Question about Sony Playstation 3 (PS3) Console
The yellow light comes on when i try to eject
The yellow light comes on when i try and eject a disk , and the the redlight flashes
  • 58 Answers
This is the YLOD. It happens when the system overheats causing the solder on the board to melt and bridge. Your board needs to be professionally reflowed. Check out www.wiredextreme.com or call 1-888-389-3038. We are a professional, BBB accredited repair shop that can fix this for you. All of our repairs include a 90 day warranty with the option to extend up to four years.
Posted on Jul 05, 2010
PLAYSTATION3 80 GB has lights flashing:green,yellow,green then flashing red.had a dvd disk that would not eject.i took it apart and removed disk.the dvd had some damage in one spot.playstation will no
Hi there James
it seems to me like you have the yellow light of death, but don't worry this is something that can be fixed.
You have two options here
Option1 you can send the console to SONY for $150, they will send you a refurbished model oh and all data may be lost. The whole process usually takes about 4-6 weeks.
Option 2You can fix the problem at home with a PS3 repair guide worth only $40 a 3rd of the cost of sony, the ps3 will be fixed within the next hour or 2.
Hope this helps
Nov 26, 2011 | Sony PlayStation® 3 (80GB) Console
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
It flashes a yellow light in front instead of green when i press the power button and won't let me play or even eject the disk
the ps3 is dead call customer support if you need hte disk out turn it on hold eject flip power switch off in the back whili still holding eject and turn it back on it will force the disk out
Dec 04, 2010 | Sony Playstation 3 (PS3) Console
It wont turn on just flashed red light and wont give the disk back
watch the lights on the front when you try to turn it on. If the blue light flashes yellow for a second, you have ahardware failure, so-called Yellow Light of Death. You can get the disc out by turning off the switch at the back, then hold down the eject button and turn the back button on again.
May 01, 2010 | Sony Playstation 3 (PS3) Console
Mid game my console beeped and shutoff. Now it wont eject disk or turn on at all. Light goes Green, Yellow then flashes Red
your PS3 overheated, what you need to do is remove the power cable and hold the power button for 5 seconds to make sure that there is no power left, then plug it back in and press the eject button hold it down, it will power up and eject disk, if that fails, you need to RMA your ps3 to sony or you can try and return it to vendor with the game case or dvd case of the disk that is stuck they should replace both
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
When I turn on my PS3 the light flashes green 3 times then yellow twice then red. It won't eject the game disk. I've tried holding the eject button for up to 30 seconds without success.
Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony. North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
2. You could try this article, if you choose to, it's a long shot but might work for you in your case. http://ps3.qj.net/Possible-PS3-flashing-red-light-fix-from-MXACE/pg/49/aid/75721
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Dell crashed with cd still in drive - how to remove disc?
To manually eject a CD look for a little pin hole usually below the cd drawer. Unfold a paper clip and stick it in there and push. The cd drawer should come out a little. Also sometimes you can hold down the cd eject button as the computer is powering up and it might eject.
The flashing yellow light seems to be a more serious problem. Do you have any ABCD diagnostic lights on the rear of the machine?
It may be either a bad power supply or bad motherboard (capacitors bulged or leaking). You can visually inspect the motherboard by looking at the capacitors (look like little tiny soda cans). If any are bulging or leaking any fluid then they are bad. They should be perfectly flat on top. If you feel adventurous you can take apart the power supply and look at it also. Just make sure it is unplugged.
Mar 12, 2009 | Dell Dimension 4600 PC Desktop
On and off lights
You have the yellow light of death. You will need to have the mother board serviced.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
