Question about HP Photosmart 720 Digital Camera
Hp photosmart 720 lens out. Just clicks like it is trying to move it when you turn it on and off or use the wide/tele switch. Ideas?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 05, 2010
I have a Tamron 70-300mm Tele-Macro lens that doesn't auto focus. It's like it is locked up. I have tried moving the normal/macro switch and that doesn't move either. Any ideas will be welcome.
If that is the only lens that you have for that camera, it could be the camera that is bad. There is a sensor in the camera that measures the focus and they do wear out.
Feb 10, 2014 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
What do the letters w and t at top of camera back mean
These mean Wide and Tele, for the zoom. There should be a rocker switch nearby that operates the zoom lens. You don't say what camera it is, so I can't be more specific.
Feb 04, 2011 | Cameras
What do you do when lens does not come out all the way?
Lens turns when it comes out. Recharge your lithium ion battery fully first. Turn on the camera. Then zoom to see if the lens moves freely. Fully extended only when it is not in tele mode but in wide angle mode. You need service if the lens does not move out, and camera does not power on.
Nov 21, 2010 | Vivitar Vivicam 8225 Digital Camera
Hp945lens
Hi Do you use a lens tube? You need one of these so the lens does not hit the screw on lens when it extends. Quite cheap on ebay etc. Standard 55mm thread.
Hope this helps
jbrevealsall
Jan 21, 2008 | HP Photosmart 945 Digital Camera
H1 - is this normal ?
I haven't ever noticed anything like that with my camera. There is a slight amount of play on my lens though.
Sep 12, 2005 | Sony Cyber-Shot DSC-H1 Digital Camera
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
HP Photosmart 720 Digital Camera Logo
46 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
