I hooked my samsung 403t flat screen monitor up to a RCA home theater in hopes of being able to get an audio connection . Did I waste my money on buying this home theater, or can somebody point me in the right direction? help !
  • David Dahwud Hughes Jul 05, 2010
    thanks buddy. I'll see how it goes
    President:
  • 1,099 Answers
If you need to use HDMI cables to link electronic devices to your high definition television, you may be wondering how to tackle the connection process. Fortunately, connecting HDMI cables to a high definition television is a simple task that can be completed in a timely and stress-free fashion.
Prep Your TelevisionBefore connecting your HDMI cables, make sure your television has been safely turned off. Connecting or disconnecting cables when the device is operational can cause damage to your television.
Locate Your Television's HDMI Connection PortsNow that you've turned off your television, you'll need to locate its HDMI connection ports. These ports are typically located on the right side or the back end of high definition televisions. Be sure to consult your television's owner's manual or the manufacturer's website to determine the location of the HDMI connection ports. Take care not to confuse the device's HDMI connection ports with its standard AV connection ports because the two can appear to be similar.
Connect Your HDMI CablesHaving turned off your television and located the appropriate ports, insert your HDMI cables' connectors into the corresponding color-coded connection ports on both your television and the linking device. Your television should then be ready for the electronic device hook-up.
Hope this helpout....
Posted on Jul 05, 2010
How do I connect my flat screen tv to my Phillips MX3900 system
This is an older home theater package and only has component video out for HD and RCA or SPDIF optical out for audio. You'll need to locate the component video input on the back of your flat panel and connect it to the component output of the Phillips unit. Component cables have 3 RCA cable (Red, Blue, Green) for HD. You can use a RED/WHITE RCA cable for audio but if you have a SPDIF Optical cable you should use that for better sound. The TV should have that as an input also. You will need to go into the Menu for the TV and select component video and SPDIF optical if you went that route for audio.
Dec 03, 2014 | Philips MX3900 System
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
What is the proper way to connect to home theater system?
Does the Sub have a Low- Level input? This is a RCA type female connector, what you need to do is run a Male RCA cable from your home theatre where it says Sub-OUT and go into the Sub woofer Line in. Unless you only have speaker wire inputs on the back of the Sub then take the Left and Right front into the Sub speaker inputs and then out of the Sub speaker OUTS back to your speakers.
Feb 28, 2009 | Omage BB08 Subwoofer
How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Feb 27, 2009 | Coby 5.1 Channel Home Theater Speaker...
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
Hooking samsung htz310 into insignia 52 inch flat screen
From what i learnt you learnt to connect tv to system with hdmi and a  optical lead..
Jan 20, 2009 | Samsung HT-Z310T Theater System
Hooking my flat screen tv to my home theater
Since your output is coaxial (rca) you should be able to find an input for coaxial that will work on your surround the setting on your surround will be either coaxial or digital input,
hope this helps
it would help if you said what kind and model of surround you have
Dec 02, 2008 | Philips Magnavox 42MF521D/37 Television
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
