Question about Cuisinart DLC-2009CHB 9 Cups Food Processor
Work bowl stuck.
The work bowl on my food processor is stuck on the base and won't release. What can I do to release it?
  • 10,865 Answers
Hello. It will release. Just use a wooden spoon wrapped in a towel to gently tap on the handle until it moves and releases. J.
Posted on Jul 05, 2010
Lid stuck on work bowl of kitchen aid processor
This tip is used to remove a stuck bowl from the base of a Kitchen Aid tilt-head mixer. It might work for your situation. Fill the bowl with very hot water (use the food shoot as a pour spout). Now use either frozen gel packs, or a bag of ice cubes, and lay the ice on top of the lid. Wait for a few minutes. The hot water with make bowl expand, ice will make lid shrink, thus loosening the tight lid. I'm assuming that the lid edge fits inside of the bowl, like most food processors do. Try to gently move the lid, and see if it'll give.
Mar 20, 2017 | Food Processors
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
How to take out stuck chef bowl
I've not seen a bowl stuck on one of those unless the chopping blade is jammed on the shaft and preventing the bowl lifting up. Or is the chef bowl a smaller bowl that fits inside the main bowl?
Jan 12, 2016 | KitchenAid Professional KFP770 Food...
How do you take bowl off for cleaning
Hope you've worked it out by now, but there are 2 notches at the bottom of the bowl that slot into the base. To remove the bowl, take the lid off and rotate the bowl clockwise so the notches disengage from the base, and simply lift it off/. I assume if you couldn't do this the bowl must have had a lot of gunk stuck in the notches which prevented it from moving - yuk! I put my bowl and lid in the dishwasher - no prob.
Jul 02, 2012 | Sunbeam 4817 Oskar Food Processor
How to disassemble the Sunbeam Oskar processor to wash.
Ours is hard to remove, too. I just hold the base with both hands, then put my left thumb and right index fingers on the parts of the bowl where it attaches to the base. Then push it, if I remember correctly, clockwise. This works far better than gripping the entire bowl.
Jun 30, 2010 | Sunbeam 4817 Oskar Food Processor
I cannot remove the top from the base
I don't know what brand food processor this is. However, are you saying that the bowl will not rotate to release? It's normally just a matter of twisting the bowl (probably anti clockwise when viewed from the top) in order to release it.
Apr 12, 2010 | Cuisinart DLC-5 Food Processor
The base is stuck on. I was able to take base off.sunbeam oskar
Mar 12, 2010 | Sunbeam 4817 Oskar Food Processor
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food processor
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-2009CHB 9 Cups Food Processor Logo
1,501 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
