Question about iLO 3200 32 in. LCD Television
Antenna problem I just bought an ILO-32hd but doesn't have coaxial input just like orange color rca input, what should i do?
    President:
  • iLO Master
  • 1,779 Answers
That model requires a HD cable box from your cable company. It does not have an atsc tuner in it. That's why they are lower in price.
Posted on Apr 17, 2008
Where is the coaxial output on the LT-2722 twenty-seven inch LCD TV from Norcent
Many new TV's do not have a standard coaxial input anymore. The industry has moved on from that and you might have to get an external tuner to get an input like that. I found an old review from 2006 and it shows the antenna input on the bottom side where the power cord plugs in. http://www.geek.com/xyzcomputing/norcent-lt-2722-27-inch-lcd-tv-571351/
Jul 07, 2016 | Televison & Video
I need to know the type of audio cable to use with the Altec Lansing BX1021 2 speaker system.
COAXIAL DIGITAL JACKS;
{COLOR OF RCA COAXIAL CABLE CAN BE DECEIVING THIS CABLE CAN BE A BLACK, ORANGE, ETC.} IT'S BASICALLY COAXIAL -- OUT & IN..
http://www.crutchfield.com/S-S7N8XMJitvh/learn/learningcenter/home/connections_glossary.html
**ABOVE IS THE URL ADDRESS WHERE I FOUND THIS INFORMATION COPY AND PASTE TO YOUR URL BAR AND DISCOVER THE WORLD WIDE WEB
This type of jack is used for the digital audio inputs and/or outputs on A/V components such as receivers, CD players, DVD players, and more. Coaxial digital jacks are also sometimes found on higher-end PC soundcards for digital audio input and output.
Coaxial digital inputs and outputs use standard RCA-type jacks (so coaxial digital cables are terminated with standard RCA connectors). But the cable itself is specially designed to handle the much wider frequency bandwidth of digital signals
**** ~ Where did I find this information here is the URL Address where this information was found. ~ ****
Dec 07, 2010 | Altec Lansing BX1021 2 Speakers
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Ilo 32HD NO Channels! buzzing noise
the input setting may need changed on your tv
Dec 09, 2008 | iLO 3200 32 in. LCD Television
RCA RTD 215 audio input
After posting my question on Fixya, I went to www.cnet.com and found reviews on 3 systems $100-200 which had coaxial digital audio inputs.
Oct 07, 2008 | Audio Players & Recorders
Cable in connection
Most TV models/cable providers uses the F type of coaxial connector as shown below. 7c21c7e.jpg
However, some versions intended for other regions (Europe & Middle East) uses the PAL type of connector likewise shown below.
If your model uses the latter and your cable provider uses the F type, what you need is a straight F type Female to PAL Male adapter. Or it could even be just the other way around.
They are available in most electronic parts/supply store or online. You can try here, here or here.
Hope that this be of idea/help. Pls post back how things turned up, r should you need additional information and/or if your cable connectors are of different types. A photo of the connectors would be nice.
Good luck and kind regards.
Jan 06, 2008 | iLO 3200 32 in. LCD Television
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
72'' LCD Ilo won't switch inputs
By a learning remote. Go to WalMart borrow the Ilo remote and use it to teach your learning remote. Simple!!
Jul 31, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
157 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
