Question about Weber Genesis Silver B Grill
Weber Genesis Gas Grill won't heat up very high
Here is the answer to the problem that you wrote: open gas control taps on bbq let pressure out turn off taps reconnect tank turn gas back on
Please say that in never owned a bbq in my life women terms. Are the gas control taps the knobs that control the heat? so that tank was not suppose to already be connected? I'm hungry, help!
  • Weber Master
  • 2,557 Answers
Yes the control knobs are what controls the heat, its a saftey thing on the bbq so turn off tank undo gas from tank open knobs release gas from line , turn off control knobs , reconnect gas line to tank ,turn on slowly , turn control knobs to on and light,
Posted on Jul 05, 2010
Testimonial: "Thanks, it worked!"
  • jonathanlack Oct 07, 2013
    belive it or not this worked for me also. It was only getting to about 250 degrees and following these steps workd and got it back to robust performance.
Weber genesis silver B won't get hotter than 450
Yes diaphram could be split causing vent to pass gas .
Aug 08, 2012 | Weber Genesis Silver B Grill
I have a genesis model 320 natural gas grill what
change all the gas orffices and the reg , try Calgary bbq center for a kit they are on line .
Sep 07, 2011 | Weber Genesis E-320
My weber grill won't heat up beyond 200 degrees - why>
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ,,./,./
May 28, 2011 | Weber Genesis Silver B Grill
Webber grill burners will not go beyond just starting and I used it a week ago and no problem. I put a new gas tank on and the same. Genesis silver unit
This should fixya up.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
Your grill should now heat normally
Nov 10, 2010 | Weber Genesis Silver B Grill
When we light the grill the burners only have a low flame. We can't turn it up to a high enough flame.
Hopefully this will fix you up. Follow exactly.
  10. Your grill should now heat normally
Nov 06, 2010 | Weber Genesis Silver B Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
Sep 06, 2010 | Weber Genesis Silver B Grill
Won't heat up higher than 300
Jul 02, 2010 | Weber Genesis Silver B Grill
Low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Mar 14, 2009 | Weber Genesis Silver B Grill
I have a Weber Gas Go-Anywhere Grill that I want to connect to a propane tap on my travel trailer. The problem is that the tap is low pressure, it's located after the regulator. the Go-Anywhere has a...
You can buy a "T" fitting that connects to the LP tank with a valve allowing you to pull LP gas off for your BBQ before the RV regulator
Most any RV shop can get them from NTP Distirbution
Jul 08, 2008 | Weber Gas Go-Anywhere Grill
Weber Genesis Silver B Grill Logo
2,308 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
