Question about Spectroniq Protron PLTV-32 32 in. Plasma Television
Spectroniq DTV menu will not appear
While trying to solve a problem with HDMI, I hit reset all. In doing so, I lost all my DTV channels from my antenna. Now, my DTV shows no signal so I can't scan the channels. What do I do to get back?
  • phillipgrill Jul 05, 2010
    pltv-32 Also, on this particular TV, the DTV input is a completely separate input option, it is in no way connected to the TV input menu. That means the menu display only operates solely with whatever input is selected. So, my DTV input has no signal and no menu display.
  • 484 Answers
When you reset your television, all the stations wiped out automatically, the main solution is for you to search for the stations either manually or automatically by selecting the (TV/AV) channel and search for the wiped channel one after the other.
To get your DTV signal uninstall the DTV and reinstall it back.
If that does not work, it means the whole DTV channels have been wiped off.
Reinstall the Antenna and turn on the television, select the channel your antenna works with from the remote (press the input button or the AV/TV button as it may imply on your television) and see if the channels are not there, you will have to search them one after the other either manually or automatically, save the stations and your Channels will be back, one after the other.
Take care
Posted on Jul 05, 2010
  • 2,335 Answers
When I encounter people trying to solve HDMI-related problem, I invariably, immediately recommend switching over to component cabling. The picture is better, and there are far less issues with both HDCP and resolution switching issues.
That said, on to the problem you requested help about:
First I recommend you unplug all signal and power cables to your set and walk away for a good ten minutes. This ought to reset the brain inside your TV into thinking it is being setup for the first time. Reconnect the antenna, power and signal cabling, turn your set on, and run through the Auto Search function of your TV's on screen display setup menus, taking care that 'AIR' is selected as your TV's Tuner Mode (it will have most likely reverted back to 'CABLE'). This ought to help it find your antenna's DTV channels.
I hope that helps.
________________________________________
Protron PLTV-32 Manual Download
Protron PLTV-32 Service Manual Download
    I have tried your method several times over. Also, on this particular TV, the DTV input is a completely separate input option, it is in no way connected to the TV input menu. That means the menu display only operates solely with whatever input is selected. So, my DTV input has no signal and no menu display.
Lg 42ls575t won't go to "input" screen or "home" screen so cannot select HDMI channel. "Loading" message appears for 30s or so then disappears
solved.
1- turn off you router
2-go to settings
3-ok on the ? (support)
4-inatialisation of premium.
Problem solved
Apr 15, 2013 | Televison & Video
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
I have a Daewoo DSL22V1WCD combined tv/dvd with built in freeview, our area is in the grasp of the digital switchover - everything I look at says I need to retune the tv - but this tv has various "sources"...
Press the DTV menu button (<<)
Press the Down arrow until you reach Settings
Press OK
Press the Down arrow until you reach Installation
Press OK
Press the Down arrow until you reach First Time Installation
Press OK
Aug 04, 2010 | Daewoo Televison & Video
Lost digital channels+hdmi
should have to do with the re reprogramming get your manual and try to reprogram the channels such as cable or tv or cable tv or dtv just make sure you choose the one with cable and dtv
Feb 25, 2010 | LG 37LC2D Television
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
Pioneer PDP-6020 FD, Menu items grayed, no HMG after firmware upd
I have the same issue - Pioneer told me the local repair shop could reset the firmware, I paid the $90 service call and they could not fix anything. For a 18 month old $5000 TV they now want me to replace the digital board for around $500.
Sep 10, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
JVC TV LT-32G80BU can't navigate in menu + all channels messed up
TV seems to reset it's settings for some reason (it happened to me with similar TV - LT-32A80SU). I have found the way to solve this situation - service menu.
Press button "i" and "mute" on remote at the same time - service menu should appear. Now press 8 and there should be menu that allows to change few advanced features. Pressing down and up arrows allows to navigate, pressing right and left arrows changes values. You have to change "dual HDMI" to YES (this will enable second HDMI port) and change "remocon" to other option available (this will change how the remote behaves). Save settings by pressing OK button. Now you can leave service menu by pressing "i" button twice. You should now be able to use your TV like before.
Remember - these are instructions for my TV and they worked for me but playing with service menu can be dangerous so you're doing it at your own risk. Ask JVS support if you're not sure what to do.
Jul 19, 2009 | JVC Televison & Video
Need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Aug 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Spectroniq Protron PLTV-32 32 in. Plasma Television Logo
158 people viewed this question
Top Spectroniq Televison & Video Experts
Chinmay Joshi
Chinmay Joshi
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
