Question about Refrigerators
How do i change the filter in my westinghouse virtuoso fridge model rs645
    Problem Solver:
  • 5 Answers
Turn power off this avoids water solinoid valve opening.
Locate the filter housing righthand side under master mind control panel on topshelf next.
Remove light cover by pushing bottom rear up and gently pullout.
Unscrew filter cover looks like upside down juicer.There should have been a special white plastic spanner which came with the refrigerator.
Pull filter element down.
Install new element by firmly pushing up.
Screw filter cover in gently don't over tighten.
Turn power on and operate water dispenser to remove air and check for leaks
Posted on Oct 14, 2009
Our Westinghouse Virtuoso side by side refrigerator with ice-maker Model RS645V*10 will not make any ice. Would changing the water filter fix the problem or is it a bigger concern?
If you are getting water from dispenser, then changing filter wouldn't help. Is ice maker getting water? Is freezer at or near 0F?
Nov 16, 2017 | Westinghouse Refrigerators
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse virtuoso fridge freezer manual
where is filter located for water and ice block dispencer on a 2003 model
Sep 13, 2010 | Refrigerators
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
384 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
