We have a Dimplex "Oil Filled Column Radiator" Model OFC2411TI It has been turned off (and unplugged) all summer and now that we have turned it on, the Electronic Timer Operation panel does not light up. The neon at the top is glowing indicating the power is on, but even when the machine was turned on for 16 hours, no heat was produced. Thanks in anticipation ****
  • stacey22 May 25, 2009
    Same ~ switched on and a dim light on the electronic timer but even hitting reset won't turn it on, there doesn't seem to be anyway to get the cover off to change the battery, does anyone know how to do this or override the electronic timer so the heater works manually?
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
muttandjeff
  • 359 Answers
SOURCE: Burners wont ignite
does unit have thermo-cupling
Posted on Nov 24, 2008
  • 400 Answers
SOURCE: Will not operate: operation light
You have not specified the make nor model. Five flashes can indicate a blocked drainpan and drainpipe which needs cleaning.
Posted on May 14, 2009
  • 30 Answers
SOURCE: Amana Quiet Zone air conditioner 12m12ta
Try setting the Unit to run full out, set unit at 66* it maybe the lights flash to let you know the save ( power) is on ?. Otherwise look for the manual and troubleshooter page .
Posted on Jul 18, 2009
How to set timer
Here is a link to an Owner's Manual for a Dimplex Model that is similar to yours. They all function just about the same way.You can downbload & print the manual if you so desire.
http://www.dimplex.co.uk/assets/product_instructions/Dimplex_Oil_filled_Column_Radiators_UK-Issue_0_H27a.pdf
Hope this helps you.
Jun 23, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
We have a new OFC2400TIF heater. We have set a program which worked for a day. Now the heater will not work on either manual or auto. The display lights are all on, the screen indicates that the heater is...
The heater may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the heater from the wall outlet. Wait 12 - 15 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and set the controls as you normally would. Hopefully, that 12 - 15 minute timeout allowed the heater to reset itself. If this continues to occur, contact Dimplex Technical Service at
888-346-7539.
Hope this helps you to further troubleshoot and solve the problem.
Apr 24, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
I have lost the brochure for my heater, the Dimplex Eco 2.4kW 11 Fin Column Heater.how do you set the timer?
Emily, if you live in the USA, contact Dimplex Technical Service 888-346-7539 for that information, as well has getting a replacement Owners Manual.
Apr 18, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
A leak has developed on my oil filled Dimplex rad is there any way to fix this thanks
Sadly, the short answer is "No, not safely". Because, repairing it won't solve the problem of why it started leaking in the first place.
Sorry, I wish I had better news for you.
Feb 11, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
The oil filled radiator is leaking oil when it is on.
Turn it off and if it is not under warranty dispose of properly. These are sealed units and there is no way to refill it. They should never leak, and when they do that is because of a bad weld or rusted metal condition. Sorry this is probably not the solution you want, if it is under warranty return it to where ever you purchased it. It leaks when it is warm because the oil gets hot and thins down to about the viscosity of water.
Dec 29, 2010 | Dimplex OFC2000 Oil Filled Radiator Heater
Oil filled dimplex leaking oil and funny smell
oil smells funny when its hot you heater is porous needs to be replaced
Nov 29, 2010 | Dimplex OFC2000 Oil Filled Radiator Heater
My oil filled radiator trips the mains after a few
Try changing circuits (plug into one not protected by the same breaker.)
While the heater element can fail in your heater, I have had to replace several breakers after only a few years use after they became overly sensitive.
May 24, 2010 | DCS Heating & Cooling
I have an oil column heater about two years old, this year it is emitting an adour, is this normal , does the oil get old?
You need to give this heater a good clean with a mild detergent and cloth with it unplugged let it dry for a few hours then try it again. The oil is sealed inside inturn you can't smell this unless it's leaking.
Cheers
May 30, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
Manual for Dimplex construction heater
Can someone tell me how to work the time on my Delonghi 0820 heater..
Thenk you
Oct 14, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
