Question about Samsung 40 in. Flat-Panel LCD HDTV
My samsung tv will not turn on
The tv turns on then off constantly and never turns on, tried to unplug then wait awhile then plug back but that does not work. any suggestions
  • 201 Answers
Sounds like your power supply is bad, common issue with samsung. If you remove cover and look at the capacitors on the power supply,you may find 1 or more caps that are rounded on top instead of being flat the like the others. These need to be replaced.
Posted on Jul 05, 2010
My toshiba tv wont turn on
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
Feb 13, 2012 | RCA F27450 27" TV
My Samsung HP-T4234 is not turning on. It "clicks" constantly as though it was trying to turn on but doesn't. If it should turn on, after a few minutes it turns off the picture and continues to "click". I...
I found it was the HDMI plug-in on the tv that my dvr plugs into went bad. There are two HDMI ports. I plugged the dvr into the other HDMI port and I no longer have any problems.
Apr 16, 2010 | Samsung HP-T4234 TV
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Status light on printer is constantly red & USB status is not ava
Unplug printer and wait a few and then plug back in and turn on. Should reset printer.
Mar 29, 2010 | Samsung CLP 300 Laser Printer
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
WHEN I TURN ON THE POWER THE THE RED LITE COMES ON
We have a TV that does this after we have left it off but plugged in for awhile when we go on a trip. Just unplug the TV, wait a few seconds and plug it back in. If it's like ours, you'll find that resets it.
Nov 19, 2009 | Loewe ARC332 32" TV
Samsung Projection TV
try unplugging the 3 wire plugs for the convergence yokes and try powering up the set. if it comes on you will need convergence ICs if it doesnt you will need a deflection board. let me know what you discover as I can help you with either problem
Jun 19, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HLR5067 flashing green
Thank you!!!! Our power was off due to new transformers being installed in the area and we had no clue how to fix this. I called around and no one seemed to know the answer (not even Samsung, who only wanted to tell me my TWO year old tv was out of warranty),so I tried this and it worked perfectly!!! You saved me a bundle! Thanks!
Jun 13, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv turns its self on or off at times
I tried to unplug mine for awhile then plug it back in that worked for awhile now it won't come at all. Hope this helps abit, although i'm sure your like me and have tried it all,8)
Jan 17, 2007 | RCA 27F650T 27" TV
Samsung 40 in. Flat-Panel LCD HDTV Logo
248 people viewed this question
Henry  Thomas
Henry Thomas
