Question about Ryobi Cultivator
Gas leak. Need filter in gas tank. Any idea where i can get one?
    Master:
  • 502 Answers
Try the ryobi agents
Posted on Jul 05, 2010
Gas is pouring out of new generator. It seems to leak at point where gas goes into filter.Tightened hose. Still pours. Any ideas
Sometimes gas leaks appears to be leaking in one place when it is actually leaking from another place. I assume that the fuel feed is by gravity from the tank to the filter and to the carburettor. Did you check the hose that is attached to the bottom of the tank? it may be ruptured; check both clamps and make sure that there are no shavings to the hose.
good luck
Apr 23, 2016 | Lifan Energy Storm 2200 Portable RV...
Gas is leaking after I put gas in. It looks like the fuels lines are in. Does the filter attach to the gas lines? I don't see an air filter on my 536-77240000 craftman edger.
If you just replaced the lines, alot of times the lines outerm diameter is not correct, causing leaks...other times its the gas cap itself, However, there shouldn't be any hole under a gas tank... at least not where any air filter would be close by..
Sep 26, 2015 | Garden
I have had mower for some time and all of sudden it is going through gas about twice as fast as it did. there are no leaks, i've changed plugs gas & air filters and changed oil/filter. I don't...
Let it idle for a few minutes and check around the gas cap,sometimes they leak.You could also add some Marvel Mystery oil to your gas tank,to clean around the pistons.
May 12, 2011 | John Deere Garden
2000 ford windstar gas smell on the inside only no gas leaks already changed the fuel filter the pcv valve is fine as well .where is the smell coming from? and why is it only on the inside and u can't...
Check and see if you have any gas on the ground after you park your car. Check around the gas tank and gas cap. It's possible that the fuel pump (which is in the gas tank) has hoses that may be leaking. If this is a slight leak, it might only manifest itself via a gas odor into the trunk or passenger compartment. It might be a good idea to put the car on a hoist and follow the fuel lines from the engine to the fuel tank. There should a one line that takes the fuel from the fuel tank to the engine and another that brings back the excess. There should also be another line coming out of the fuel tank that is for venting. Unfortunately, the fuel pump and hose connections are not easily accessible and require either removing the gas tank or cutting a hole in the trunk to access it. You should definitely take care of this soon as leaks don't get better, only worse and it is a potential fire hazard. Good luck!
Mar 11, 2010 | 1998 Ford Windstar
2003 Saturn Vue leaking gas
you need to locate leak quickly and fix.this is a fire hazard look under hood check for gas leaks around fuel pressure regulator.and fuel lines going to fuel injectors.also go to rear of car under where gas tank located and check fuel lines around fuel tank and fuel filter for leaks.
Dec 30, 2009 | 2003 Saturn VUE
Idles runs really rough can smell fuel
1. Could be changing the fuel filter
2. Leaking injector
3. The gas cap (tank gas input) is clogged - Gas tank does need some air
4. Pressure check you gas line - should be in the 20s and hold steady for hours. Could be slow leak
Oct 14, 2009 | 2000 Dodge Grand Caravan
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I empty gas tank and put new gas. could it be something is clogged?
It is a myth that sugar will mess your car up. Sugar does not dissolve in gas, it will just sit in the bottom of the gas tank. You will need to drop the tank and have it cleaned, and replace the in-tank fuel filter, but anything upstream of the fuel filter will be okay.
May 28, 2009 | 1999 Mazda Protege
Leaking Fuel tap (petcock)
This sounds like a vacuum lock pet ****. 3 position? run, prime,and reserve? If you have it on pri, You will fuel running or not. If set on run, then you will only pass fuel when engine is running, and of course res. when tank is used up. Is this leak at the valve? or from the tank or internally flowing? Tis should also be a gravity feed fuel system, please correct me if I'm wrong. good luck. Long fuel lines are not prefered on gravity feed systems.
May 20, 2009 | 1986 Honda VT 500 C Shadow
Ryobi Cultivator Logo
83 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
