Question about Canon PIXMA iP1800 InkJet Photo Printer
It asks technical service
The printer reached the maximum printing. It is no longer printing. I want to have an exact instruction about this trouble.
  • 748 Answers
Usually this means, that the waste ink absorber is full, or at least the printer's internal ink counter reached maximum capacity.
When the printer cleans it's heads, it "spits out" some ink into a special container, called the waste ink absorber. The internal counter prevents the ink overflowing from that container, and staining whatever the printer stands on.
If you want to avoid a visit to a service depot and try experimenting yourself, try www.fixyourownprinter.com, you may be able to find some guidelines there.
Posted on Jul 05, 2010
System error 21:10
first,unplugging the power cord for about 30 seconds then plug it again..if problem persist then follow next
Service Station failure. The possible cause could be:
1. The steps counted by the Service Station motor are not consistent
with the expected length of the current movement.
2. The Aerosol Fan has reached its maximum current limit.
3. The Service Station motor has shutdown because of blockage.
Corrective Action: Replace the Service Station/Aerosol Fan Assembly
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 19, 2013 | HP DesignJet 500 InkJet Printer
WON'T PRINT TO MAXIMUM PRINT AREA
You should change the margins in the word document before you print to 0.5 mm on all sides and remove header and footer.
May 02, 2012 | HP Officejet 6500 Wireless All-in-One...
I have a message saying print unable refer to user manual maintenance section and I no longer have this. How can I fix it.
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
Aug 18, 2011 | Brother DCP 130C All-In-One InkJet Printer
Epson r230 service required
Hi if your printer displayed service required, seems like your printer had gone a lot of printing jobs and reached to its maximum numbers to be printed and the counter needs to be reset. browse this site for solution or to download tools to reset your printer counter, http://www.ssclg.com/epsone.shtml
Jun 16, 2011 | Office Equipment & Supplies
Printer works ok in usb1 port but computer does not recognise it in usb2 port. This is on laptop with vista 32. On mac it sees the printer but it does not respond print request. Service error 300.
anon forces this error when you have printed and consummed the maximum amount of ink. It normally takes a very long time to get to this point. Canon has determined that once the amount of waste ink dumped reaches their limit, it is time to clean the entire machine. This is why they lock up the machine such that it will need to be serviced and totally cleaned inside. However many people have found out how to "Reset" the waste ink error and just proceed. This can be done but it is just asking for major problems down the road.
Jun 15, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
The printer doesn't print even if it is turned on. Every time I print, the printer status says it is printing but it doesn't. They say the printer should be reset bec it has reached its maximum limit. Is...
no its not true,
pleas follow the instructions from the below mentioned url.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-4&cc=us&lc=en&dlc=en&product=1100995
after you run this utility you will get to see whether there is any problem or not
please do get back to us and we will surely help you further
thanks
ragards
HAMID
Feb 18, 2010 | HP Deskjet D2360 InkJet Printer
Printer not working it keeps saying parts inside your printer are at the end of their service life, still has ink. Any suggestions?
Your printer is near to the end of service is a problem that most users encounter. It's a protection of the printer to get leaked or over flow since you printer has a small piece of waste ink pad inside the printer that collects and absorbed wastes ink.
To make it easier to explain but not exactly, your printer has a page counter that allows you to print the maximum page. If it reached that page yield the printer get the message printer is in the end of service. If you reached this problem, you can dowload a free resetter for Epson at http://www.ssclg.com/epsone.shtml.
If you do not know how to use the resetter, you can send me an email together with you printer model to give you the instructions. Hope this helps
Dec 12, 2009 | Epson Stylus C46 InkJet Printer
How do i trouble shoot waste ink absorber full in a canon pixma ip1600
Solution: Ink Absorber Replacement Options iP1600
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you feel your product might require service, a Technical Support Representative will be happy to answer any questions you may have and explain the service options available to you. You can contact us through the email link or phone numbers listed below.
  • Obtain Support by Email
  • For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON
If your printer is no longer under warranty :
  • For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. The charge will be $9.99. If it is determined that there is a hardware failure, you have the option to purchase a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, a limited manufacturer?s warranty, free next business day shipping and discounted pricing. If you elect to take this option, the pay for support charge will be canceled.
Oct 07, 2009 | Canon PIXMA iP1600 Printer
Ask
Sep 16, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
old marine
old marine
