Question about Sport & Outdoor - Others
After bring slide out in, on a 27 foot fifth wheel R.V., using the electrical switch, with no problems, tried to raise fifth wheel to hook up truck. The jack motor turned slow as if under a load. Had to raise fifth wheel manually. There was no problem with the jacks. The fifth wheel was still hooked up to the land line or 220 volt, 30 amp camp ground electricity. Moved fifth wheel to storage, less than a mile away, on the camp ground storage lot. Backed into storage spot and tried to lower jacks. There was no response from the jack mtor when switch was moved either up or down. The fifth wheel was connected to the truck electrically. Had to lowere jacks manually. While checking fifth wheel for storage found electrical items such as water pump, lights, etc. did not work. Checked volt meter at batteries, solar powered, saw 14.1 D.C. volts. Do you know what my problem is?
  • collins116 Jul 07, 2010
    did as was sugested and had no change in electrical system.
  • 484 Answers
The problem is that there is a fault in the electrical panel of the jack. That is why it is not properly functioning.
The fault most likely could be that a component on the panel is burnt or is having partial contact.
If you have the technical skills to open it up and check, no problem, otherwise, you can take it to an expert that will help you check and replace any bad part of the panel.
Take care
Posted on Jul 07, 2010
    Guru:
  • 468 Answers
I am not an expert for this but as far as I know in most of the cases it may happen due to static electric charge. At this point, I would advice you to turn off the power supply , wait for 2 minutes and try tuning it On. It should take care of the issue.
Posted on Jul 05, 2010
What holds in a slide out that has no electric or hand crank
It must have a spring loaded latching mechanism.
Jul 21, 2016 | Cars & Trucks
I have a 2001 Fleetwood Terry 27 ft fifth wheel with one slideout. Having trouble with slideout coming in.
Replace the hydraulic pressure block. I would also look at the slides for the room extension. Made out of hard plastic.
Jun 25, 2016 | Cars & Trucks
How to change front power seat track worm in 1993 landcruiser
Lift the front edge of the seat bottom by using the regular power seat switch. Take voltage readings of the seat slide motor.2 Verify that the voltage to the seat slide motor on the harness side between "BR" and "W/B" is 12v when the power seat's switch is pressed backwards and forwards. Jot down your radio presets and tap the seat slide motor so that the motor will work long enough to give you access to the seat mounting bolts.3 Pull the seat as forward as it will go. Take off the two M10 rear seat mounting bolts and set them aside. Push the seat as far back as it will go. Take off the two M10 front seat mounting bolts. Switch the ignition so that it marks "OFF." Unplug the negative battery cable. Stand by for 4 minutes. Raise the seat assembly to find the harness-to-seat connectors. Disconnect them.4 Take out the entire seat assembly and place it on a dry, clean, flat surface. Position it so you can access the bottom of the seat. Undo the seat bottom's carpet flap and take out the four M8 bolts. Then, take out the top screws from the right hand and left hand side finishers. Unplug the seat sub-harness connector.5 Put both the seat rails back into their rear position and take out the worm gears, motor, flexible wire and gear boxes all at the same time. Take out the flexible wire from the gear boxes using a screwdriver. Verify that the new seat track mounting tab makes contact with the rear stopper and that the threaded shaft facing up is point upwards. 6 Install six new rubber grommets. Place the new worm gears, flexible wire and gear boxes into the frame. Reposition the seat tracks over the seat track mounting tabs. Use your hand to tighten the M6 bolts securing the seat track mounting tabs. Torque the six base plate nuts securing the gear boxes to 64 to 85 inch pounds (7.17 to 9.69 Nm) and the M8 bolts on the seat's front edge to 13 to 17 foot pounds (17.5 to 23.7 Nm).7 Plug the slide motor connector back in and hook the carpet flap's strap. Reinstall the seat assembly and reconnect the electrical connectors and negative battery cable. Torque the mounting bolts to 27 to 36 foot pounds (37 to 49 Nm). Operate the seat to make sure that the problem has been resolved
Sep 29, 2011 | 1993 Toyota Land Cruiser
How to fill a bobbin on singer sewing machine model 6268
Raise the presser foot and turn the hand wheel to put the needle at the highest position. Next open the slide plate by sliding it towards you. Make sure the bobbin is empty (remove any remaining thread or use a new bobbin). Slide the plate forward (partially closed) so that the arrow on the plate lines up with the arrow on the machine bed. Bring the thread from the needle under the presser foot and wind it around the presser foot screw (on the left of the assembly) once. Make sure that the thread is in the spring groove. Press the One-step Button hole A button (has a bobbin symbol by it). Then begin running the machine. Watch the winding process carefully and stop when you have enough thread on the bobbin. Do not let the thread continue to wind past the outermost line on the bobbin (black). Slide the plate fully closed and raise the needle. Pull the thread to the back of the machine to a length of 4" and cut the thread in the middle of the loop you just pulled through.
Now position your fabric under the presser foot, lower the presser foot and select your stitch. Begin sewing.
The manual is available for sale or download here: http://www.singerco.com/accessories/instruction-manuals/search . Just enter the model number. The direct link is: http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf . Pictures for winding the bobbin are on page 16 (page 18 of the PDF).
I hope this helps.
(make sure that the machine is correctly threaded before starting to wind a bobbin)
May 25, 2011 | Singer Sewing Machines
I have a singer 600E touch and sew. I accidently took out the bobbin case and can't seem to get it back in. Can you please tell me how? Thanks
Open the slide plate, and remove the needle plate.The needle plate should be raised by a lever on the right hand side of the bed.Move it to the left, then raise the needle or take it out.It is also easier if you remove the sewing foot.Once you have the slide plate moved towards you you will see a black piece of metal in the front right corner of the bobbin area.Lift it up and slide it to the right.Position the bobbincase with the metal flap that locks the bobbin in towards you so when you lift it up it is on the end closest to you.Make sure the bobbin case is in the groove of the hook(the round thing that spins when you turn the handwheel)once you have the bobbin case in position you bring the black metal pieceover to the left and it will drop down to secure the bobbincase.Turn the hand wheel towards you the bobbincase should stay in place and the hook should turn around it.If it turns smoothly replace the needle plate,close the slide plate,screw the foot back on and replace the needle.You are done. www.sewvac.com
Feb 01, 2011 | Vacuums
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
Locked keys in the trunk of a 1985 chrysler fifth ave; ignition switch is locked; how do i access the trunk?
thats easy,locate the fuse for the electric trunk lock,take the fuse out,hook a piece of wire to one of the contacts where the fuse goes into and hook it to the battery or an acc line in the fuse box then hit your electric trunk switch and it should open,if it doesnt work try the other side where the fuse hooks into
Apr 26, 2009 | 1985 Chrysler Fifth Avenue
Sport & Outdoor - Others Logo
29 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
