Question about Microsoft Office Outlook 2007 for PC
Outlook 2007 phantom email in outox
Outlook 2007 phantom email in outbox remove
  • nancie1186 Jul 12, 2010
    Try recreating the profile for user if you have not done so already :)
Basti
  • 1447 Answers
SOURCE: Outlook 2007 - Emails sticking in outbox.
If the size of the attachment in the e-mail message is too large, the e-mail message cannot be sent within the time limit. As a result, the message is sent repeatedly. To resolve this issue, use the following options: Option 1: Increase the server time-out limit
  1. On the Tools menu, click E-mail Accounts.
  2. Click View or change existing e-mail accounts, and then click Next.
  3. In the list, click the e-mail account that you want, and then click Change.
  4. Click More Settings, and then click the Advanced tab.
  5. To increase the maximum time duration for e-mail server connections, under Server Timeouts, drag the slider control.
  6. Click OK.
  7. Click Next, and then click Finish.
Option 2: Compress the file you are attaching to the message Zipping a file creates a compressed version of the file that is considerably smaller than the original file. File types that are reduced the most after zipping are text-oriented file types, such as .txt, .doc, and .xls, and graphics files that use noncompressed file types such as .bmp.
Posted on Apr 19, 2008
  • 359 Answers
This generally relates to an issue with emails which include large attachments, and the settings for Outlook; however, it is typically seen with POP accounts rather than accounts associated with an Exchange server. This is a documented issue with Outlook 2003, and although it has not been documented as such with Outlook 2007, I have encountered several users with the same exact issue.
The root of this situation can be found primarily within the Outlook account settings. Basically, the time it takes to send the message with the attachment(s) is longer than the established setting for server timeout. Of course, the frequency of occurrence of this issue will vary depending on several factors: (1) the speed/bandwidth of the internet connection used for transmission; (2) the size of the message and attachment(s); (3) the server timeout setting established within Outlook for the email account being used; and (4) using file compression (zip) to decrease attachment size.
As you mention both Outlook 2007 and 2003, I am not certain if the issue is occurring in both instances, as it appears. I have not yet heard of this issue with Exchange involved, but I would imagine it is possible. Resolving the Exchange piece will take coordination with the administrator of the Exchange server, however, as the server would basically control the external communication piece.
On the individual PC being utilized, however, it is typical to find a server timeout set at 1 minute, and likewise, automatic send/receive set at 5 minutes. Though the automatic send/receive timing does not appear to be directly related to this problem, if the setting for the server timeout were to create a conflict with the automatic send/receive process, this could create further issues. Therefore, I recommend adjusting both settings in order to avoid any such conflict, in addition to correcting the primary problem regarding sending of email messages.
In Outlook 2003, the process for changing the server timeout is: Tools > E-mail Accounts > [select account] > Change > More Settings > Advanced. Then within the Advanced tab, there will be a slider below the title "Server Timeouts", which will lengthen the timeout as it "slides" to the right. The maximum is 10 minutes, and I have had users choose to set the time as high as possible, but generally 5 minutes should be sufficient. This setting is the primary contributor to the problem you are experiencing. In other words, the server is timing out in accordance with your settings, and those settings are causing a timeout before the message/attachment transmission can be completed. This is causing the cyclical treatment you are seeing, wherein the message transmission is not completed prior to the timeout of the server, therefore, it is beginning transmission again at the end of each timeout period (for example, every 1 minute). I would also caution at this point that, whatever the final choices may be, the ISP should be consulted to ensure that there is no standard or maximum, e.g., established for their service.
If you choose to change the Send/Receive ("S/R") Settings, this can be reached in two ways. (1) Tools > S/R > S/R Settings > Define S/R Groups; OR (2) Tools > Options > Mail Setup > S/R. Either path will bring you to a window titled "Send/Receive Groups" where you will see general settings for any groups set up within your Outlook application. For instance, it is typical to see a group titled "All Accounts" (which affects all email accounts included in the group), and often the checkboxes will be marked to include the group in S/R, to schedule automatic S/R every ** minutes (typically 5 minutes), and perhaps to perform an automatic S/R when exiting. It is recommended that any automatic S/R scheduled be longer than the server timeout as set above to avoid any potential conflict.
In implementing these changes, it is important to remember the involvement of the ISP and the general rules with which subscribers must comply; therefore, it would be prudent to verify that the ISP does not have any particular concerns with the values chosen for each of these functions. Additionally, depending on the typical size of the attachments included with your email messages, you may consider zipping the files prior to sending, which compresses the files and can result in file sizes reduced by perhaps 50%. Obviously, reducing file sizes would have a corresponding dramatic reduction on the amount of time required to transmit the message (and for the recipient to download same). Quickly, the easiest way to zip a file would be to right-click on the file in a "My Computer" or "Explorer" window, Send To, and choose Compressed/Zipped Folder. This will save your file with the same name within the same folder, but with a .zip extension, and file size will be dramatically lower.
Although the steps detailed above are directed toward Outlook 2003, the settings to be adjusted in Outlook 2007 are the same, just with a slightly altered path to reach each "end result". This is obviously a fairly complex issue, and I would welcome any further questions or requests for clarification if you need further assistance.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 22, 2008
My problem was an outlook email sometimes usually with an attachment getting stuck in outbox and sending multiple times to users. very embarrassing, some users getting hundreds of emails. Bloody M$ outlook. Tried turning off antivirus - no change. tried setting up another profile, same problem. Once it's stuck can get email deleted using techniques described in posts. i.e work offline, cancel send / recieve etc. but didn't solve problem of getting stuck and sending multiple copies, happens on semi - random almost consistent basis.
Only solution to have fixed problem was as described in one post here, change outgoing server timeouts. go to tools->account settings-> choose account->change account->more settings->advanced tab->change server timeouts from 1 min to 5 mins or longer.
I believe the problem is with ISP and random variances in broadband connectivity. Have noticed my ISP doesn't provide consistent speed and occaisional dead connectivity spots which would explain why one needs to expand timeout settings.
Cheers BC
Posted on Dec 12, 2008
2dcapcom
  • 51 Answers
try turning off the windows firewall or adding an exception for outlook, you can do this from control panel
Posted on Feb 17, 2009
  • 20 Answers
Be sure that only one instance of Outlook is running.
You can verify this by openning the tasks manager and ordering process alphabetically.
Kill all redondant Outlook processes.
I have email stuck in the outbox. Outlook 2007.
Can you move it to a different folder then try to delete it? Or right-click and "Cut" it?
Jan 02, 2010 | Microsoft Office Professional 2007 Full...
Feb 17, 2009 | Microsoft Office Outlook 2003 for PC
Outbox - Outlook Express 6
Hello
I havent seen that problem with Outlook Express just with Microsoft Outlook. but this solution should work with outlook express to.
here how you solv it. you need to remove the outbox file manually. remember that all your outbox files gonna be deleted.
step by step.
1.close outlook express
2. go to C:\Documents and Settings\"your user name"\Local Settings\Application Data\Identities\("alot of numbers here.->"{7850C6E6-099E-4EFD-A3F5-A88CA4FC6169}\Microsoft\Outlook Express\
* if you can find Local settings you need to show hidden files!
a. go to tools>folder options->view-> mark show hidden files and folders-> ok
3.in the map outlook express delete the outbox.dbx or move it somewhere.
4. try now to start the outlook express and the outbox should be empty.
good luck.
Sep 04, 2008 | DBX -215 Home Equalizer
Email stuck in outbox
Here's the fix if when you send an email attachment from another application it gets stuck in the Outlook Outbox...
[HKEY_CURRENT_USER\Software\Microsoft\Office\Common\MailSettings]
"StrictAccountOrder"=dword:00000001
Tooks us a long time to come up with it but great to have! It's fixed in Outlook 2007.
Bill
www.IVDesk.com
Complete hosted IT solution where we run all your applications and provide 24x7 support!
Work from any Internet connection anywhere.
Jun 18, 2008 | Microsoft Office Outlook 2003 for PC
Outlook 2007 emails stuck in the outbox
I've had the same problem more that once. Today it sent the same message 21 times before I finally was notified and deleted it out of the outbox.
May 23, 2008 | Microsoft Office Professional 2007 Full...
Open Questions:
Microsoft Office Outlook 2007 for PC Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
