Question about Cameras
My screen says lens error - Cameras
  • imarandola Jul 05, 2010
    i tried solution 1 did not work still getting lens error
  • 3,083 Answers
There are many things that can create this error, and it's the most common problem with digital cameras. The first thing to suspect is that dust, lint, or sand has worked it's way into the lens assembly, and obstructed a gear that drives the lens, or is impeding the focusing lens. You can try to fix this by spraying a can of compressed air into the front of the lens assembly, in the hope of freeing the gear or lens up. Here is a blog about the problem, and things you can try to get your camera working again. They say 50% of the problems can be fixed, trying their suggestions. Unfortunately, if the lens got bumped too hard, damage may have occurred to the gears, but you have to disassemble the entire camera, to determine that. Here's the web blog:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If your camera still isn't working, make sure you get an estimate before having it repaired. The cost of repair can sometimes be more than a new camera.
Posted on Jul 05, 2010
    President:
  • 1,382 Answers
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
My camera has on the screen, "lens error, restart
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 09, 2010 | Canon PowerShot SD1000 Digital Camera
The screen says lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2009 | Kodak Easyshare M753 Digital Camera
Lens Error on L18
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 23, 2009 | Nikon COOLPIX L18 Digital Camera
Error message E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 12, 2009 | Canon PowerShot S1 IS Digital Camera
Camera does not go on
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
14 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
