Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
The pump goes on and off repeatedly - Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
  • 760 Answers
The pump should only run if you are using water. If you have a leak it will cycle on and off. If it only cycling fast when you're using water, you may need an expansion tank, sometimes referred to as a bladder tank for newer style. If you have a "bladder" tank , the bladder may be leaking and lost it's air charge. This bladder will have an initial air charge, and when the pump runs it will compress the bladder even further. When the pump shuts off the bladder is compressed. When you begin to use water, mainly low flow like one faucet, the bladder will begin to expand expelling the water from the tank until the pressure drops below that of the pump pressure switch. This makes the pump start and stop fewer times.
Posted on Jul 05, 2010
I have had 3 flotec's in 10 years. 1/2 and 3/4 hp. used as a booster at the house from the well. They all work for a while but eventually just start cycling constantly. Terrible, finicky pumps. I changed bladder tanks. really not the problem. Constantly adjust the pressure switch etc. I still have them all and the pump still works...just dont work properly in service! JUNK
Posted on Aug 17, 2010
Replaced 1/2 hp pump w/ Utilitech #0036758 pressure tank. open valve up water came out. add sprkler. short time shuts off. wtr gets smaller. pump comes bk on. sprkler goes to original hgt. repeats
check the pressure setting in the tank ( 35-40psi is optional)check on-off switch on the pressure tank as the period setting may need adjusting
consider running extra sprinklers or taps as the pump capacity may exceed the deliver requirements
Jun 06, 2018 | HP Plumbing
How to bleed brakes?
If YOU DON'T HAVE AN AUTOMATIC BLEEDER GET SOMEONE TO HELP YOU. MAKE SURE THERE IS FLUID IN THE RESOVOIR. HAVE YOUR HELPER 'PUMP' THE BRAKE PEDAL NUMEROUS TIMES THEN HOLD THE PEDAL DOWN. STARTING FROM THE FURTHEST WHEEL AWAY FROM THE RESEVOIR OPEN THE BLEED SCREW SLIGHTLY TO LET OUT ALL AIR. CLOSE THE BLEED SCREW AND PUMP UP THE LINE AGAIN HOLDING THE PEDAL DOWN OPEN THE BLEED SCREW AGAIN UNTIL PEDAL GOES TO FLOOR. CLOSE THE BLEED SCREW AND REPEAT UNTIL NO AIR COMES OUT. MOVE TO NEXT WHEEL AND REPEAT. MAKE SURE YOU KEEP THE RESEVOIR FULL.
Dec 09, 2015 | Cars & Trucks
My jacuzzi Century Flex-48 pool pump is surgeing after running for 10 min.
possible motor overheating then overheating seals, then they wont pump water they expand and water goes by them
Oct 09, 2017 | Pool & Spa
Sherryhernandez56@yahoo.com stops when engine get hot starts up again and goes another 4 to 6 miles then quits again and repeats itself
this is hard to say without being there, but check the fuel pump relay. it maybe bad and shutting off fuel pump when engine is hot. is fuel pump and fuel filter ok! check fuel filter also. good-day!!
Aug 20, 2011 | 1996 Plymouth Voyager
Live in florida - pool pump goes off for a half hour and then turns back on and then operates normally for a while. it then repeats the same eequence. is this due to overheating
it does sound like overheating. runs for a while, trips the high limit, then cools and restarts. this could be a supply power problem, under sized wiring, or loose or damaged terminals associated with the wiring.
Aug 13, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Intermatic c8866 1 hr cycle timer- wiring- I have 2 hot legs & neutral. Neutral goes to the clock, one hot leg goes to switch common, what does 2nd hot go to- normally open or normally closed? this is...
You have C8866 repeat cycle pump, that repeats the same program each hour.
Your well pump is 240Volt which is why you have two Hot wires.
One Hot wire connects to COM terminal.
Your Neutral wire connects to Clock terminal.
This will power the clock motor.
One hot wire to Load connects to NO normally open terminal.
This terminal turns ON when timer turns ON.
NC terminal is ON at all times, EXCEPT when timer turns ON, and then NC terminal turns OFF
Your second Hot wire runs directly to pump and does not connect to timer.
See diagram below:
Jan 07, 2011 | Intermatic C8865 Timer, 1HR CYCLE TIME, 30...
How to bleed rear brakes on a 1997 honda Prelude
the best rule of thumb is to work from the closest bleeder to the master cylinder, it does take two people!!!!!!! one to pump the brakes and one to open and close the bleeder.
1. fill the resivor
2. pump the pedal all the way down and up, tell the pumper to hold down.
3. crack open the L-F bleeder untill the pedal goes all the way to the floor.
4. repeat untill you get brake fluid with no air bubbles.
5. you MUST do all wheels no matter what!!!!!!!!!!!!!!
6. please do it in this order left froont, right front, left rear, and then right rear.
7. just pump and hold, open bleeder, close bleeder, and repeat for each wheel.
8. make sure to keep filling the fill point on the master cylinder.
Jan 07, 2010 | Honda Prelude Cars & Trucks
I have a water pump short cylicng problem... I changed the water pump a couple of months ago and everything was fine . It is at my cottage and I go there once a week. Last week, I noticed the pressure...
Pump the air chamber up to 40# and check for air leaks. The system needs the air to provide buffer and hold pressure against the water in your tank when the pump is not pumping.
Aug 17, 2009 | Plumbing
Compressor comes on for 2seconds an then off for 8 seconds keep repeating .will not stay on long enough to cool.
When the A/C pump pressure drops, unfortunately because of lose of freon charge, then the pump will be turned off. When the pressure rises, the sensor tells A/C pump to turn back on, so it goes back and forth. When there is no residual pressure left, the system will not even try to turn on.
Jul 09, 2009 | 1988 Ford Bronco II
Baby gaggia wont pump
The pump may only have lost its prime. To prime the pump:
Fill an ear syringe (available at most pharmacies) with water. Insert the business end of the syringe securely in the tube that normally takes up water from the reservoir. As you squeeze the syringe bulb, flip the brew switch on. If you see movement of water in the tube, and hear a change in the sound the pump is making, flip the brew switch off, remove the syringe, and put the tube back in the filled reservoir. Now flip the brew switch on, and see if the pump can draw water on its own. Repeat several times if necessary. If the pump still won't pull water, then it must be replaced.
www.espressosolamente.com
Apr 21, 2008 | Gaggia Baby Espresso Machine
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
926 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
