Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Running brand new Intex salt water system. Ran fine for a few hours then the low flow indicator cam one. I rinsed out the brand new filter and it started back up fine. A few more hours and it's back to low flow. I take the filter out and the flow is fine. Put the filter in and it's low flow. What's up with that?
    Master:
  • 502 Answers
Youll have to keep renewing the filter,or ask the people you bought it off
Posted on Jul 05, 2010
Why is my intex pool water turning green even with the saltwater chlorniator
enough salt? too much salt?
running enough hours per day?
adequate flow to activate salt cell? (cf dirty filter)
Salt cell clogged with calcium deposit?
Jun 21, 2012 | Intex Krystal Clear Saltwater System...
How do i get a higher flow into my pool
The low flow could be caused by a clogged filter. If you have a sand filter and the pressure gauge is reading a high pressure then turn the control valve to Backwash the sand filter until the water is clear in the waste pipe (usually for 2 to 3 mins). then turn the control valve to Rinse for about 1 min then turn the control valve to Filter.
May 09, 2012 | Pool & Spa
This is the second summer for my krystal clear salt water system (above ground intex pool). When the low salt light came on I cleaned the cell as directed but the light came back on. I shut it down and...
Did you check the salt level and was it between 2000 to 3000ppm?? These are the two causes for the low salt alarm.. Dirty scale buildup on the cell and low salt level.. Also, you may need to add a scale buildup preventer. hth makes a bottle called "cell saver" it works okay and prolongs my cell cleaning cycles...
Aug 10, 2011 | Intex Automatic Salt Water System for ...
I lost my manual, What do the codes mean on the salt water chlorenator in particular the code "93"?
88 ia str8 filtering
90 is low flow
91 is low salt
92 is high salt
93 is sleep mode
after running the amount of hours you set for chlorine generation it will shut down and display 93
The system wil then turn back on 24 hours later for the same amount of time
this is ok but every day is different you may need 5 hours and sometimes 12 or any where in between
to reset just unplug and plug back in
To further help you look up some of my posts on green water and low salt I am positive you will find them very helpful
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Aug 08, 2010 | Intex Automatic Salt Water System for ...
Intex salt water witha 18x48 witha 2000/gph pump. my salt water system keeps saying low salt... my salt tested fine after adding more and ive cleaned the cell... it will stay on about 20 min then beeps low...
nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
and no higher than 3800
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
Jul 03, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
Low water flow
Low water flow is generally and indication that the filter is dirty / clogged. Remove the filter cartridge and see if the light goes out. Replace the filter if required.
Apr 22, 2010 | Intex Automatic Salt Water System for ...
Low salt indicator
high concentration? Salt is salt except for the fact in aq pool you want 98% pure and it must not be iodized salt
Also before generating salt with the timer you must have the right amount of salt
the #'s in the manual are just guidelines
get a salt test kit and get your pool to 3000ppm you need to filter only 24 hours or so getting to the 3000ppm wheather you ad salt or need to drain water and ad fresh none the less get it to 3000ppm
Now worry about your chlorine level if it is to high leave alone until it comes down if too low then run the generator for a few hours if it does not show on the scale at all try 4-6 hours
you will get a knack for the amount of time you need for your chlorine situation
if once all of this is set right and you still get high reading on salt unit take it apart as directed and spray it out with the garden hose
it is really simple only 4 screws
Jul 13, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
1,091 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
