Question about Hunter Fan Company 5/1/1 Programmable Thermostat
New thermstat hunter model 44860 says
New thermostat model 44860 says "system turned off". how can i turn it on? i'm trying to turn the a/c on.
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
SOURCE: hunter thermostat 44860
How do I set the air conditioning? I'm lost on this thing and I can't find my manual. Apparently the one I saved is in Spanish. Please help, it's getting warm here in Ohio.....and I have horrible asthma.
Posted on Apr 25, 2008
Hit just to the left of the temperature and you will see a fan symbol pop up. Make sure the fan is set to the correct setting. Refresh means the fan will come on every 15 minutes or so no matter what the tempurature. Auto is usually the normal setting I think. Program mode - depends if you have programs. On mode means the fan is always on.
Posted on Oct 22, 2008
SOURCE: Instruction Manual for Model 44860 Hunter Thermostat
Well, I consulted with Randell (my 12 year old grandson) - he assisted me in finding the solution in converting cooling to heating on the touch pad. Jameson (the 4 year old grandson) looked on, wanted to help Pa-Pa - but, we could only listen to his demands to help.
I still need an instruction manual - can you advise me how to obtain a replacement (or print one from the internet)?
Your response will be greatly appreciated.
Regards,
J. Alan Overton, Sr.
Posted on Nov 19, 2008
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44002.pdf
Posted on Jan 09, 2009
Help! I can't change the temperature and the system won't turn on. All solutions are appreciated. Please include details.
The first thing to determine is if in fact the problem is in the thermostat or if the problem is in the furnace. The furnace typically provides the power source for the HVAC control system and if nothing is wanting to come on, the power to the furnace could be interrupted. Verify that condition first.
Remember most programmable thermostats have a built-in time delay possibly as much as 5 minutes and that is a long time to wait without pressing or touching another thermostat function.
Apr 25, 2015 | Hunter 44860 7-Day Programmable Touch...
Air handler fan runs continuosly. Will not shut off.
There should be fan options "automatic" which will turn on with heat or cool. , continuous, and perhaps "circulate" which is a randomized turn and off. Double-check your Thermostat programming manual. If no manual,
Try this: http://www.manualslib.com/
Mar 04, 2015 | Hunter Universal Touchscreen Thermostat...
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Feb 21, 2015 | Hunter 44860 H Univ. Touchscreen...
Hunter 44860 Thermostat - continually resets clock to 1am
My Hunter 44860 is doing this also. It started on Nov. 1, 2009. It also displays the day of the week as "SUNDAYAY" when it hangs. I believe this is a firmware problem with older stock. Unfortunately I bought it from Lowes this fall and lost the receipt. I am going to try to return it to Hunter Fan Co for an exchange.
Nov 09, 2009 | Heating & Cooling
Hunter 44860 touch screen temperature override
"Hunter" says it all. Throw it out and buy a honeywell, robertshaw, or a white-rodgers. Hunter stats are notorious in the business as being problematic.
Oct 07, 2009 | Heating & Cooling
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
249 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
