Question about Boating
354HC Chrysler 35 hp outboard motor parts and repair manual Need manual to see diagram for repairing impeller cooling system. Also need good source for parts for same engine.
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
  • 86 Answers
SOURCE: how to replace impeller in a 1959 evinrude
Put engine in fwd gear. Then disconnect the shift linkage. Remove the bolts that hold the gearcase on and slide gearcase off of the tower. Remove the 4 bolts or screws in the waterpump housing and lift the housong off. Replace the impeller and reassemble in reverse order. Make sure that you get the water tube lined back up and you can twist the prop to line the splines back up in the powerhead.
Posted on Aug 09, 2009
  • 57 Answers
SOURCE: Downloadable free repair manual
i searched for a site myself but had to eventually buy a Mercury service manual that covers 75 hp up to 150hp-has all engines specs maintenance and repair procedures-cost around $70 but invaluable
Posted on Sep 15, 2009
  • 53 Answers
SOURCE: I have a 60HP Mercury outboard motor and I need a
I'm afraid you will have to purchase one. here is a link to Clymer Manuals. these manuals are great. very detailed. I would give you the part number to the manual you need but, you did not list the year model. so click here to select the one you need
Posted on Nov 05, 2009
  • 6 Answers
SOURCE: CHANGE WATER PUMP IMPELLER FOR EVINRUDE OUTBOARD MOD# E28ESLETD
Crowley Marine Boat Parts & Diagrams have diagrams of all the components, and the catalog is easy to go through to pull them up, OEM and other brands, no cost for the images.
Posted on Jan 21, 2010
I have found an old boat engine with no make and no cover for it made in Canada patented in Canada in 1956, 57, 58, 60 serial number is C384919 and model number 25DE21V or could be 2IV who made it
Eaton's Viking
[PDF]Eaton's V Eaton's Viking Outboards Model Y iking Outboards Model Y ... www.romeosmarine.com/images/Outboards/VikingModel-YearGuide-2007edition.pdf
  1. Cached
  2. Similar
Eaton's Viking Outboards Model Y iking Outboards Model Y iking Outboards Model Year Guide ear Guide ... 25DE21V 25.0 Electric Starting. 40D15V 40.0 ...
[PDF]Eaton's Viking Outboards Model Year Guide ... - Richard L. Paquette
https://richardlpaquette.ca/VikingModel-YearGuide.pdf
  1. Cached
Eaton's Viking Outboards Model Year Guide. 1933-1969. Richard L. Paquette, Third Edition, August 2009. Year: 1933-35. 1936-38. 1939. 1939-41. 1940-41.
Original 1963 Eatons Viking 25 HP Outboard Motor Parts Catalog ...
blackcatantiques.net > Manuals > Boat Motor Original. 1963. Eaton's Viking. 25 HP. Outboard Motor. Parts List. Model 25D21V. &. 25DE21V. NOS. (Sellers Inventory no. B111003). Up for sale, we are ...
Original 1963 Eatons Viking 3 HP Outboard Motor Parts Catalog ...
blackcatantiques.net > Manuals > Boat Motor Original. 1963. Eaton's Viking 3 HP. Outboard Motor. Parts List. Model 3D19V. NOS. (Sellers Inventory no. B111000). Up for sale, we are offering an original ...
Original 1963 Eaton's Viking 5 HP Outboard Motor Parts Catalog Model
  1. Cached
Original. 1963. Eaton's Viking. 5 HP. Outboard Motor Parts List. Model 5D22V. NOS. (Sellers Inventory no. B111001). Up for sale, we are offering an original ... Eaton Viking 25DE21V Google Search
Sep 21, 2017 | Boating
Thermostat on Yamaha F40; where is it specifically? I need to inspect for gunk from burned out impeller.
It's located on the port side of the engine, You'll see just before the spark plugs the exhaust cover. At the top a cap, held with 2 10mm head bolts. There is the thermostat.
But, most of time the impeller parts will stay stuck in the tube between pump and engine block...
Aug 03, 2017 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
I have a 35 hp evinrude that i need a wiring diagram. The model number is35953A and the serial number is E0004955. Thank you!
Hi Cathy.
If you go to a site called
Boatinfo.
You'll find workshop manuals for all makes of outboards.
If you know the year of the motor, you should find it.
Good luck....
May 18, 2016 | Boating
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
Engine diagram parts
Have you replaced the impeller in the lower unit recently? If so was it in pieces? I would start there.
Aug 21, 2014 | Clymer Mercury/Mariner 2.5-60 HP...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Where and how do u get to the water pump it is a 1978 105 chrysler outboard do u have any diagrams? BOAT
all the outboards i have repaired require the removal of the lower gearbox to get to the water pump impeller ,it sits on top of the gearbox driven by the engine drive shaft in a little housing
May 29, 2011 | Car Audio & Video
Mar 19, 2009 | Boating
Boating Logo
104 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
