Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water leaking during rinse cycle
Water leaking from washing maching during rinse cycle
Whirlpool Ultimate Care II Heavy Duty Super Capacity Plus
  • 5,911 Answers
If your TOP LOADING Whirlpool washer is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jul 05, 2010
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine leaks
Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
May 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer spin & gurtitate no working
Coupling is broken that connects motor to transmission. Replace it. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
452 people viewed this question
Dan Webster
Dan Webster
Sal De
