Want to convert heater from natual gas to lpg are jets available for this conversion.heater model no reh210ec thankyou
    Problem Solver:
  • 11 Answers
Dont know if you can get orvices for that heater but almost all gas appliances can be converted for nat to lp and lp to nat,they made a spud kit which is a blank orvice that you drill out your nat gas orvice to I think a 20 drill side and install the spud in and redrill to size usally a nat-gas orvice is around 8 to 10 sizes larger then a lp.The big thing is the gas valve and if it has a built in regulator or not,some valves can be conferted to open up the regulator pressure by the spring or a block off kit and others are fixed and cant be changed,have to replace valve.most nat-gas are at 3" to7" and lp is at 10".Hope this helps you
Posted on Jul 11, 2010
How can I convert from natural gas to LPG bottled gas?
usually by installing a conversion kit .but if you have natural gas available it's always cheaper than propane
Apr 27, 2015 | Heating & Cooling
Need to convert Paloma gas heater from natural gas to lpg in qld.
You can't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Among other things besides having to reprogram modulation, you'd also need to re-jet it and that's not possible in the field. NG and LPG jets are not the same due to vastly different operating pressures.
Some brands can be field converted but not Paloma/Rheem/Richmond/Rudd Tankless units!
May 18, 2014 | Water Heaters
Rinnai granada MKII
The conversion requires new jets in the unit and readjustment of the air /gas ratio shields. Use a qualified gas specialist for the conversion .
Jun 11, 2013 | Heating & Cooling
Lpg heater conversion to natural gas
You will need make, model, serial number and name of heater to obtain your kit.
Try National energy the sell spares and they are on line , The how well that is a Gas Fitters job.
Mar 03, 2012 | Heating & Cooling
Hello. I have Weber Summit 670 NG and I would like to convert it to LPG. I was told that it can be solved if I replace the NG Orifice with LPG Orifice. Is that true ? Where can I buy the LPG Orifice...
Ronni, unfortunately none of the Weber grills are approved for conversion from one type of gas to another. Each grill is tested and approved for it's specific gas type. Based on that, converting it, places all the liability on you, if something should go wrong. In addition, it takes more than just the burner orifices to convert a grill safely. With any gas appliance, always err on the side of caution and safety.
Thanks for choosing FixYa.
Sep 12, 2011 | Weber Summit S-670 Gas Grill
We have a 2grs45 Vulcan Deep Fryer and would like to convert it from nat gas to propane. What do we need to do?
You need to Order a conversion jet or set of Jets , if more than one from the Manufacturer of the
Deep Fat Fryer, or from your local Retailer.
Just ask for an L.P.G. Conversion Kit for the model of Fryer you have.
The ofirice in the conversion Jets will have been cut to suit the type of Gas you intend using
and so all you should have to do is change the Jet/s.
Eleanor.
Jul 26, 2011 | Vulcan 1GR45M Deep Fryer
I have wall mounted Vulcan gas heater (made around 1970), with Single, flued, Currently connected to LPG gas bottle. Will be connnecting to natual gas shortly. Do i need to get a converter from LPG to...
there is a difuser where the gas comes out and there is a different part for each type of gas. the gas regulator should stay the same you will need a new difuser. dont know if i spelled it right but that is what it is
Mar 26, 2011 | Heating & Cooling
Model reu2402w need jets for lpg the unit at the moment is natural gas still going but need to run it on lpg
Who is the manufacturer of your heater? Unfortunately, the model number alone doesn't help much. Also, you said you need the "jets" to convert it to LPG. Did you mean you needed the burner Orifices?
Please advise. Thanks
Mar 25, 2011 | Heating & Cooling
329H portable heater Can this be converted to a gas bottle fitting will it be ok what is the use age and how many watts of power to run the electronics etc
You need to convert the unit if you are changing from Natural gas to LPG. This involves getting a full conversion kit for your model and changing burner , gas pressures and electronic settings.
Power draw on high remains at 22Watts. Input is almost identical for either natural or LPG gas as you would expect but running costs depends on how much you pay for your LPG. For example in Australia we use 45kg bottles of LPG, they retails at about A$110 delivered. One of these would last about 170 hours running a 329 on high.About 2 litres of LPG per hour
Aug 26, 2010 | Heating & Cooling
I want to convert to propane. Rinnai dont carry kkts for these anymore . . . . are there any way to convert these?
i want to convert one to natural gas from LPG would u like to swap the pilot assy and jets i cant find a conversian kit anywhere...
Apr 23, 2009 | Kitchen Ranges
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
