Question about Polaroid FLM-3201 Television
Screen appears washed out
The screen looks like the contrast and brightness controls are in turbo mode. Consequently the images look washed out and dark. Picture looking at a shadow through an aquarium filled with watery milk. There is color but the picture isn't at all sharp or accurate.
I did replace the: Polaroid Main Unit 782-L32K52-560A
and that wasn't the problem. Any other suggestions?
  • martyrunnell Apr 17, 2008
    Dish network is our provider. I have a dvd player hooked to the TV. I don't think it's an external problem as I've used an external antenna and the same problem exists. This problem does fluctuate slightly. Sometimes it's worse than others but always unacceptable.
  • chilibball
    chilibball May 11, 2010
    What is your TV provider and what connections do you have going to the TV?
Dish Network. I have a DVD player and that's about it. Have tried using just an external antenna as well. Same problem.
Posted on Apr 17, 2008
The best contrast and brightness settings for a toshiba crt floor model tv,model 50A61
Televisions are unlike other consumer electronics products. Their setup and settings have a tremendous effect on how well they perform. The best TV on the market incorrectly setup will almost always look worse than a mediocre TV setup well.
Ideally, you'll get a setup disc to ensure the correct settings, but regardless, it's important to know what each setting actually does.
To get the ultimate performance out of your TV, a full calibration by an ISF Certified technician is your best option. Even if you go that route, it's good to know what the calibrator is adjusting. So here's a quick look at the basic settings every TV has, and what they do.
Please keep in mind, this is only a general guide in what each setting does, and rough idea how to set it. Correctly setting up a television is a completely different article.
Where to start
Nearly all modern TVs have picture modes. These are labeled things like Standard, Cinema, Vivid, and so on. Cinema or Movie is often the most accurate setting, with all the controls set to offer an image close to what a director intended them to look like. Most people aren't used to an accurate image like this, and to them the TV may appear reddish, soft, and possibly dim. Technically, it isn't. Other picture modes like Vivid or Dynamic are programmed to "pop" on a store sales floor with an overenhanced, blue image. Because most people don't change any of their TV's settings, this has resulted in most people thinking a TV should look blue.
The choice is yours, of course, but we here prefer an accurate image and suggest you at least try it for a few days. Once you get used to it, you'll never go back. Check out What's the best picture mode? for more info.
Regardless, all TVs need tweaking to look their best. Here's what the main controls do.
Backlight
Only LCDs have this control (though not all of them). This is a direct control of how bright the image is. Setting this lower will reduce eyestrain, and save a little on electricity. Before you adjust Contrast to make the image brighter, try here first. Check out LED LCD backlights explained for more on this.
Some plasmas have a control that drives the pixels harder, which in some ways acts similar to a backlight control. Samsung's name for this on their plasmas is Cell Light.
Contrast
Sometimes labeled "Picture." This control makes the image brighter...up to a point. Every television has a maximum light output. Once you reach this point, increasing the Contrast control further actually degrades the image. Correctly set, you would see a fluffy cloud in a bright sky. Set too high, you'd see a blotch of white instead. As mentioned above, try setting the overall light output of an LCD with the Backlight control first (if available). Then adjust the Contrast.
Brightness
This controls how dark the dark areas of the image are, again, to a point. Every TV has a minimum light output. Once you reach this point, decreasing the Brightness control starts removing "shadow detail." Correctly set, you'd see all the detail in a black leather jacket at night. Set too low, and it would be a black area on a black area, probably with a head sticking out of it. For more information on how the contrast, brightness and backlight settings interact, check out my article on contrast ratio.
Color
Can be thought of as color saturation. Setting this too high will make everything look cartoony. Setting it too low will make for an expensive black-and-white HDTV.
Tint
Rarely will you need to adjust tint, a vestigial control left over from the CRT "tube" TV days. It gives a green or magenta shade to the image.
Jun 23, 2016 | Toshiba Televison & Video
Tip
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Outdoor photos are all over exposed and white. Video works fine.
set ur screen first .click one image 1st load on ur pc. see the screen and pc screen then set ur screen brightness and contrast of ur camera
Jun 17, 2009 | Mitsuba DV505 Digital Camera
Toshiba Satellite contrast/brightness problem
when u power up the laptop press F8 key then u see some menu like safe mode
enter in enable vga mode.
then go to dispaly property then set screen resolution to 1024*768
Mar 26, 2009 | IBM ThinkPad T42 Notebook
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Screen Image too light to read
Try tapping the power key while the unit is on.  This may activate a control for contrast and brightness.  Otherwise it's in the settings screen.  Try looking at the screen in bright sunlight it may be make the screen visible enought to see the settings.
Oct 14, 2007 | Garmin StreetPilot c550 GPS Receiver
Polaroid FLM-3201 Television Logo
119 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
