Question about Coleman Hot Water On Demand
Control knob wont go on properly
I removed the control knob for the water heater but cant get it back on PROPERLY. please include detailed include detailed instructions or tips. thank you!
  • Tim Cook Oct 02, 2011
    tried re assembling knob as directed but knob is very wobbly. No spring tension. Can you give a diagram or detailed instruction.
Re-assemble the knob in the high range of the warm position, about 180 degrees from the "OFF" position. Install the long prong of the spring inwards (away from you as you look at the knob). That prong has to go in between the metal stop bar (again, about 180 degrees from "OFF") and a ridge on the inner knob. You should be able to reinstall everything while the spring is loose in this position. The only time you'll feel spring tension is if you rotate the knob counterclockwise towards "HOT". You won't feel any spring tension as you rotate the know clockwise back towards "OFF".
I figured it out after a fresh start in about 5 minutes.
Posted on Jul 15, 2010
  • Allan Hill Mar 30, 2012
    I normally can figure out most things but these instructions don't make sense, what position does the actual switch be in , Does the actual unit need to be in same position as the Knob for instance
  • Maria OCallaghan Jun 30, 2013
    Did you ever figure it out? We have tried and tried. Managed to get knob on, whilst it appears to be ok, the water temp now is only barelly warm. Take the knob off and it gets really hot turning the inner knob.
    New Friend:
Hope this help someone if still having a problem with contol knob Coleman Hot Water on Demand
Posted on Aug 05, 2016
Aviditi XFJ150FDCH-B Tankless Electric Water Heater, 15-Kilo Watt 4-GPM,no hot water,no any errors,water pressure is ok
Most of these tankless water heater must be mounted by taking the front cover off. Quite often the knobs (flow, heat) do not "line up" properly when reinstalled. Therefore, turning the knobs does not actually turn the switches. Take the front cover off and very carefully reattach it, observing how the knobs fit into the switches.
Apr 25, 2016 | Water Water Heaters
Reliance 606 water heater was in flooded basement had few inches of water up to it now wont light. What to do?
This could be a tough one without being able to examine it. First, have you precisely followed the relighting instructions printed on the heater (turn the knob to "pilot," hold down the button, etc.)? One other thought: the gas pressure to the pilot flame is very low - if some water got into its little supply pipe it could keep gas from getting to the pilot burner device. You would have to disconnect the pilot tube from the gas controller valve and blow it clear, then try again. Dealing with this type of gas problem can create dangerous conditions if not done properly. If water got into the gas controller valve (the one with the knobs and buttons) it will have to be replaced. If unsure, consult a plumber.
Apr 20, 2013 | Reliance & 50gal Electric Water Heater
Heater wont shut off, water gets to hot
You need to provide more detailed information, such as the make, model, and year of the unit. In any case, if it is not functioning properly, regardless of type or model, SHUT IT DOWN, until it can be properly serviced by a professional. DO not risk injury!
Aug 11, 2012 | Pool & Spa
Cant restart gas heater it atempts to light three times then red light comes on and vent stops
Your brand and model number are not known, nor is type of gas control valve. Location of water heater, recent events, age and other factors are also unknown.
Copy following links for possible troubleshoot resources, including troubleshoot by type of gas control valve:
Jul 17, 2012 | Fasco GSW Hot Water Heater Exhaust Draft...
I need to know how to replace the wick and what size wick is required, I guessed a 95mm. The dial that controls the wick wont stay turned holding the wick up so i cant light the heater. would this be due...
It possibly could, if the wick is not installed properly. Also, the height mechanism (the control knob and the gears) may have lost it's tension and will need to replaced.
However, without knowing what brand/manufacturer and model number kerosene heater you have, there's not much more I can tell you.
May 12, 2011 | Heating & Cooling
My 2000 ford f250 doesnt heat. checked gates on heater core and blower assembly. every gates seems to be working properly. checked to see if truck has a heater contro valve. couldnt find it. checked the...
Have you felt the heater hoses to see if they are both equally hot? It would indicate there is water flow. If you do not seem to have flow, disconnect one heater hose at the core and the other at the block and take a water hose and force water into the long hose you removed at the block.
Then if there is no flow it is either a clogged heater core or a control valve, or a block circulation problem. The Valve shown at costs $13.93 and is part#5337-07026431 in a Four Seasons brand. It is Electrically controlled and appears to fit inline with the hose.
There are differences in part numbers for other Year models and the others are for a 5/8 hose. If it is electric it may have a separate fuse. Check an Owners manual or with the autoparts counter. There is also reference to a Super cooling package and differences in Diesel applications. Now if you have noticed a Vacuum heater control, the knob to vary the heat breaks and splits. You turn the knob and the shaft behind it does not move.
I would try to check the Control knob on the dash first, as the Electric valve may just be for off and on and the Control knob regulates the blend doors. Turn the shaft behind the knob with a pair of pliers and see if the heat returns.
Feb 04, 2011 | 2000 Ford F250 Super Duty Crew Cabs
I have a Lifestyles Phoenix Spa with a Wolfpac model 12404GH controller. The onboard circuit breaker trips when the temperature control potentiometer-knob is turned up past water temperature and when the...
IF when the spa control calls for heat and it trips the breaker when the heater comes on then you have a bad heating element and it will need to be changed.
Disconnect the power to the spa. Disconnect the two wires going to the heater and then turn the spa back on.
If the spa stays running without the heater attached then that will be your source of trouble. New heater and you will be all fixed up.
Jan 28, 2011 | Home
Just installed an A O Smith 50gal NG water heater.and can not get it to lit. I have checked the presence of gas at the control valve inlet. I have mechanically held the pilot knob on the gas valve...
Did you have the main gas valve shut off to the house? I know this sounds like a really dumb question, but if the gas line is installed and sealed properly where it goes into the control valve inlet, how did you go about checking for the presence of gas there? If there is in fact, gas going into the valve and no gas coming out at the pilot when you are holding the pilot knob, then you have to have a defective control or a pilot gas tube that is smashed completely shut. It is also possible that dirt and/or debris got into the control unit during the installation process and has things clogged up.
Jan 16, 2011 | Heating & Cooling
1998 volvo v 70car starts great then when warmed up stalls and , it starts good again also cant seem to turn off teh heater "fan"
The car stalling when warmed up is most likely a fuel pump. If the vehicle is not awd then the pump acces is from the trunk. Pull back the carpeting and youll see a circular plate with wires coming out of it with some nuts holding it down. Remove plate and theres your pump. Remember to index your pump, take a grease marker and mark where the tubes coming from the assembly are pointing, if it isnt indexed correctly, your fuel gauge wont read properly. The heater fan issue could be a couple of things, do you have ecc? Like can you move a knob to a set temperature and move another knob to the auto setting? If so its probably the fan power unit. If you have manual climate control then it is probably the switch. Hope this helps.
Nov 26, 2010 | 1998 Volvo V70
Water temp
The water heater thermostat control is usually under a plate/cover toward the bottom of the water heater. Remove the cover (first turn off the power to the water heater) and look for a dial with temperatures marked on it.
You can adjust the thermostat using its knob (if it has one) or a screwdriver. There may be insulation covering the thermostat, so you may have to pull some of that out of the way to see the thermostat.
Apr 29, 2009 | Water Heaters
Coleman Hot Water On Demand Logo
3,165 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
