Question about Panasonic NN-P295SF Microwave Oven
Why my NN-ST556M oven after 23 seconds automatic turn off no matter i set how long time.
SOURCE: microwave shuts down after 5 seconds
chech the control panel and wiring and thermal sensors..
Posted on Sep 24, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic microwave oven model nn-p994sf
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
Thanks for this. Thats exactly what I did. It didn't work at first, however, I think it was my impatience! After selecting the Microwave, you MUST wait until you are told via the screen to input the time. It now works fine. Thanks again. Just needed perseverance! Mike
Posted on Aug 18, 2008
SOURCE: microwave oven problem
Hello
My microwave oven makes my cups and dishes so hot they can't be touched . The dish is much hotter than the food or beverage inside .
Do I have a defective microwave ?
Tim
Posted on Sep 17, 2008
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
Panasonic NN-F542BF 1300 watts microwave switches off after 3 seconds
It sounds like you were sold somebody else's problem, it could be a bad magnetron, cracked high voltage diode, and a shorted high voltage capacitor to name a few. I recommend a professional if you feel it is worth getting checked.
Mar 09, 2012 | Panasonic Microwave Ovens
Shuts off after 23 seconds....
In most cases when the microwave stops @ 23 seconds it's the Magnetron which has failed, and is shorting to earth.
Either that or the magnetron isn't getting the right signal from the inverter board. It gives it 20 seconds to get the right signal or it shuts itself off.
Apr 04, 2009 | Panasonic Microwave Ovens
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
You can find an authorized Panasonic servicer here.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
Stops after 3 seconds - Panasonic NN-S252BF
may be magnetron spoiled or high voltage section problem,please check circuit andreplace damage parts...
Aug 14, 2008 | Panasonic NN-S254BF Microwave Oven
Micrwave does not heat, and turns off by itself before time
Unplug the Microwave and remove the outer cabinet. Inside the cabinet will be a thermal insulated fuse, looks like the old buss fuses for early model cars but white. Replace that with the correct fuse which can be found at Lowes or Home depot and see if that solves the problem. Be careful not to touch any capacitors if they are in there.
Mar 14, 2008 | Panasonic NN-H664 Microwave Oven
Turning off before finishing time time cycle
I have just had this problem where the oven will only run for 5 seconds and then turns off model #NNS561. Cant find any solution.
Jan 19, 2008 | Panasonic NN-S950BA Microwave Oven
Microwave cuts out after 23 secs
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Dec 15, 2007 | Panasonic NN-S550WF Microwave Oven
Microwave shuts down after 5 seconds
Sep 23, 2007 | Panasonic NN-H965 Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
87 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
