Question about Linksys Wireless-G WRT54G Router
Apparently wireless works, but not the wired network
When the WRT54G is plugged in, the lights come on for power, DMZ, and WLAN. No lights come on for the Ethernet and Internet ports. Is it trashed, or is there some way to fix it?
I have a BEFW11S4 which has the opposite problem: Ethernet but no wireless. Perhaps parts could be swapped to make one of them work?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
If your computer is plug in to one of the ethernet ports that should light up. If not you can try another computer or try another ethernet cable. There is possibility that the port is busted.
You can perform a reset on your router and see if the status of the lights change.
If you think your router is still under warranty , you can call linksys support at 1800linksys .. They will be able to diagnosed the problem with your unit, if its faulty or not.
Cheers,
KA
Posted on Jul 05, 2010
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Power, DMZ, WLAN leds OFF. Ethernet, Internet are solid ON.
With the signs that you have describe about your router, this is a clear signs that the router is already bad the hardware itself and better have it replace if still under warranty if not you need to go get a new one sorry about that router is dead already.
May 02, 2010 | Linksys Wireless-G WRT54G Router
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at http://192.168.1.1
Sep 04, 2009 | Linksys Wireless-G WRT54G Router
No power light, all other ports lit.
Well you know when you reset you router you have to reconfigure it so it works that could be it please email at joegoetz16@gmail.com if you need help
Jun 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless G broadband router
Hi
No problem if dmz is off ( only if you put one of your computer outside router firewall it will turn on though tghis is not recomended )
Wlan will be on only if you are connecting wirelessly .
Yes if power is not on spells trouble .
Go to your router support site update latest firmware it will end the problem .
Feb 16, 2009 | Linksys Wireless-G Broadband Router
Router not responding at all
Refer to the instruction booklet about how to re-initialize (re-set) the router. You will then have to re-enter all the setups.
If it does not re-initialize, then it is internaly defective.
Jerry G.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Some light on; some not
disconnect power supply from the router, wait for 30 seconds , and reconnet it back then check you get the power light.. if not try in a different power outlet..check the physical connection, the modem should be connected to internet slot in the router ,so that you would find the internet light lit up.., if still you do ont see the power light or the wlan light, reset your router, if you look at the back of your router, you would find a reset button, press and hold the reset button , with a pen on paper clip for 30 seconds with the power cable connected and disconnectc power and reconnect and then check..if still not the problem is with your router
Nov 16, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
174 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
