Satellite pro 4300 series
Hi, I am in the position of having satellite 4300 with completely broken dc jack..can of course get new part but how easy/hard is it to refit?..take it the pins are soldered in....is it possible to bypass jack or do I have to brush up on my desolering/soldering skills?/ Thanks..Mike
    Genius:
  • 1,019 Answers
Hi Mike,
Not the simplist of tasks. especially on a laptop.
it,s a complete disasembly of the laptop itself, right down to barebones. the jacks themselves are very well soldered to the boards. usually 2-4 pins. i,ve done a couple myself on vaios.
i,d suggest a good quality desolder pump. and a small roll of soder-wick. be very carefull not to overheat any of the pins. and gentle pressure when lifting away the old one from the board. as you can bend/warp the motherboard. use a good quality solder and a small amount of flux, to resolder the joints. you seem a competant guy, and you should,nt have many problems.
Good luck.
Mike @ Compurepair.
Posted on Apr 17, 2008
Charge isn't consistent. Orange light flashes instead of remaining on when charging.
Are you using the original ac power adapter, or one that is designed for use with your model to ensure that it is fitting tightly where it plugs into the laptop at the dc jack?
If so, the dc jack could be broken, which could prevent the battery from charging properly, resulting in the flashing amber light, which is indicating that the battery is still low and needs recharging.
Another possibility is that the battery is defective, but the more likely problem is the dc jack since it is such a common problem.
You can find a replacement dc jack here.
http://www.laptoppartsexpert.com/c-49361-toshiba-satellite-a130-a135-series-a135-s2276.html
Good luck, please let me know if it helps.
Thanks
May 08, 2010 | Toshiba Satellite A135-S2276 Notebook
DC Jack pin is broken on my Toshiba satellite p25 S607
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Nov 22, 2009 | Toshiba Satellite P25-S607 Notebook
Toshiba plug-in ac adapter LCDlight flashing and wont boot up
It may be that you need a new, (Or good condition used), motherboard. You may not.
The problem could be the DC Power Jack. The DC Power Jack is small, and the body is made of plastic. Sometimes there is a metal shell around the plastic body. (The jack is a rectangular shape, and is just a little larger, than the outside portion of that AC adapter plug!)
This is an example of a DC Power jack for a Toshiba Satellite a215-s5807,
http://www.notebookworks.net/ProductDetails.asp?ProductCode=NBW52-0133
As you know there is a metal pin in the center, and at the back of the round hole, there are flat metal contacts.
Let me explain the construction of a DC Power Jack, and how it's mounted to a motherboard. This all has relevance to the solution.
Your laptop uses DC electricity. (The AC adapter converts AC to DC. Your laptop battery, and a flashlight battery, are examples of stored DC electricity)
DC uses a Positive connection, and a Negative connection. The metal pin in the center is Positive. The flat metal strips at the back are Negative.
That laptop DC Power Jack has metal prongs, that come out of the plastic body. One prong, (Or pin), connects to the Positive metal round pin, in the center of the jack.
There may be one, or two prongs, (Or pins), that come out of the plastic body, and connect to the Negative side of the jack. (Flat metal strips)
These prongs go down through holes in the motherboard, and are soldered on.
With the AC adapter plugged in, an accidental bump on the plug itself, could break the body of the jack, or break solder joints that hold the jack to the motherboard.
AC adapter removed, and battery removed. Use a NON-metallic object, and see if you can make the center pin of the jack move. See if the entire jack itself seems to move.
A.If the center pin moves, you have a broken DC Power Jack.
B.If the entire jack moves, you have cracked solder joints. (Broken)
Replacement of the DC Power Jack for A.
Re-solder the solder joint/s for B.
Cost of replacing a jack at a reputable computer repair shop? $90 to $150
Cost of re-soldering solder joints? $50 to $90
Cost of replacing the motherboard?
$250 on up.
If you are a skilled person with the correct tools, it is feasible for you to replace the jack, or re-solder the solder joints.
It is also feasible that you yourself, could replace the motherboard.
Some laptops have a poor motherboard design, for where the DC Power Jack is mounted to the motherboard.
Crude explanation would be, that the main body of the motherboard is a 1 foot square. Then a 2 inch square comes out of the side of the main body.
The DC Power Jack is mounted to that 2 inch square. From accidental bumping, OR just normal usage of inserting, and removing the AC adapter plug, this 2 inch square can crack away from the main body.
This, of course would require a motherboard replacement.
Disassembly instructions for a Satellite A200 and A205 Series laptops. Very close to the A215 Series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
(Don't forget to buy, and use a cheap ESD wrist strap, to prevent static shock to the delicate hardware components, inside your laptop. Average cost is $7)
Aug 04, 2009 | Computers & Internet
Gateway M Series M7301 M6885 Laptop DC Jack Adapter is Broken
The correct model number would help in order to solve the issue. Please see if you can locate the correct model number in order to help you.
Thank You,
Jun 11, 2009 | Gateway M-6885u PC Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107128&moid=1073769765&BV_SessionID=@@@@0579949615.1140817607@@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Apr 09, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
