Question about Asko T701 Electric Dryer
Drier does not tumble but it still heats.
Drier still heats but the drum does not turn/tumble. This is a front loader "Asko" Tumble Drier. Does it have a drive belt or some form of direct drive?
    President:
  • 1,194 Answers
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Posted on Jul 05, 2010
What is the load capacity for a 84 AW white knight tumble drier?
5Kg
White Knight 84AW White Tumble Dryer by White Knight Be the first to review this item
Currently unavailable.
We don't know when or if this item will be back in stock.
  • Construction: Freestanding
  • Control of Drying: Timer Control
  • Display of Remaining Time: No
  • Energy Consumption in kWh at 1400 RPM: 2.5
  • Energy Consumption in kWh at 800 rpm: unknown
  • Energy Efficiency: A
  • Energy Savings Trust Feature: Yes
  • Heating System: Electric (incl. Heat Pump)
  • Height in cm: 85
  • Maximum Loading Capacity in kg: 5
  • Start Delay Option: No
  • Type: Ventilation
  • Type of Loading: Front
  • Width in cm: 59.6
84 aw white knight tumble drier capacity Google Search
Feb 19, 2018 | Dryers
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Jul 16, 2015 | Candy Dryers
Bosch Exxcel Condenser
replace the broken drive belt
May 13, 2013 | Dryers
I have an ASKO T700 and it heats up but does not tumble.
belt around the drum fell or broke off
Oct 29, 2010 | Asko Dryers
How easy is it to replace the rear bearing on a Zanussi TC7102W Tumble Drier, do I take the whole drier apart to do it? Thank you
you first remove the top cover,then the front cover then the drum belt and drum come out the front,and the bearing can then be accessed
Oct 14, 2010 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Asko Drier T741, Panel powers up, Press start Trips House Circuit
yes time for a full service take to your nearest electrical service place
Feb 22, 2009 | Asko T741 Dryers
TUMBLE DRIER-INDESIT IS70C
hi did u check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | AEG Washing Machines
Asko T701 Electric Dryer Logo
305 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
