Question about Toshiba 57H81 57" Rear Projection Television
Hope this is an easy fix have a Toshiba 50HX51 if memory serves me correct a 2002 model- the problem is the picture was instantly lost and now the power indicator light just flashes can you help. Thanks Ben
snakehead
  • 1074 Answers
SOURCE: Toshiba 50A61..power comes on but no picture or sound
my friend your tv got hit before you did the disconnections storm hit sets are a piece of work to fix, it is left with the circuit board burned.my advise is to buy a new tv.good luck
Posted on Jun 23, 2007
Shuttle83
  • 1139 Answers
SOURCE: Toshiba TN43V71 43 in rear projection
Hello WendyOreo,
It sounds like your switching power supply or you High Voltage power supply has malfunctioned. These sections control all power to the TV and can produce the situation you are describing. If you do not have a background in electronics, I would suggest that you have a TV repairperson come over and check your TV out.
I say this because there are voltages in a TV set that can kill, so caution is needed.
I hope this helps
Thank you,
Shuttle83
Posted on Oct 17, 2007
SOURCE: toshiba 50"rear projection hometheater picture shut off on/off light flashing
take the back off and change the fuse
Posted on Jan 31, 2008
  • 1694 Answers
SOURCE: Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
........................T.
Posted on Feb 01, 2008
SOURCE: Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
The solution is you have to buy a new better tv with a good extended warranty in payments. JZ
Posted on Sep 17, 2008
Is it possible to restore deleted photos from damaged sd card?
Of course yes!
The iPubsoft Android Data Recovery can help you to recover all the data from android phone, including text message, contact, video, photo etc. How to Recover Photos from Android SD Card
Jun 20, 2014 | Toshiba Mobile Sd Card Pack Micro Sd/mini...
Hi All, Yesterday I went for a picnic with my
Hi, It's easy to recover your lost pictures from your memory card. Watch this video and it will help you to recover them.
Hope my advice can help you.
Oct 10, 2013 | SanDisk 2GB microSD Memory Card
Where is the radiator drain plug on a 2002 toyota celica
If memory serves me correctly (I changed my rad) its on the right as you face the vehicle from the front, BUT its at the bottom on the side facing the engine, you need to get right underneath and behind the rad and a good torch, it' not easy to find, but look for the white plastic plug with slightly winged top which you just turn. Get the car up as high as possible - it is a squeeze.
Feb 09, 2013 | 2002 Toyota Celica
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
I need a new voice coil and entire cone and surround replacment for my ma audio 2002 model ma100Xl 10" subwoofer. any Suggestions?
MA does not make a recone kit, and does not repair out-of-warranty equipment.
You have a door stopper i'm afraid.
Thanks for using FixYa!!
Sep 30, 2009 | MA Audio MA 100 XL Car Speaker
Hi everyone. Hopefully an easy question. What
If memory serves me correctly, I believe the dome light fuse controls the trunk light.
I hope I'm right! :)
Sep 14, 2009 | 1987 Chevrolet Nova
Using multiple card slot
There will be a slot, the size of the SD memory card on the front edge or side of the laptop. The slot will be the same size as the slots in an USB memory card reader.
You can download a manual from the Toshiba WEB site.
You can download any/all the Windows XP or Vista device drivers and manual for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers and manual.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 14, 2009 | Toshiba Satellite Pro L300 Notebook
I have somehow lost over 120 pictures from my disk. Is it possible to recover them from whatever the .ctg files are?
Hi!
I will assume that you lost pictures from a memory card. If I'm correct, please follow the steps below.
There are a lot of recovery software that you can use to recover deleted files - specially pictures. You can try to use Zero Assumption Recovery. You can download the software at this site:
http://www.z-a-recovery.com/download.htm
It's a free software (you do not neet to pay to use this), and it's easy to use.
Here are the steps that you need to do:
1.) After you install this software, connect your camera or memory card to your PC . Open the Zero Assumption Recovery software.
2.) Click Next. Select "Recover images from the digital camera.." and click Next again.
3.) Select the Physical Device - select your camera or memory card , click Next. [grab a cup of coffee since retrieving the files may take some time depending on the size of the memory (",) ]
4.) After retrieving the files - select all the files that can be recovered. Click Next.
5.) Select the button on the right side (close to Destination) and select where you want to save the files. Click "Start recovering files".
That's it.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Canon Cameras
Lost pictures
yes, you can recover deleted pictures from digital camera memory card if you follow the correct steps. Here's a guide that helped me before:
Recover deleted pictures from camera memory card
hope this helps.
Aug 13, 2007 | Samsung Digimax S500 Digital Camera
Toshiba 57H81 57" Rear Projection Television Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
