Question about Whirlpool RF368LXKS Electric Kitchen Range
Whirlpool range model # rf114pxsq2 flashing P5H have chaned board & sensor still flashing code please help
5 Suggested Answers
SOURCE: need operting book for the
Just go to www.whirlpool.com and under customer service there is a spot you can download it as long as you have adobe.
Posted on Jul 10, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Range Error code F1 F3
Unplug the range.
Remove the rear panel to access the temp probe.
Unplug the temp probe and test for 1100 ohms.
Test the temp probe to ground also.
Sometimes the connectors are bad.and must be direct wired.
Unplug and re-plug the ribbon connector to the ERC.
F-1 is a connection problem since you have a new control.
Posted on Mar 14, 2009
  • 41 Answers
SOURCE: Whirlpool range model GY398LXPB00 oven does not work
Turned out there was a short in one of the wires connected to the bottom element on the oven. After fixing that, I got a EO-F2 error that the repairman could not get rid of by pressing start. After hours on line and at this site I remembered that you had to do something after the power was interrupted. I came home and looked again and found you need to unplug the stove for 5 min before resetting the clock. I did this and it fixed everything. The repairman left telling me the control panel needed to replaced to the tune of about $600!
This shows you have to be informed or you can be taken advantage of. Thanks FixYa.
Bob
Posted on Aug 28, 2009
SOURCE: Whirlpool Gold Range Model#GR773LXSS (WD Sensor Open)
@DocJohn - but if it says "WD Sensor Open," isn't it possible that the Door and latch switches do not agree (i.e. door open latch closed) and that maybe just checking the alignment might be the first place to start? Just thinking out loud.
Posted on Apr 09, 2010
I have p5h code on a whirlpool oven model yxfe36lvb can't find anything on it
The START pad begins any oven function. if the START pad is not pressed within 5 seconds after pressing a function pad, the Push to Start ["PSH"] indicator light will flash and the push to start tone will sound as a reminder. you can download a manual for your range at go to "owner center", scroll down to "manuals & literature" and enter your model number
Oct 01, 2016 | Whirlpool Ovens
Error code P5H
WFG114VQO error code P5H need help thank you
Mar 17, 2012 | Whirlpool GS460 Gas Kitchen Range
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Gives codes F-2 &F3 what is the problem jachin2145@comcast.net
Hi, Error Code F2
An F2 error code indicates a failed connection with the keypad. Ensure that the connection between the keypad and control board is tight, and press the "Cancel" key. Wait one minute to see if the error code returns. If it does, the keypad is defective and needs replacing.
Error Code F3
F3 error codes are triggered by problems with the oven temperature sensor. You cannot tell whether the sensor has shorted out or has simply failed to generate a reading if your Whirlpool range only displays two-digit codes. On a Whirlpool range with four-digit error codes, the F3-E0 code represents a failed temperature sensor and F3-E1 represents a short in the sensor. Regardless of which code is displayed, replacing the temperature sensor is the only way to correct the problem.
Hope that helps.
Thanks for using fixya...
Oct 27, 2010 | KitchenAid KESC300 Electric Kitchen Range
Try to heat oven, get 'P5H' message on display
the START pad begins any oven function. if the START pad is not pressed within 5 seconds after pressing a function pad, the Push to Start ["PSH"] indicator light will flash and the push to start tone will sound as a reminder. you can download a manual for your range at www.whirlpool.com, go to "owner center", scroll down to "manuals & literature" and enter your model number
Aug 16, 2009 | Whirlpool GSW9800PW Washer
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Need operting book for the kitchen range Model RF114PXSQ2 SER. # 1819470
Jul 10, 2008 | Whirlpool Kitchen Ranges
Whirlpool RF368LXKS Electric Kitchen Range Logo
102 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
