Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
I just bought a AOSmith 1hp pool pump. I do not
I just bought a AOSmith 1hp pool pump. I do not know what voltage to set it at 230 or 115v. Which voltage do I set it?
  • 760 Answers
Well first did you have an old one you're replacing? Check it. Second you could test your voltage with a tester (best idea then you know for sure). Third, you can look at the circuit breaker in your panel, and if it is a single breaker , it is 125V If it's a double pole breaker (two wide with wide handle) then it's 230V. Usually if it is 230V then the wires coming to it would both be black, or black and red, with a bare or green ground. Usually if it's 115V you'll have one black (hot), one white (neutral) and one bare or green(ground) but at times someone will wire one 230 with black and white. There should also be a large bonding copper jumper connected to a lug on the outside of the motor to bond your system to the pool (NOT AN EQUIPMENT GROUND)
Posted on Jul 05, 2010
    Master:
  • 502 Answers
If you live in America,115v,japan,100v,Aussie and NZ 230v
How can I run my aosmith 1hp pool motor on 115v?
LOOK ON THE MOTOR LABEL IT WILL HAVE A PICTURE ON HOW TO CHANGE IT, OR TAKE THE COVER OFF THE BACK AND LOOK CLOSE YOU WILL SEE HOW TO CHANGE IT.. jay the pool pump motor repair guy in longwood Florida 32750 .. BEST TO RUN PUMP ON HIGH VOLTAGE , IT WILL RUN COOLER AND LAST LONGER AND CHEAPER TO RUN $$$
Sep 21, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
New motor, will not start - only hums
voltage set right? motors come set from factory 240 v .. or you might have moved the start switch, it's at 6 0clock on the motor make sure its centered (back of the motor) shaped like a v.. looks like this.click on this
also might be a bad start or run capacitor..or a dud motor
hope this helps
Sep 05, 2012 | AO Smith Pool Pump Motor 1HP Square Flange...
I have a 5 month old ao motor that the shop tells me has a ground fault. The company i bought it from does not want to warranty it. The motor runs when power is applied except when ground is attached. ...
The short answer is yes, but the longer version includes an explanation about the cost to do so being higher than the cost of a motor. You should contact AOSmith and ask for a local motor warranty station which is almost always an electric motor repair shop. They should be able to get you a replacement motor under warranty as the places that sell the pumps are not usually able to warranty the motor in the first place.
For help locating the shop try: AOSmith locator
John
Oct 28, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I need apicture of the wiring on a 1 hp motor
here are a couple typical wiring diagrams that cover most AOSmith pool pump motors. Without knowing more about your motor it's impossible to be exact. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck! cde0e76.jpg9fa085c.jpgc5ac9c6.jpg
Oct 02, 2010 | A O Smith Motors A O Smith 1hp 115/230v Ur...
What do wire colors mean for ao smith dl1056 blower motor
Thank you for posting your question here on Fixya.com.
White is common, Black high speed, blue medium speed, red low speed; Brown wires are for the capacitor; The remaining 4 are for selecting the rotation.
For details look at the AOSmith print here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jul 31, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Can you please tell me the correct wiring for a Hayward 120V pool pump (not 240V) Thank you
Follow diagram on the tag. typically low voltage and high voltage volt are diagramed on the tag. Most manufactures send pumps out already for 220. the A and B terminals are for pump wires. and the lines are for the power cord. follow the diagram and you can't go wrong;
The Pool Tech
Jul 10, 2010 | Hayward 1HP Super Pump II Inground Pool...
How do I replace the capatitor on my 1HP pool pump motor. I have the new part but cannot tell which of the three wires attaches to which terminal.
Please use or contact page feature at www.arrowmotor.net and include your motor model and serial number. I can try to get you the connection diagram. If by chance you have the 2 yellow, one red wire combination, the two yellow go together on either set of posts and the red goes alone on the other set of posts. There is no polarity to a capacitor so it does not matter which set is which, just what wires you pair together.
Oct 16, 2009 | AO Smith Pool Pump Motor 1HP Square Flange...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
397 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
