Question about Vivitar ViviCam 5340s Digital Camera
The usb cable dont works - Vivitar ViviCam 5340s Digital Camera
  • kakima Jul 05, 2010
    Have you considered NOT connecting the camera to the computer?
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.<!-- from fixya rte -->
Posted on Aug 10, 2010
Need a connecrtion/cable for downloading photos from phone to computer whats it called and which type do i need
Hi
Depending on your phone you will need either a mini - USB cable or micro USB cable. You can find them on eBay. Most likely Micro USB.
Micro USB:
http://www.ebay.com.au/itm/2M-3M-MICRO-USB-Cable-Data-Charger-For-Samsung-GALAXY-S4-HTC-ONE-M7-M8-/400691057892?pt=AU_MobilePhoneAccessories&var&hash=item5d4b0c54e4&_uhb=1
Mini USB:
http://www.ebay.com.au/itm/New-1m-USB-2-0-Male-A-to-B-Mini-5-Pin-Cable-Lead-XC03-/321443971464?pt=AU_CablesConnectors&hash=item4ad78dc188&_uhb=1
Aug 31, 2014 | Cell Phones
My ps3 controller won't work turn on or charge
Check to see if your USB cable works.It coulb be that your USB cable dont work and since your your ps3 remote needs to be charged then when you connect it to charge nothing happens so try using a different USB cable to see if that works..
Jul 02, 2011 | Sony Playstation 3 (PS3) Console
How to connect pc with micromax Q5 mobile. I am using vodafone prepaid connection.
you connect via a usb cable or bluetooth which is a wireless connection. if you have tried connecting with a usb cable, what happens? If the device cannot be seen or recognized by your pc the most common reason is that you dont see a device you plugged in is that you dont have the proper drivers installed on your pc. See what error meesages you get, and troubleshoot! Are you saying your internet connection on your PC is via vodafone usb dongle? This should not affect your ability to connect a mobile phone via a usb cable which should work without being connected to the internet. Its all a question of hsving the correct drivers, but some software wont work with the dongle software, which has to be uninstalled. Troubleshoot for the correct drivers them get technical help from micromax
Dec 27, 2010 | Computers & Internet
How can i connect my laptop bought 2 weeks ago to my cable modem its a sb5101 cable modem by motorola
This modem is USB or Ethernet. I strongly reccomend using the ethernet and not the USB option as USB will lose some speed.
An ethernet cable is a standard RJ45 Jack'd cable (both ends) - check google images if unsure but you'll see the plug in the modem that is the same as one on your laptop.
If you dont have an ethernet port on your laptop (possible but unlikely) then you'll have to use the USB option - this is a usb cable similar to a printer usb cable (square usb end at the modem and flat usb to the laptop)
Hope this helps! please dont forget to rate :)
Nov 03, 2010 | Arris SURFboard® SB5101 Cable Modem
I'm tring to download the driver software onto my HP laptop but doesn't seem to work. Should I see an icon once this has successfully downloaded?
Yes it should be, but first try to uninstall the drivers, disconnect the printer usb cable connection, turn off the printer. then install again your drivers, but dont connect the usb cable yet, when the software prompts that it should be connect it, connect usb cable then power on the printer, let it run what it should do, dont interrupt any installation, when its done, youre off to go.
Jun 15, 2010 | Epson Stylus C86 InkJet Printer
WHERE TO PUT THE WIRES ONE IS A DATA CABLE TH OTHER IS A ETHERNET CABLE?
I dont understand the question. Usually connections are very self explanatory because sizes of plugins are unique.
An ethernet cable has an rj45 connector and can only plugin to an rj45 connector.
Usb have 4 or 5 type connectors but they are unique to them also.
Personally I never use the USB connector cable though sometimes you may have to if the modem or router doesnt seem to work with the ethernet cable.
Lay people that have no idea how all this modem router stuff works should probably follow the directions for setup using the USB cable.
Apr 01, 2010 | Arris High Speed DSL Modem
I don`t connect with usb of PC. The USB port not reconigze it
use only the rear USB port of desktop, because by using any extension or hub there is a voltage drop so that why it is not recognisezed, only use the rear USB port and use the orignal cable or branded product USB cable, loose cable also dont work with it.
Feb 14, 2010 | SimpleTech SimpleDrive 160 GB External USB...
During installation, device is not detected error appears. tried uninstalling software, unplugging cables, restarting, reinstalling, then plugging cables in. did not work. Windows XP o/s. already checked...
is it wireless or usb, if it usb, dont connect the usb cable. on the installation window where it asks for the usb cable, chek mark on the option connect printer later and continue with the installation
Oct 02, 2009 | HP PhotoSmart 7760 InkJet Printer
My computer doesnt recognize my sansa express and it used to
check usb cable and make sure that the cable is connected properly .
Try connect to other usb port .
Hope it helps
Jul 17, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
How do i have a usb port run a high speed device
The USB port in your computer is not the new high-speed USB 2.0 version, and when you plug a USB 2.0 device in you will get that message. Most USB devices will still work but not give best performance. Just close the message window.
The network cable unplugged message can be disabled through the network settings. Normally Windows is set to display that message when there is no network cable connected. You can just ignore the message.
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
Vivitar ViviCam 5340s Digital Camera Logo
24 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
