Question about Kirby G4 Bagged Upright Vacuum
Loose prong ? on plug (solid no screws like the old fashioned ones)how can I replace
    Master:
  • 501 Answers
Cut it off and put new plug on.or,take it to repair shop
Posted on Jul 05, 2010
The white wire from the plug came loose where does it go? Need to see diagram for wire.
It is the ground wire. If it broke off from the plug, replace the whole plug. There should be a place to attach the white wire to the third round prong on the new plug
Jun 02, 2015 | Filter Queen Majestic Canister Vacuum
My dog chewed the plug completely off my Bissell vacuum, model 61C5-W. Can I fix it myself, and where can I find the replacement cord?
The power cord should be a standard 3 wire cord. Any hardware store. Just buy the length you want. You will have to remove some covers/plastics to get to where the cord connects inside the vacuum. Look for screws holding panels in place. Once inside, you'll see how the cord is attached. Just replace the old with the new. Not critical which of the flat prong wires goes to + and - but be sure the ground wire (usually copper) goes to the ground screw and not a hot connection.
Oct 15, 2013 | Vacuums
Chord plug broke
go to any hardware or home store even dollar shops --where ever u choose to go buy a replacement/repair plug .this is not a hard repair cut off plug end strip cover back 1 inch and strip back the wires separate the repair plug usually 2 or 3 little screws- slide wire up into sleeve and connect green wire to u shaped connection- white to silver color[sometimes the connections are not colored ] -black to goldish connection put plug togeather and ur done
Dec 18, 2011 | Electrolux Vacuums
Bell Howell 7650TMO Sunlight Floor Lamp....I need to replace the plug...does it matter which wire goes where on the plug? Only 2 wires come out of the lamp. Thanks.
Yes, it does matter if correct polarity is to be maintained.
Black wire to brass screw on plug
White wire to silver screw on plug
If the plug has 3 prongs (grounding plug), the green wire goes to the green screw.
More info, let me know.
Charlie
Jul 20, 2011 | Vacuums
Hoover Wind Tunnel Bagless cord prong loose, Vacuum shutting off. Do we have to scrap the vacuum?
Home Depot has cord plugs. Cut off your plug, strip apart the three wires, black, white, green. The new plug will have a green screw for the green ground; a silver screw for the white neutral wire and a brass or gold screw for the black or hot wire.
Connect those wires, ensure that none are touching the others, plug it in and turn it on.
Good Luck,
Gary
Jun 22, 2011 | Hoover U6630-900 WindTunnel Bagless...
Vacumm just stopped running
1} visually check the power cord from the plug all the way to the unit, as their may be a cut in the cord.
2} see if the pins on the plug are unusually loose by wiggling them one by one, there are two flat prongs and one round one.
3} if none of the above are found I suspect the brushes need replaced in the motor or the power cord.
4} Take the vacuum cleaner to a qualified repair service center.
Oct 30, 2010 | Kenmore Quick Clean 30012 Vacuum
E series was working came unpluged while running, pulgged it back in and now it wont come on. Why?
This could be several things. Any time a vacuum cleaner doesn't start, it can either be caused by a bad cord, the plug on the end of the cord, the switch, or the motor on the vacuum.
Judging by what you said in your repair question that you were using the vacuum and it was working fine, and only when the vacuum came unplugged it stopped working. This definitely sounds like your plug probably went bad. When the vacuum is plugged into the wall, and the cord is pulled tight, this can caused too much tension to be placed on the actual plug that's in the wall. We see this quite frequently, especially from people that pull on the vacuum cord from across the room to unplug it. When the plug has too much stress on it, it will cause the prongs to either bend, or loose their connection on the inside of the plug, preventing the vacuum from getting electricity.
An easy way to test the plug without tearing down the entire vacuum is to just wiggle the prongs at the end of the cord. Are the prongs loose at all? If the prongs are loose, this is a sure sign that your plug has gone bad. If the prongs are tight, then it still may be the plug itself, or possibly the entire cord assembly. Again, because you stated the vacuum was working fine until it became unplugged, I tend to think that the plug is probably bad.
Since the plug is the easiest thing to fix, I would recommend trying to replace the plug first. If this doesn't fix it, it can only be the whole cord assembly (which you'll have a new plug anyways), the switch, or the motor.
This is step by step instructions on how to replace the plug on a vacuum. This was a repair that I helped with on a vacuum that had a three wire cord, but putting a two wire plug on will be the same repair minus the ground wire. Honestly, I use a three wire plug with all of the plugs that I repair, regardless of whether or not the vacuum has two or three wires. Typically the three wire plugs are better quality, and hold the wires better. It won't hurt the vacuum or your outlet if you don't have a wire connected to the third prong. You can pick up an electrical plug at any hardware store, or Home Depot.
Here's how to change the plug:
Step 1. Make sure the vacuum is unplugged. Then cut the existing plug off of your Rainbow, at the very end of the cord, right before the plug molding starts:
Step 2. There are typically three screws that hold the plug part into the base of the plug assembly, remove these screws to separate the two parts of the plug:
Step 3. Slide the cord of your rainbow through the bottom part of the plug so the cord sits about 5-6 inches past the opening of the bottom part of the plug:
Step 4. Carefully cut the outer cord jacket off, about one inch from the end of the cord with a sharp knife. Make sure that you don't cut into the actual wires below, and that you're only cutting the outer part of the cord. If you accidentally cut into the wires, just cut the cord again and start over. This is how you can remove the cord jacket:
Step 5. After removing the cord jacket from the cord, cut the paper filling material off, so you have just the two wires (make sure that there is no copper showing through the wires) are the only thing sticking out. Make sure that you have cut enough cord jacket so the wires have enough room to fit into their respective terminals:
Step 6. Use a pair of wire strippers to strip the insulation off of the wires. Strip the wire insulation about about 1/2 inch down both wires.
Step 7. It's best if you twist the copper wires to keep them from fraying.
Step 8. When using a heavier duty plug like the 3 wire plug shown in this repair, the wire actually uses a clamping device to hold down the wire. Cheaper 2 wire plugs just wrap the wire around a screw, in my opinion the heavier duty three wire cords are much safer, and better:
Step 9. Put the White wire into the clamp that has the silver screw, and the black wire into the clamp with the gold screw, and tighten down the screws that hold the wires into place:
Step 10. Tug firmly on both wires to make sure both are securely fastened inside the terminals. If a wire comes loose, loosen the terminal, put the wire back inside, and then tighten down securely.
Step 11. Usually the 3 screws that secure the top of the plug to the bottom part, are aligned with two screws on the top, and one screw on the bottom. Try and line up the screws with the female receptacles on the bottom part of the plug. There may also be a notch on one (and only one) of the terminals, and similar notch on the bottom part of the plug to help you align the two parts correctly:
Step 12. After aligning the screws on the top part of the plug to the bottom part, tighten each screw until snug, then go back and tighten down completely only after each screw is snug. Screw all three screws until they no longer turn:
Step 13. The last step is tighten the lower part of the plug assembly down on top of the cord. This helps relieve stress on the end of the wire that is connected to the plug prongs, just in case the cord is pulled on, this will prevent the cord from pulling out of the top part of the plug assembly. Make sure that you tighten both screws on the lower portion of the plug as tight as absolutely possible:
And you're done! This is how the completed plug should look when you're finished:
Now just plug the vacuum cleaner into a wall outlet, and see if the vacuum turns on. Hopefully it does, and this fixed your problem. If it didn't, then this means that it can only be the cord itself, the switch (in 10 years I've never replaced a Rainbow E or E2 switch), or the motor. I'm fairly confident from what you explained in your repair question that this will fix your problem. If it doesn't however, please just use the Clarification Request form here on Fixya, and just leave a comment explaining that it didn't fix the problem. I will then follow up on how you can test the motor, the cord, and the switch on your Rainbow.
I hope this actually fixed it however. If this was helpful to you in figuring out what happened to your Rainbow, please be kind and rate my repair as helpful by clicking the thumbs up icons on the repair page. This little gesture really and truly does keep me coming back to Fixya and helping people solve their vacuum problems. I really do appreciate it, and I look forward to helping you further diagnosis your Rainbow should you need it.
Thanks again,
Chris J.
GoVacuum
Apr 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How do I fix an electrical plug on my vacuum
cut it off. go to a hardware store and get a three prong plug which you can install onto the wire.
when you prepare the wire you will see a black wire, a white, and a green.
black goes to the brass screw, white goes to the dull screw and green goes to the green ground screw.
Sep 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I wondered if it is possible to repair the prong on the electrical plug of our vacuum
Yes, it is possible. Cut the old plug off and put on an appropriate new plug available at hardware stores. The more expensive plugs are usually easier to work with.
Charlie
Aug 22, 2009 | Vacuums
I have a Hoover Windtunnel 2 upright vvacum cleaner. During regular use my wife turned it on and it staarted cleaning, then all of a sudden it stopped and then started again then stopped for good. I...
It sounds to me like the power cord has a short. To test your power cord you need a multimeter. Test continuity threw the power cord, from the male plug prongs, to the wiring inside the vacuum. You should get continuity from one prong on the male plug to only one wire on the other end of the power cord. If you test one prong but get a readying on 2 wires, then it is crossed. If you dont get any continuity on one or more of the wires, you have a short. A common place for a short in the cord is the male plug, you can find a replacement male plug at a hardware store and cut off the old one. When wiring the male plug, black wire goes to the gold post, white wire goes to silver, and green wire goes to the green post.
If your carbon brushes on the motor are warn, then that could cause the motor to stop, but other parts of the vacuum should still work so I dont think it is that.
Hope this helps.
Jun 27, 2008 | Vacuums
Kirby G4 Bagged Upright Vacuum Logo
109 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
