove the modular fuel pump/sender assembly, as outlined earlier in this section.
    3. Inspect all connectors for dirt and burrs. Clean or replace, as required. Inspect the fuel line O-rings for cuts, nicks, swelling and/or distortion and replace as necessary.
    4. Install the fuel sender assembly to the new tank, as outlined earlier in this section.
    5. Install the sound insulators.
  2. With the help of an assistant, raise the fuel tank to the vehicle and attach the fuel sender connector and, if equipped, the fuel pressure sensor connector.
  3. Raise the fuel tank into position then fasten the retaining straps. Tighten the retaining bolts to 26 ft. lbs. (35 Nm).
  4. Connect the hoses to the filler, vent and vapor pipes.
  5. Attach the nylon fuel feed and return connecting line quick-connect fittings to the fuel sender, as follows:
    1. Apply a few drops of clean engine oil to the male connector tube ends.
    2. Push the connectors together to cause the retaining tabs/fingers to snap into place.
    3. Once installed, pull on both ends of each connection to be sure they are secure.
  6. Install the rubber exhaust hangers.
  7. Install the muffler hanger bolts, then tighten to 11 ft. lbs. (15 Nm).
  8. Attach the fuel tank sender electrical connector.
  9. Carefully lower the vehicle.
  10. Refill the fuel tank, then connect the negative battery cable.
  11. Turn the ignition to the ON position for two seconds, then turn it to the OFF position for ten seconds. Turn again to the ON position and check for fuel leaks.
Nov 04, 2009 | 2000 Chevrolet Malibu
Where is the fuel pump in a 3.4 2000 chevy impala? is it hard to replace?
Please don't forget to rate!!!!
Pump is in the tank and here is the procedures to do the job:
Fuel Pump Removal & Installation To Remove:
  2. Drain the fuel tank from the filler neck as much as possible.
  3. Raise and safely support the vehicle.
  4. Loosen the clamp and remove the filler hose from the fuel tank.
  5. Disconnect the fuel and EVAP quick-connect fittings at the fuel tank.
  6. Remove the exhaust pipe hangers and allow the exhaust system to drop slightly.
  7. Separate the EVAP fresh air line at the splice.
  8. Remove the fuel tank shield.
  9. Support the fuel tank with a suitable jack.
  10. Remove the two bolts securing the fuel tank straps.
  11. Lower the fuel tank from the vehicle.
  12. Disconnect the electrical connectors from the fuel pump assembly.
  13. Clean the fuel pipe connections with compressed air to prevent contamination during removal.
  14. Disconnect the quick-connect fittings at the fuel sender assembly.
  15. Remove the fuel sender retaining ring and remove the fuel sender assembly. The modular fuel sender assembly will spring-up when the snap ring is removed.
To Install:
CAUTION
Be careful not to fold or twist the fuel inlet strainer when installing the fuel sender assembly, this will restrict fuel flow. Also, make sure the float arm is able to move freely.
  1. Place a new fuel sender assembly seal on the tank and install the fuel sender assembly.
  2. Holding the fuel sender in place and install the retaining ring.
  3. Connect the quick-connect fittings at the fuel sender assembly.
  4. Connect the electrical connectors.
  5. Place the fuel tank on a suitable jack and raise it in position under the vehicle.
  6. Install the fuel tank strap bolts. Tighten the bolts to 35 lb ft (48 Nm).
  7. Install the fuel tank shield.
  8. Connect the fuel and EVAP quick-connect fittings at the fuel tank.
  9. Connect the EVAP fresh air hose at the splice.
  10. Install the fuel tank filler hose to the fuel tank.
  11. Raise the exhaust and install the exhaust pipe hangers.
  12. Lower the vehicle.
  13. Add fuel and install the fuel filler pipe cap.
  14. Connect the negative battery cable.
  15. Perform the following to pressurize the fuel system;
    • Turn the ignition ON, for 2 seconds.
    • Turn the ignition OFF, for 10 seconds.
    • Turn the ignition ON.
  16. Inspect the fuel system fuel leaks.
Jul 16, 2009 | 2000 Chevrolet Impala
Fuel filter replacement removing old filter
  1. Properly relieve the fuel system pressure.
  3. Grasp the filter and nylon fuel line fitting on the tank-to-filter line. Twist the "quick-connect'' fitting 1⁄4 or a turn in each direction to loosen any dirt within the fitting. Use compressed air to blow out the dirt from the fittings at the end of the fuel filter.
  10. Connect the fuel feed line to the filter, then tighten, using a backup wrench to prevent damage, to 20–22 ft. lbs. (27–30 Nm).
Jun 28, 2009 | 1997 Pontiac Sunfire
Plumbing Logo
159 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
