Question about Garden
Lately my Stihl bg 61 av Leaf Blower is very hard to start. I put in a new spark plug; the fuel mixture is correct. It used to take four pulls to start and now it takes at least 10 pulls.
5 Suggested Answers
  • 61 Answers
SOURCE: NOT GETTING FIRE TO THE SPARK PLUGS for a leaf blower
bad coil, or bad off on switch.
Posted on Sep 06, 2009
nova2nv
  • 197 Answers
SOURCE: Simply need the fuel mixture
50 to 1.
Posted on Sep 07, 2010
  • 20 Answers
SOURCE: Stihl BG 75 blower doesn't
These units are very promt to gas fouling of spark plugs, try replacing plug. If you still have no spark then possibly the flywheel has a metal strip in it that is prone to rusting, especially if unit does not get used alot, can be cleaned up with 180 or 22 grit sandpaper. If this strip is rusted then coil cannot communicate & therefore you get no spark. Lastly if all above check out good then most likely you have a bad coil. If coil is to be replaced make sure to gap the coil away from flywheel by placing a peice of paper folded over between coil & metal strip-(magnet) coil will pull itself to strip, tighten bolts & remove paper, gap is set.
Posted on Nov 10, 2010
  • 110 Answers
SOURCE: I am getting no spark at plug. Briggs model 31c707
Hello, the next couple of things to check would be under the engine lid.
  1. Remove the screen over the air fan on the top of the fly wheel.
  2. Remove the 4 bolts securing the main lid and remove. Depending on the year of this engine it may have a secondary cover that Craftsman put on that will need to be removed first.
  3. When the lid is off you will see the magneto coil right above the spark plug; just follow the spark plug wire up to it.
  4. Use a wrench to see if the magnet on the fly wheel is strong. If the magnet is bad or really weak the flywheel will need to be replaced.
  5. Next check the magneto ground out wire. It will be a small black wire on the magneto. Unplug it then crank the engine. If the engine starts plug the wire back on the magneto and if it shuts down there is a short along the wire. It should only shut down or short out when the key is shut off. You will need to find the short if this is the problem.
  6. If the magnet is strong and the above test still fails to provide a spark then it is likely that the magneto is bad. You will need the rest of the model number; it will look something like: 31c707- # # # # - # # The part runs somewhere around $35.00 from Sears, but you might find it on-line cheaper.
  7. Replacing the magneto is pretty straight forward from there.
  8. Remove the old one and replace the old one adjusting it as far away from the flywheel as possible.
  9. Turn the flywheel until the magnet is directly across from the magneto.
  10. Put an ordinary business card between the magneto & the flywheel.
  11. Loosen the 2 screws that hold the magneto in place just enough for it to tighten up to hold the business card in place.
  12. Tighten the screws holding the magneto & rotate the flywheel to remove the business card.
  13. Test rotate the flywheel by hand a couple of full turns to ensure there is no contact with the magneto.
  14. Replace the small black wire, spark plug and spark plug wire, then test fire the engine.
  15. Shut the engine down and replace all the remaining parts in the reverse order as removed.
You should be good to go after this. If this was helpful please vote yes. Thank You!!
Posted on May 07, 2011
Carb settings for Stihl FS160
Here's a link to your owner's manual,look at page 26 for carburetor adjustments,I have 3 stihl's,a blower,weedeater and chain saw,had them a long time,never had to adjust the carb.What problems are you having?Clean your air filter or replace it if's real dirty and can't get clean,use 50;1 regular unleaded gas and oil mixture,put a new plug in it,same as you were using,Autozone has them cheaper than the Stihl dealer.Are you using your choke and throttle correctly when starting?On mine,I set the throttle,lock it in,put choke on close,pull a few times,no more than 5,then open choke and pull,it should start,is your spark plug getting oil-gas on it,if so then your flooding it at start up,use fresh gas mixture.I wouldn't adjust the carb. https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS160_180_Manual.pdf
Jun 14, 2017 | Stihl Garden
Why won't my Stihl blower not run?
check for spark first thing if spark sqiurt some starter fluid in the carb start it if it trys to start rebuild your carb dirty or water in gas dump tank put in fresh mixture not same one again
Aug 26, 2014 | Stihl Owners Instruction Manual Leaf...
Why is my Stihl HS61 not firing up?
Try cleaning out the carburettor and make sure u are using new fuel and the correct mixture
Jun 28, 2014 | Stihl Trimmer Blower Hedge Pruner...
Where is the reed valve on stihl bg61av leaf blower
read valves are used by two stroke engines its a V shaped flaps
and is used to feed fuel into the cyclider
it takes the place of a puch rod valve in 2 strokes
and is located at the head end of the intake manifold just after the carborator
Apr 14, 2014 | Stihl Leaf Blower Spare Parts List Manual...
Bg86c spark plug change
the tool you got with the unit for changing other parts
usually is a T shape and has two hex socket at the top of the T and the stem has a torx 10 or similar on it
is also used to change the spark plug
Nov 16, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Sounds like a tricky one. Have you checked the magetism/functioning of the flywheel.? Tracking back the problem by having a new spark plug and coil would next point you to the flywheel. Coil to flywheel gap should be 0.25 feeler guage.
Hope this proves useful. :)
Mar 15, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
HOW TO FIX BROKEN ROPE IN PULL START FOR STIHL BG 61 AV LEAF BLOWER?
The pulley the rope goes onto needs to be fully wound against the spring. I usually wind the pulley and hold it with one hand while feeding in the new rope with the other. The pulley may have a cut out on it where you can hook the rope and then wind the pulley. Once the pulley is fully wound by the spring you can hold the end of the extended rope/grip and let it slowly wind back into the recoil assembly.
Aug 22, 2012 | Garden
Why does my Stihl BG 86 Leaf Blower not accelerate?
remove the muffler and run it if ok open the muffler and clean the screen in side they build up with carbon and stop exhaust flow
Jun 15, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Stihl Leaf Blower no top speed model BG86C
If there is a spark arrester in the muffler outlet check this is not blocked with carbon.
Jun 09, 2012 | Stihl Bg 86c Handheld Blower Cylinder...
Stihl Leaf Blower BG86c no top speed
take off the muffler and run it the screen inside it might be plugged and you can clean it off by opening the muffler
Garden Logo
994 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
