Question about Kenmore 24 in. 16019 Built-in Dishwasher
My kenmore dishwasher will not fill up all the way
After i add water it will work but not until i add water
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 05, 2010
The dishwasher is working, but there is a soap like film left behind on the dishes, glasses and silverware. It's a Kenmore dishwasher.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Jan 07, 2011 | Kenmore Dishwashers
Dishwasher not working and rinse aid and eco light flashing.
you must fully fill rinse agent close the door raise the door up and down 3 times then add more liquid tolet out the air ,repeat until fully filled then turn on hot water until it get the hottest THEN START THE MAVHIN. problem should be solved.
Mar 02, 2010 | Dishwashers
We have a Kenmore dishwasher model #665 15831971
4 step check
1. make sure the in coming watter is hot. solet the faucet run until this is so.
2.add or completely fill rinse aid .open and close door 3times then fill somemore that will take the air out of dispenser andallow you to completely fill dispenser.
4. add correct dishwashing soap
once you did all of that your problem should be gone. let me know if i have been of some help.
Feb 26, 2010 | Dishwashers
Dishwasher won't start until running until at
The 2 minutes is most likely the "Fill" time in the cycle therefore since the water supply is active the fill solenoid is spent or not getting a signal.
Dec 12, 2009 | Kenmore Dishwashers
No water getting int the dishwasher
1. kink in supply hose.
2. fill solenoid has failed.
3. screen at water inlet has clogged with debris.
Check 1 and 3 first, easiest.
Oct 02, 2009 | Kenmore 17259 Free-standing Dishwasher
I have a washer that is not getting full of water
I don't believe the fill level is time dependent since we have very little or no variance in fill  and our well system can be anywhere between 30-60#.
By the way, I just noticed you posted under 'dishwasher.' I don't think you wanted that, I suggest you repost with the proper name and model number of your washer. I hope our dishwasher never gets 'filled!'
Jan 18, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Kenmore 665.1736 fills with water but does not spray
Take thre drain hose off from disposal. Pour hot water down the hose until full. Cover end with hand. Press cancel/drain while holding hand over hose - over bucket. That may unstick checkvalve balls and or fix air lock. I have to do that every 6 months or so. Started happening 1 month out of warranty. Go figure. Not a fix - just a work-around...
Dec 28, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore
Make sure you run water in your sink until it is hot before you start the dishwasher. On the newer dishwashers they will fill and drain until the water is hot enough so it takes longer if it starts with cold water. Normal time for a basic wash could take about 45 min.
Oct 07, 2007 | Kenmore 15129 Built-in Dishwasher
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 16019 Built-in Dishwasher Logo
87 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
