Question about John Deere 48 in. EZ Trak Power Flow Assembly
Murry 12.5 40in mower wont engage
Murry 12.5hp 40in mower wont engage
  • Fernand Luc Bergeron
    Fernand Luc Bergeron Jul 05, 2010
    do you mean that when you pull the rope, the engine won't start ?
  • 333 Answers
Could be the seat switch, the on/off switch, or the electromagnetic clutch. I would check them in that order.
Posted on Jul 05, 2010
12.5 hsp murry ride on wont run at low speed misses and has blown black smoke?
Check the choke butterfly to be sure that it is open, if so rebuild the carb...
Jul 24, 2014 | Garden
Cant get gear i to reverse on my Murry riding lawn mower
is your belt to tight? that will cause tention on the trans. and it wont go into reverse try it while its moving forward jerk it into reverse and see if it goes may be just hung between gears
Jun 29, 2013 | Mtd Garden
What is the fluid type in a murry auto drive transmission
I use 30w motor oil, plug ( either rubber or steel ) is on top.
Jul 07, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Murry 10hp 8/30 rideon can select gears but wont engage
inspect the drive belt from the engine
Jun 30, 2012 | Garden
Primary belt motion belt diagram for a murry 46 inch cut 2006 model
just did another murry today there is a sticker of the belt routing on the bottom of the foot rest
May 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
I have a murry 42" riding lawn mower and i just put a new deck belt and when i engage it works fine but when i disengage it the belt comes off i dont know how to fix it
This sounds like either a worn bearing, or a bent bearing carrier on the mower deck shaft. The belt is thrown off by a misalignment of the deck pully, when the belt is loosened by disengaging the mower.
Aug 12, 2010 | Garden
Murry 21 inch lawn mower wont start geytting fuel and spark
if the mower is not due for a tune-up I would suggest making sure there is fresh clean gas in the tank. no water. if the unit starts and dies after you prime it may need a good cleaning and carb rebuid. commonly after a mower sits for a while the contaminants in the gas will cause a rubber seat to swell. thus raising the float and shutting
off the proper fuel flow. also is your compression good. many of the
Brggs OHV engines many times need a valve adjustment. you likley have a L-head engine and with age the valve clearances may need to be reset.
Apr 27, 2009 | Garden
Need carb diagram
Go to either the murry site if still available or the briggs and stratton with all of your numbers and see what you can do with them. If you have the carb name and model # go to that site also. Hope this will help you. donnyb60
Mar 21, 2009 | Briggs & Stratton Garden
John Deere 48 in. EZ Trak Power Flow Assembly  Logo
134 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
