Question about Microsoft Windows XP Professional for PC
I want to copy the xp pro to my usb, and make it a installer
  • 171 Answers
Hi! you can't copy already installed OS, and then install it to other computer. if you would do that, you would copy system files only.
Posted on Jul 05, 2010
How to install windows XP Pro without using cd drives
Find a computer with a CD-ROM drive.
Find a USB memory-stick that can hold 1 gigabyte.
Copy all the files from the CD-ROM onto the memory-stick.
Carry the memory-stick to the CD-lacking computer, and plug it in to a USB port, and install from there.
May 29, 2010 | Computers & Internet
Ethernet-controller drivers for Acer Aspire 5520-5908 XP
Find a USB memory-stick, and find a computer with Internet access and an available USB port.
Put the memory-stick into the USB slot.
Browse to ACER's web-site, and select your specific model of the Aspire line, and select Windows XP, and select network-controllers, and download the device-drivers, and copy them onto the memory-stick,.
Walk the memory-stick to your Acer, and install the device-driver.
May 07, 2010 | Acer Aspire 5520-5908 Notebook
Don't detect usb, malfunctioned, don't recognised
Did you reinstall from the Dell "System Restore" CDs that came with your computer, or from some "generic" XP CD-ROM?
Access http://support.dell.com
Allow the web-page to "detect" your Dell "asset-key".
You'll be directed to a web-page containing downloadable "drivers" for your computer's USB-ports. Select, download, and Install those drivers.
Sep 15, 2009 | Dell Optiplex GX110 (2909T) Motherboard
I have a thinkpad t20 and a 570e, both with
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
Sep 06, 2009 | IBM ThinkPad T20 2647 Notebook
Format pc without cd
You could use a copy of bartpe on a usb stick. same with windows if you know how to copy your original cd properly. Its actually pretty easy I have both bartpe and xp pro on a single stick and used it to install to an older compaq that had no cd drive. setting up the stick for bart pe can be a little bit of a challenge but there is plenty of help on the web for it.
Same with how to copy your original xp cd.
Aug 11, 2009 | Intel Computers & Internet
I have a aspire 5515 acer with Vista Basic and i want to install Xp Pro. When i try to install Xp pro it starts and the comes back that it is quiting the installion because it will damage something. How do...
There's no single way to install Windows XP. As there is no CD / DVD drive, you have two main choices:
1. Purchase an external CD / DVD drive. Plug it into a USB port on the Aspire, and then access the BIOS, Make sure the CD drive is first, and insert your Windows XP disc. You should now be able to install it normally.
2. Use a bootable Flash drive. This method will be far more difficult, and requires a moderate amount of experience with computers. First you will need to install QEMU on another computer. Create a hard drive the same size or smaller than the one in the Acer. Install Windows XP to it using QEMU. Copy the hard drive image onto a USB Flash drive. Now install some version of Linux on it, such as Puppy Linux or Damn Small Linux. Howtos are available in the Related Links section below. Boot from the Flash drive, and access a command line. Find your hard drive in the /dev folder (probably sda or hda). Now issue the following command
dd if=image.img of=/dev/hda
This will make an exact copy of the hard drive image to the hard drive in the Acer. Waituntil the command is completely done. Now turn off the computer and unplug the flash drive. When you power it back on, it should boot into Windows.
Jun 13, 2009 | Computers & Internet
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
CANT GET WINDOWS XP PRO TO COPY FILES TO A GX280
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
HOW TO ACTIVATE XP PRO USING A COPY OF XP PRO?
If it is a copy, and not genuine, it won't work. It is impossible to make an exact copy of Microsoft product CDs. They detect it. Also, if you do install it, you cannot use it without any limitations.
So be legal and search for an old XP CD. It is out of sale now, until stocks last, but it went out 6 months ago.
You can buy and install the superb new Vista or even buy and download it safely from the Microsoft website.
Jan 13, 2009 | Gateway SOLO 200ARC (7004615) Keyboard
Reinstall Windows XP Pro without losing my data
There is a free program that will allow you to view and change your current product key. It is called Magical Jelly Bean Keyfinder.
The link to this software can be found here. Go to download the latest build on the right side of the page, then run the program. Hope this helps!
Dec 28, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional for PC Logo
18 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
