Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Hello i have a problem with my wireless because the switch is in orange all the time don't matter if I change the possition always is in orange. Can somebody help me with taht? Thank you. My laptop is compaq F700
Your problem most likely lies in a fautly Nvidia Chipset, its a common problem with these laptops and while a DIY reflow could work, you would need to replace the motherboard to complete take care of the problem
Posted on Aug 03, 2010
    Problem Solver:
  • 6 Answers
Well can you connect to the internet or no, if you can it should goes Blue and if not you need to check your wireless conn.
Posted on Aug 01, 2010
H/bar brake switch wire reconnecting 96 Suzuki 800 intruder;have 1 orange 1 blk/wt wire which goes to front prong
Hi,if its the switch on the brake leaver you are talking about it dosnt matter which one gose to wich connector,as the way the switch works is the two wires make a sercuit when the leaver is let go back to its possition closed it bracks the secuit there for no power gose through the switch,hope this was some help,all the best.
Aug 20, 2015 | Suzuki Motorcycles
Help me please, my Dell V505 will only show a orange wifi sign indicating a bad wireless signal. What can i do about this?
Hello emma.
Has the printer always worked fine from that same location or was the printer in another room.If it was in another room then you might have to either move the printer back or bring the wireless router closer.
Step 2.
If the printer has always worked fine from that same position then it might not be able to connect to the wireless access point.
You either need to switch off the router /wireless access point and printer at the same time for about 1min and then try again.
Try to switch off the printer first and unplug from mains for 5 min and see if this solves the problem if not then step 2 is required.
You can download the user manual from here:
http://www.dell.com/support/Manuals/us/en/19/Product/dell-v505
And follow instructions to reconfigure the wireless section once again.
Aug 13, 2013 | Dell V505 All-In-One Printer
Trying to connect Apexis camera to internet
Hello you can download a manual here if you don`t have it:
http://www.apexis.com.cn/en/download-2.html
Here is a orange live box fault finder:
http://help.orange.co.uk/orangeuk/support/personal/235411
The IP camera must probably have a static ip adress in order to work.
When the ip adress is dynamic the software can`t find the camera everytime you turn on your pc.
You can buy a switch to connect between your pc and the modem
and connect the camera to the switch.
But you have to install the software again.
Good luck
Dec 14, 2012 | Apexis APM-J802-WS Wireless Wired Pan Tilt...
My rd-s590 igot the wires hooked up but when i start my truck it say see ya. then whenigotto put a cd in it come on then shut it self down i need to kno if i got the wires hook up correctly but theres...
Hello! you realy need the wire diagram that cam with your unit,,,, I do know this> there will be a wire that gets connected to 12 possitive and is hot all the time,, next there is a wire that is cannected to the acc 12 Possitive that is switched on/off with the key,
when the key is "off" then the unit should go off,,,,,,,not be on...
with out seeing your wire diagram, I will say that the red wire (should ) be connected to the 12 possitive hot all the time,,,, and the Orange wire (should) be connected to the 12 possitive acc "key switch)
Please remember : never ground your speakers to the car ground/body!!!!! you could damage your unit
Hope this helps...
Sep 20, 2011 | Car Audio & Video
I have HP probook 4520s i5 it dos't feel the wireless and why the wireless indecator Always orange
Most times HP wireless light is orange when it is either turned off or is not having drivers installed
Aug 09, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
Should the wireless communication orange light be on all the time . Does this cause any problems to the computer . If it does how do i switch it off
Yes. if it is enabled. depending on the type of notebook computer, sometimes the color light blue, yellow or orange.
if it is disabled. no light will appear and you can not use wireless devices and no Internet access unless u use wired.
regards
Mar 23, 2011 | Toshiba Satellite L500 Series Notebook
What color wire is the power lead for the 1991 lesabre delco radio with cassett model 16129904
Orange is hot all the time 12V+
Yellow is Switched Power 12V+ (only has power when key is in IGN Or ACC possition.
Sep 25, 2009 | 1991 Buick LeSabre
Lost the disc. the modem light is flashing orange on the router. I loss my connection all the time. I'm always unpluging it to reset it. I think some my be stealing my wireless connection.
So you having problem with your connection?
Try this:
1. Go to settings on your wireless router via Internet Browser.
2. Right click to the wireless icon connected on the menu bar.
3. Select status>Support tab>Obtain your default gateway address ( e.g. 192.168.1.1)
4. Enter your gateway address to your Internet Browser.
5. And there's settings for your router. (keep it mind to make sure you protected, change your password for your router, and make WPA encryption for your WiFi.
Hope that will help you! Feel free to ask me =]
Jul 08, 2009 | Belkin Wireless-N Wireless Router with...
Compaq laptop won't connect to internet
on my hp the light is blue when switch is on. go to network and conn. and make sure ur wireless is turn off there. cause if my switch is in the on position and i turn it off hp wireless assistant the light will glow orange eventhough the switch is on . ? Just had an issue simular to this one, hope it helps.
May 19, 2008 | Computers & Internet
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
607 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
