What is the best way to back up my computer harddrive?
    President:
  • 1,561 Answers
I would have advice you use the internet service to back up your data on your system, because it is safest, but the major disadvantage is that, if you mistakenly delete any file on your system, the file will also be deleted on the internet server you back up the data,and it might not be recoverable, again, they have limited data storage you can back up on the server within the months but i will recommend backing up to an external hard drive.
Take care.
Posted on Jul 05, 2010
Computer only works in "safe mode".
the restoration discs will ask you if you want to repair or put a fresh os. like you said be sure tyou have every thing you want because fresh is better!
Nov 02, 2012 | HP Computers & Internet
My computer cannot detect my external hard disk... when i insert my usb cable to connect to my pc my hd does blink..but when i open the explorer there is no sign of my hd is detect..
Hi..
Is it a new harddrive in a external case..if so i have the same prblems and i have to remove the harddrive and insert it into my computer and format it 1st...then place it back into my external case...
If you have used it before,then the best thing to do is try it on an other computer,if that doesn,t recognize then try a different usb cable,if still no go...then the harddrive might be either virused up...then you will have to put it in your computer to virus scan.or your harddrive may be faulty...
Or the last thing...if it is a new external google your motherboard because if it is a old computer your trying to use it on..it may not regonize the harddrive if the capacity is to large..
Hope this helps..if so please take the time to rate it,and if i can be anymore help.
Regards
Apr 02, 2011 | Computers & Internet
Have old Gateway GP6 350 tower. I am looking for a owners manual and what I need to do to uprade. Also, where is the harddrive located on these towers and what does it look like? Thank You for any help you...
If memory serves these little beasties were made in 1998-99.
Believe it used an Intel Pentium II 350MHz processor, that is the Slot 1 type.
http://www.cpu-world.com/CPUs/Pentium-II/TYPE-Desktop%20Pentium%20II.html
It probably has an AOpen AXL6 motherboard, or a Chaintech 6LTM motherboard. Both use the Intel LX440 chipset.
This is all going by memory, as I haven't worked on one in years. I can find no supporting data to give you, as far as a User Guide. I can guide you to the best of my ability if you ask. Just post in a Comment.
Again, if memory serves,
To open the computer case;
1) Looking at the back of the computer. (Computer unplugged from power)
The case has a metal shell going around it. Resembles a U shaped hood, once it is removed.
(Upside down U)
Observe the metal case 'Hood'. Note how the sheet metal of the case hood, comes around the back.
2) There is an inch, (Finger digit), width of sheet metal that comes up each side, and across the top.
In the sheet metal on the sides, I believe there are two screws.
One towards the top, one towards the bottom.
These are removed.
3) There is one screw at the top, I believe. This screw is removed.
Now the hood is pulled away from the rest of the computer. Observing from the back, the hood is slid forward.
Sometimes this is tough to do.
You will have an IDE harddrive inside.
This example shows you what it looks like,
http://computer.howstuffworks.com/hard-disk4.htm
Computer case open. BEFORE you reach inside.
Computer unplugged from power.
TOUCH the metal frame of the computer case to relieve your body of Static.
Your body carries Static electricity. Static will fry out computer hardware components.
Computer unplugged from power, you are safe.
TOUCH the metal frame, your computer is safe.
(Should you get up for any reason, walk away, then return, Touch the metal frame again)
The following is with the utmost respect.
Why are you wishing to know where the harddrive is?
If you are wishing to replace it, it isn't that simple.
You will need a fresh genuine copy of Windows, in order to do so.
Also the Windows version that a Gateway GP6-350
computer is going to support, is Windows 98, or 98SE.
Do you have a Windows 98 disk?
Again, with the utmost respect, trying to upgrade your computer sir, is wasting your money.
There is no Processor upgrade possible. The Processor you have now is the best one for your computer.
The ram memory it uses, (I believe), is SDR Sdram.
(Commonly just referred to as Sdram)
Expensive stuff, in relation to how your money could be used for better computer parts, or computer.
Harddrive upgrade. There is probably a 3GB, 5GB, or 10GB harddrive inside.
Maximum upgrade in size would be around 40GB.
(Maybe)
For the price of a larger harddrive, and an upgrade in ram memory, you could buy a better computer on Ebay. (Don't zap me, I'm only the messenger!)
Jan 15, 2010 | Computers & Internet
Backing up my Maxtor Portable Harddrive?
hi
visit www.fbackup.com and download the software to backup your data
Dec 26, 2009 | Maxtor Hard Drive
I have a dell gx 260. orked great for 1 month when
Hello there:
It looks like to me that your bios is not recognizing the harddrive or is not set up properly like user settings or default settings
I would first go into bios and make sure that the bios is set to the harddrive that is installed.
And also in the boot sequense look on this and see if the harddrive is listed there if it is make sure that it is the top one and not the bottom one than save and reboot the computer when it boots back up it should tell show your harddrive and cd rom if connected properly than if all is good now just continue with your xp[ installation or what ever you were doing ok
I hope that this is very helpful for you
best regards righard
Nov 16, 2009 | Computers & Internet
ECC Error on IBM T40
Hi Dag!
It could be either a faulty contact (unscrew the screw and try to re-seat the harddrive) or a one or more cluster errors on your harddrive. In that case, remove the harddrive, get yourself a 40-pin IDE-to-USB-converter like this one http://www.netshop.no/aspx/produkt/prdinfovnet.aspx?plid=103475.
This one will do the trick with support for S ATA, IDE (40pin 2.5") and IDE (44pin 3.5").
Then just connect it to another computer and save the files and photos you need into that computer.
Best wishes
Ståle
Nov 08, 2008 | IBM ThinkPad T40 2373 Notebook
Transfer data off internal harddrive on to disc
The best way is to take the hard drive out of the computer. Add it to another computer as a secondary drive then use burning software to burn the files you want backed up.
Oct 24, 2008 | Computers & Internet
17" gateway notebook oiwer source
I think returning it is your best option. It could be a bad motherboard. See if they have an expedited option.
Jun 14, 2008 | Gateway 19" Flat Panel LCD Monitor
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
How to Install PS2 Modchip?
what you need: an IDE harddrive (maxtor or seagate works best. ive got a maxtor diamondback or whatever its called), the online adaptor and hdloader. hdloader can only be found on the internet so google it. if youre interested in my setup then you need the original hdloader then you can go to ps2hd.com and find all the other programs if youre interested in doing cogswap (play burned games without a chip) then also search that site for the ps2 exploit disc and cogswap. each harddrive is different and can require differnt jumper settings. look on your harddrive to figue out what is cs or check te company's website where you put your harddrive on the ide cable matters. when i first installed a secondary harddrive in my computer i had to shift my original harddrive down one position to make room for the secondary and allow it to take the secondary position on the ide cable. if you switch them then your computer will tell you "cannot find primary harddrive" and will not boot. one thing that i didnt mention is that you should also ground yourself after grounding the computer. your body can carry static electricity and if it gets discharged inside of your computer you can destroy components like RAM, the motherboard or even harddrives. to ground yourself touch a part of the metal casing of your computer. this will continue to be updated as i find more things that i forgot to say
Dec 01, 2007 | Sony PlayStation® 2 Console
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
