Question about Bissell 8910 ProHeat Clear View Upright Vacuum
I have a Bissel Proheat 2X 12 AMP Model 8920 06242C. It will not squirt water for the floor brushes, or the hose attachment. What could be the problem? Thanx...
  • 1 more comment
  • margegibson Apr 20, 2008
    i have a bissell proheat 2x and i cant get water to squirt out on the floor . i have tried everything. what to do?
  • ram2008 Apr 21, 2008
    reddevil16
    Thanks for the reply, and the part breakdown. I flushed out all my lines and took apart all my spray heads that were clogged with what looked like dried tooth paste! Now the unit works like new! I guess the trick is to flush a tank of clear water after each use.
    Thanks again...ram2008
  • Freshtrooper Nov 11, 2008
    Just got back my pro X2 scrubber from a fix it shop with a little hose in my hand the tech told me he replaced a solnoid and ran the machine it stop squirting he put the old solniod back in and told me the hose he handed me was clogged, when i got back home i forced some air back through the hose put valsoine on all the rubber seals and it was squirting, I notice more vacum when it was apart and i had it running and the tanks fit better so when i put it together the tanks didnt sit as fit and sealed when it was apart 3 seals need to be lubed on the bottom of both tanks and the top snorkel my scrubber been running since for how long who knows call Bissel LOL!!!
    President:
  • 1,673 Answers
Could have a bad pump, also there are solenoids, one of these could be bad.
Posted on Apr 20, 2008
  • 24 Answers
Solenoid controls the lower sprayers if the upolstry tool don't work eithe I say its the pump not sure tho
Posted on Aug 16, 2011
The handle hose on my bissel proheat turbo 2x is clogged, how do I unclog it?
Try suctioning clean water from a sink or bucket with the attachment removed from the hose. If the attachment is clogged, soak in hot tap water for 30 minutes and clean the end with an old toothbrush.
Here's a link to locate a BISSELL Authorized Service Center if you continue to have problems.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 10, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
The water in my bissel pro 2X heat will not spray water
front tank is warped and not seating properly or solenoid bad. solenoid most probable.
May 05, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel proheat no water will dispense
Check all your hoses and make sure that they are not blocked and everything can run freely through your sstem
Apr 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Pro Heat Turbo attachment does not work.
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes
Hope this is helpful.
Good Luck!
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Proheat Plus turbo brush does not work.
No water or soap is coming through, what do I do?
on the top of your tank you have a divertor, did you switch this to the floor setting?
Sep 27, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x upright 12 amps
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dfasdf
Jul 10, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
1,846 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
