Question about Emerson EWF2004 20" TV
How to remove protection from tv - Emerson EWF2004 20" TV
    Scholar:
  • 50 Answers
Here is the manual for the TV. The info you are looking for is on page 4. It is called V-chip setup.
http://www.funai-corp.com/6pdf/om/EWF2004.pdf
Posted on Jul 05, 2010
How to watch iTunes movies on LG smart TV without Apple TV?
Lg won't talk to your Mac, what I do is take a pc formatted USB stick and copy the movie to it and then plug it into a USB port on the tv. If the file is bigger than 4 gb you will need to write it to an ntfs formatted drive, the Mac doesn't speak that natively but there are free file systems for the Mac that do out on the internet.
Sep 22, 2017 | Apple Computers & Internet
Tip
How to burn protected iTunes stuff to DVD?
Many users want to burn DRM protected iTunes videos/movies/TV shows to DVD playable on home DVD player and enjoy on the widescreen TV. I know you can enjoy iTunes movie on TV with Apple TV, but why do you have to spend more $299 if you can do that with some easy software. What you need to do are just two steps:
1. Remove DRM protect from purchased iTunes video/movie/TV show to unprotected video.
2. Burn the non-protected video to DVD.
This step by step iTunes to DVD guide will teach you how to burn iTunes video to DVD, let’s start it.
Step 1 of iTunes to DVD guide: Remove DRM protect from purchased iTunes video/movie/TV show
Step1. Download iTunes DRM Remover, then install this DRM removal software, click button “Add” to input DRM protected movie or music, you can also directly drag-drop them into the main processing window.
Step2 Set the output settings
Choose your file and set the output settings in the "Convert video to" area:
Step3. Begin to convert DRM
After finishing all the necessary settings and editing, click the "Start" button to start converting, That's all.
Step 2 of iTunes to DVD guide: Burn the non-protected video to DVD
Please download and install the Cucusoft Video to DVD Burner at first.
Launch Cucusoft AVI to DVD/VCD/SVCD Converter pro, you will see the right UI.
1. Select radio button "To DVD"
2.choose the "merge" or "batch" tab.
3.Click "Open" button to open your movie file(s)
4. (optional) Set your preference. Region "4" in red frames can set the output MPEG properties.
5. (Optional) Set the advanced settings as following.
6. Click "Convert" button to start the conversion task
7. After you click "Convert" button, the following dialog will pop up automatically.>
8. After video conversion done, the "CD/DVD Burning engine" will be launched automatically. Please choose the DVD burner.
9. Please place a DVD-/+R/RW disc into your DVD burner. If it is a rewritable disc, the program will erase the disc before burning DVD disc.
10. When burning DVD is done, the DVD disc will be eject automatically. You can also find the output file at the output folder.
Done!
Source from:
http://www.dvdtoitunes.net/itunes-to-dvd.html
iphonebooy,know nothing but news about Apple's.
Just jailbreak ipad,ipad transfer,
mac video converter ipod transfer.
on May 24, 2010 | Computers & Internet
I am trying to remove the tv stand base off my 42lg30. Can someone please help!
DETACHMENT
Carefully place the TV screen side down on a
cushioned surface to protect the screen from
damage.
Loose the bolts from TV.
you can view a larger image by clicking on this link then selecting the Manual on the right hand side
the information you will need is on page 13 of the manual
http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-42LG30.jsp
Detach the stand from TV.
After removing the stand, install the included
protection cover over the hole for the stand.
Press the PROTECTION COVER into the TV
until you hear it click.
Dec 03, 2010 | LG 42LG30 42 in. LCD HDTV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
How do I take stand off
damage.
Remove the 4 M6 bolts by the CABLE MANAGEMENT CLIP.
Jul 09, 2009 | LG 42LG50 42 in. LCD HDTV
No Power
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH....... sory if was tooooo loooong
Sep 18, 2008 | Mitsubishi WS-55807 TV
Sharp 61R WP4h
side fade is down side of projection tv's
there is no harm other than you have to be careful now.
Dec 04, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Emerson EWF2004 20" TV Logo
75 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
