GLTF1240AS tub is loose inside and makes thumping noise when spinning
the dr
  • 447 Answers
SOURCE: Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Posted on Oct 03, 2007
SOURCE: Kenmore spin cycle thumping noises
Read this post (and comments!) before throwing any money at this washer: http://www.appliancejournal.com/appliance-repair-help/washer-repair/why-kenmore-front-load-washers-fail-271/
Posted on Mar 13, 2008
skrbin
  • 121 Answers
SOURCE: Makes a loud banging sound when spinning clothes
check springs and shock absorber.try to put more laundry.
Posted on Feb 16, 2009
  • 106 Answers
SOURCE: Kenmore front laoder washer with loose wash basket
Highly likely that either your bearings or spider arm has gone out, this is no easy fix. You can 'search' above or click on 'troubleshooting' in blue to browse
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Posted on Feb 28, 2009
  • 113 Answers
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Posted on Mar 03, 2009
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Scraping, thumping, and whining sound as the washer drum spins. sounds like something may be loose inside. sounds like a loose belt squeeling?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 19, 2011 | Frigidaire Washing Machines
I have a whirlpool duet front loading washer and during the spin cycle it makes a horrible thumping noise. It seems like the drum inside is very loose as well.
you may have a broken shock, remove lower pane with a 1/4 socket or nut driver, once you have done that you should see 4 shocks at each corner of outer tub, if one has come loose or broken it will sound loud when in spin, it should be easy to notice
Sep 20, 2010 | Washing Machines
Loud thumping noise during spin.......not related to unbalance....manually turning the tub makes a loud noise.
Bearings shot or counter weights have come loose
Take the top off and check the weights first
Jan 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer makes loud, thumping noises during spin cycle.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Jun 22, 2009 | Washing Machines
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
