Question about Intex 530 GPH Above Ground Filter Pump! 58603E
Pump not working
I tipped over the pump by mistake and straightened it right away now it is not working
    Master:
  • 501 Answers
Turn off,let bleeder screw loose to let any air out[if there is any],and try again
Posted on Jul 05, 2010
Is there any way to tighten, and straighten or re-align my Anglers Choice needle nose pliers. They were fine one day and the next they don't matchange please ends when closed.
What I do when this happens is clamp one of the tips in a bench vise and pull the handles to line up the tips. This also works when a tip is bent away from the other and won't close fully. But be forewarned that this works most of the time, and sometimes the clamped tip will break off, especially after a few such fixes.
May 31, 2016 | Cars & Trucks
Anyone have any clue what these codes are?..
No codes posted. When it comes to timing, its either right or its not, if its not you'll know soon as you start the engine. Its always good to triple check the timing alignment before you put it all back together. Not only going by the marks, but always rotate the engine to make sure they stay where they should be and are properly aligned with number 1 after at least 2 complete rotations of the crankshaft.
Mar 16, 2015 | Cars & Trucks
Does anyone have any good tips for straightening hair? I am new to this.
1. Make sure your hair is dry
2. Use oils
3. Prep the flat iron at the right temperature
4. Straighten your hair with your overall style goal in mind
5. Brush don't comb!
6. Add volume
rehost_2016_9_13_0dc297ae-7caf-4215-b998-71d5ca0093eb-fblmica31ak52inb20judn4s-3-0.jpg
Feb 20, 2013 | Health & Beauty
I need directions on how to use the Revlon ceramic Straightener model RVST2024
I love my hair straightener. It doubles for a clean modern straight look to sexy voluptuousness Kim Kardashian curls without going to the salon. If you do it right your hair will look professional and feel so soft.
1. Clean and Wash Hair: I always like to have clean hair before I style it, it isn't necessary but it makes me feel more refreshed.
2. Make sure your hair is dry. I prefer to air dry because it is the healthiest way to not damage your hair. But if you want to get more volume, using the blow dryer works well.
3. Before using any straightener make sure you get heat protector gel or spray because this will help make sure your hair does not become damaged when styling.
4. I like to split my hair up into sections to get them out of the way by using hair ties or hair clips. Sectioning your hair also helps a lot of if you have specific styles you are going for.
5. Finally, do not turn on the straightener too high because it's a sure way to damage your hair. Instead, consider low-med. If it's your first time, don't rush it because you will get burned. Give yourself an hour or more! Learning how to do it the first time can be frustrating and it doesn't always look great the first time. With some practice you can also create curls with a straightener as well.
Other tips: They have specific wet-dry straightener which can be used on wet hair but unless you have those, do not use the straightener with your wet hair because it'll give you split ends and damage your hair.
Here are some more tips for straightening that might be useful for you.
Dec 18, 2010 | Health & Beauty
I have 1989 Mustang that the fuel pump won't shut off.
Check the fuel pump relay under the driver's seat. I had the same problem and would have to unplug it under the back bumper everytime i got out of the car. Don't make my mistake of not getting it fixed right away. Broke down and waining to get it towed to a repair shop and $400 bill is less than a relay.
Sep 23, 2010 | 1989 Ford Mustang
I have a samsung sp50l6hx which was stuck on stanby flashing lamp timer we have replaced the lamp and have a new ballast board and still nothing is working please help
Go Back make sure you have everything connected I made that mistake and did not have on Ballast Board where that Small 4pin connector goes was not in right had to take a tiny flat head screw driver straighten pins then pushed connector back on TV is working Fine Now! Also CK on left side I had another plugin connector that was not connected back also.
Dec 03, 2009 | Samsung SP50L6HX 50" DLP HDTV
Water not draining away
Servicing the Water Pump
Of all washing machine parts, the water pump probably takes the most punishment, because it is constantly in use. When the pump fails, you can hear or see the trouble: a loud rumbling inside the machine, or a failure of the water to drain out of the tub. Here's what you can do to fix the problem:
©2006 Publications International, Ltd.
Take the pump apart and clean
away all debris inside the pump.
Also clear away debris from
the water tubes.
Step 1: Check the drain hoses to make sure they are draining properly. Remove the water supply hoses from the back of the washer. With long-nosed pliers, extract the filter screens from the valve ports in the washer or from the hoses themselves. Wash the screens thoroughly. Then replace them and reattach the hoses. If the machine still rumbles or doesn't drain, examine the pump.
Step 2: To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the bottom of the machine, but with the unit tipped on its front it's easier to remove the pump through the back than through the bottom of the washer.
Step 3: Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Then try the machine again to see if this kinking was causing the problem. If the machine still doesn't drain, you'll have to remove the water pump.
Step 4: To remove the pump, loosen the bolt that holds the drive belt taut and move the washer motor on the bracket to loosen the belt. Move the motor out of the way and unbolt the pump; it's usually held by two or three hex-head bolts located on the bottom of the pump housing. As you loosen the last mounting bolt, support the pump with your hand. Then lift the pump out of the washer.
Step 5: You should take the pump apart if you can, because the trouble could be lint, dirt, or pieces of cloth or paper clogging the pump impeller. Clean away all debris inside the pump and clear any debris out of the water tubes. Then reassemble the pump. Hook up the pump again and test it. If cleaning the pump doesn't put it back into working order, or if the pump housing can't be removed, replace the pump with a new one of the same kind.
Step 6: To install the new pump, set it into position and connect the mounting bolts to the pump housing. Move the motor back into position. Tighten the drive belt on the motor by prying it taut with a hammer handle or pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
Step 7: Reconnect the hoses leading to the pump.
Aug 30, 2009 | Zanussi FJS1225W Front Load Washer
Error 37
pull machine away from the wall and tip back, make sure you get as mush water out of the tub as you can. a shop vac works the best. the pump is on the right front of the machine, it has a fan blade on the bottom of it, you can also tip the machine back and try to spin the pump to get it to pump out the water, also check to see if anything is wrapped around the fan blade, ( have seen socks and dryer sheets stall the pump). no tools required, there is a tab that you push while you turn the pump. hope this helps
Aug 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
I have a whirlpool ADP4400 the green light is flashing and the pump continues to pump but the cycle will not start
I had this exact problem with my dishwasher but i managed to fix it today. It was such a simple problem, the water outlet pipe had a kink in it and wouldnt let the water drain. I straightened the pipe, put duct tape around the kink to strenghten it and the dishwasher worked straight away. I hop this helps.
Apr 28, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Smart Drive 701 w/machine not spinning
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the right side of the bottom of the machine, but with the unit tipped on its front it's easier to remove it through the back than through the bottom of the washer. Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Good luck!
Sep 16, 2007 | Washing Machines
Intex 530 GPH Above Ground Filter Pump! 58603E Logo
49 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
