Question about Lexmark C500n Laser Printer
Replace wt pack - Lexmark C500n Laser Printer
  • Official Brand Answer
  • 3,344 Answers
The waste toner bottle is nearly full and will need to be replaced. The printer will be able to print approximately 50 more pages and then will no longer print until the waste toner bottle is replaced.
Here's an article in the Lexmark website on How to Replace the Waste Toner Bottle. Just click on this link: http://bit.ly/c4gVUM. Follow the instructions carefully. Hope this helps.
Posted on Jul 05, 2010
Switch to switch colour code
Cat 5/6 cable connections - straight thru both ends the same.
cross over cable - one end type A other type B
TYPE A
wt-or
or wt
wt grn
blu wt
wt blu
grn wt
wt brn
brn wt
TYPE B
wt grn
gn wt
wt or
blu wt
wt blu
cr wt
wt brn
brn wt
Color Table
wt - white
or - orange
blu - blue
grn - greeen
brn - brown
wt blu = primary color is white with a blue stripe color
blu wt is primary color is blue with a white stripe
Feb 09, 2013 | PC Connection Cross-Over Cable (363003X)
Wt happens wen they go bad coil packs
when coil packs start to fail you will probably start getting a miss in the engine as the coil gets worse of course the miss will get worse..until a no start condition could occur
Jun 30, 2012 | 1993 Chevrolet Lumina
How do I order a mic clip for the wireless mic. The one I have broke.
Contact Bosch/EV (formerly Telex) via website or call them. They're in Burnsville Minnesota and their customer service is excellent.
Feb 25, 2011 | Telex WT-55 Belt Pack Transmitter (027)...
Replace KPH speedo
http://www.drumhillcycle.com/
http://www.bikebandit.com/?WT.mc_id=67956&WT.mc_r=2&WT.srch=1
http://www.powersportspro.com/
Copy each one into a new window or tab address bar and check out there inventory.
Jul 27, 2010 | 2001 Suzuki VL 1500 Intruder LC
Good recption on bar reading but not very loud
The good reception has nothing to do with your audiolevel.
You have to adjust the gain on your Belt Pack or on your receiver.
Regards,
Gerard
Mar 20, 2010 | Telex WT-55 Belt Pack Transmitter (066)...
What does replace WT pack mean?
Error:
Replace WT Pack
Means:
The waste toner pack is full.
To Correct:
Replace the toner pack.
Oct 17, 2008 | Office Equipment & Supplies
Installing STK392-570 IC's on a Mitsubishi WT-46809
tburg05,
Whoever told you that the WT46809 took two STK392-570 Ic for convergence amps were absolutely - 100% correct... The amps are located at position number Ic8c01 & Ic8c02 on the board. Very difficult to miss too they are about half the size of a pack of cigarettes and 1/4 as thick. They are Mitsubishi part number 267p150010 and after replacing them you want to also check all the low ohm resistors in that circuit for the yoke return.
If you order them don't get them from ebay or some other less than ignorant place, our industry is loaded with chineese knock-offs that would last tem minutes in your set before failing again... Personally I'd order them from Acme Enterprises out of Florida, 800-575-9833 and know that they were Sanyo originals that way.
BTW: If you replace these yourself make sure to use a generous portion of heat sink compound on the new installs for heat dissipation.
Bill
Dec 11, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Need a good laptop
After doing some searching this is the closest one I can find. It comes pre-installed with Vista, but includes a down-grade CD to XP Pro. Its the Travel Mate 5720-6337. I can get this unit for $1399 plus shipping. If you would like the Media Center version of XP, it would be an additional $120, and if you would like for me to pre-install it for you, it would be $250 instead of $120. If you are interested, feel free to contact me and we will make arrangements.
Nov 26, 2007 | Acer TravelMate 8200 Notebook
Lexmark C500n Laser Printer Logo
1,077 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
