Question about Dishwashers
I have a ge Profile PDW7880G00SS that won't let water in. Need to know replacement parts valve part # etc... That I should purchase
    President:
  • 3,085 Answers
I have a GE profile model # TFX30PR the plastic tube for the icemaker keeps freezing
The water inlet valve is bad allowing the water to drip into the tube and allowing it to freeze there clogging the tube. This is the most common cause for the tube to freeze. You will need to replace the "water inlet valve" on the back of your unit. Here is the part you need to order.
Oct 28, 2012 | GE Profile Performance 29.8 cu. ft....
Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
May 22, 2012 | GE Profile Arctica Stainless Steel Top...
Ge diswasher won't fill with water
When the program is switched on if there is no water flow despite the fact that the inlet flow is good, then the inlet valve is defective. it can be a failed valve if there is no action and if the flow is low then it can be a clogged valve. Remove, back flush and reset, if not replace, provided there is power to the valve.
Oct 22, 2011 | GE 24 in. Profile PDW7880G Built-in...
Won't dispense ice
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Arctica refrigerator - water is leaking from the bottom of the solenoid where the plastic hose goes up to the water filter (on the outside of the refrigerator.
Turn off the water supply and check for cracked or broken water tubing/line. Make certain that there is teflon (white) tape on threads connecting water inlet hose from shut off valve at wall to water valve at refrigerator. If there is no apparent damage to tubing or hose, then your problem may be with a water valve solenoid that is not seating/closing tightly. Replace the water valve assembly, if necessary.
Note: If plastic tubing is damaged, etc., you can splice the tubing with a "coupler" and/or more tubing purchased from Home Depot or Lowe's.
Feb 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Dishwashers Logo
105 people viewed this question
Top Dishwashers Experts
Owen Barnes
