Question about HP Pavilion dv9627cl Refurbished Notebook PC - AMD Turion 64 X2 Dual-Core TL-58 1.9GHz, 802.11b/g W PC Notebook
HP dv9627cl wont find any dvd/cd drive I put in. It has power and will eject. I put my dvd drive in my wife computer and it works fine? I have remove the upper and lower filters also.
    President:
  • 1,561 Answers
If the problem is just that the dvd/cd drive is not reading your disc, i would have limit the problem to the lens, that the lens on your dvd/cd drive is weak but in the case, the i would first advice you uninstall the dvd/cd driver from your system and reinstall back, if the problem still persist, it means the dvd/cd drive of your laptop is bad and will need to be replace. if the problem still persist, replace the dvd/cd drive.
Take care
Posted on Jul 05, 2010
  • williamoglet Jul 10, 2010
    No my drive works fine. I swap it out and put the drive into my wifes laptop and it plays fine.
    Windows Vista doesn't even show it in device manager on my computer, Not sure about the driver because windows doesn't even see the hardware. I have Phoenix bios on the laptop. i have tried to flash back to a earlier bios version.
    Thanks
Cd tray wont open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Apr 13, 2013 | HEWLETT-PACKARD Hp G62-225dx Laptop...
Can't eject CD from CD rom
Disassembling may be your only option, if the CD is Broken or jammed. Try rebooting and pushing the DVD rom button at boot. I had a DVD explode, I had to remove the drive and disassembling the DVD rom to remove all the pieces.
Apr 07, 2013 | Acer Aspire Z5700 All-in-One Desktop Pc
Hp g62 wont play or eject
The first thing you can try is to put a paperclip into the small hole in the front face of the dvd drive to pop open the tray (if you can't get it open). If you put in a CD, and it won't read it, and put in a DVD and it won't read it, then chances are your DVD drive is no longer working, and needs to be replaced.
Jan 16, 2012 | HEWLETT-PACKARD Hewlett Packard HP G62 -...
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
CD Drive not Recognized / Wont Eject CD
There is a small pinhole in the face of the dvd drive. Use a paperclip to poke into the hole. It will force an eject of the dvd drive. You can also explore the computer, right mouse click on the drive letter of the dvd drive, choose "eject"....
If it still will not eject, unplug the ribbon cable from the drive but keep the power plugged in, then press the eject button. If worse comes to worse, four small screws, and you can remove the shell of the drive exposing the dvd inside....
Good luck!!!!
-------------------please vote 4 thumbs up 4 me!!!!-----------
Apr 25, 2010 | Dell Dimension XPS 400 PC Desktop
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
Wont work
Dear Mitodelvalle,
Here are few things that you might want to check:
  1. Open the chassis of the computer and make sure that the cables that go to the drive are properly connected .. there should be 2 connectors.. One for Power supply with 4 wires and one is a ribbon cable for data. Make sure that the power supply cable is properly connected. you might want to remove and plug it back just to be sure.
  2. If that doesn't work then most of the computers come with a spare power connector hanging loose, you might want to try the spare connector.
  3. Try ejecting the optical drive by inserting pin in to the small hole in the front of the optical drive, just below the tray... Straighten a paper clip and insert it straight into the pin hole below the optical drive's tray and the drive should eject, then pull the trey out gently with your hand and make sure that nothing is broken inside...
Try the above steps and that should help. If you still need assistance, please let me know and I would be glad to assist you further.
Regards,
Srinivas.
Jun 20, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Frozen dvd drive
go to " MY COMPUTER" and alternate click the drive icon select properties and you can eject or stop from there
Apr 15, 2009 | Computers & Internet
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
HP Pavilion dv9627cl Refurbished Notebook PC - AMD Turion 64 X2 Dual-Core TL-58 1.9GHz, 802.11b/g W  PC Notebook Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
