Question about Yamaha 12V Air Pump
O\04 yamaha xl 700 overheating rebuilt carb, new
O yamaha xl 700 overheating rebuilt carb, new fuel
dealership took jets out, exhaust manifold and back flushed and found no problems
take the heat sensor off and it runs good, just runs hot
engine has good compression
really baffled about this one
  • 2 more comments
  • Ian Summerfield
    Ian Summerfield Jul 05, 2010
    is this a jetski?
  • jwiggs2797 Jul 05, 2010
    yes its a 2004 xl 700
    i first thought it was fuel problems so i rebuilt the carb and put new gas
    i took it to dealership they took heat sensor off and it ran fine, but it was running hot
    they took the jets outs and they were clean
    they back flushed it and nothing was stopped up
    they took the exhuasut maifold off and it had very good water flow
    tested engine and it has very good compression
  • Ian Summerfield
    has it been checked with infrared thermometer to see if its within range.does motor have its own water?how do you know its running hot?temp guage,or smells hot,or v hot to touch?water pump?
    no it dosnt have its own water
    there is not temp guage and no meter has been put on it
    the mechanic said it was hot to the touch
    it does not have a water pump
My ski has good compression and runs good for about 30 45 mins but after that it starts to bog down?
Posted on Feb 29, 2012
    Problem Solver:
  • 10 Answers
I am having the same problem. Although I do not yet have it solved, here are some things that have been recommended to me by friends and shops:
1) For me the water was coming out the front water vent holes (left and right side toward front of hull) but water was hot, not cool when I idled for long periods of time or towed tubers/skiers. The exhaust alarm for me went off about 15 mins also when idling but I could run it wide open for 20 without issue.
2) The shop recommended I flush the system to eliminate any foreign objects in the system. After removing all connections and blowing out everything going to the jet plate I flushed the system in my driveway for at least 15 mins without warm water or an exhaust alarm, but the nex ttime I put it into the water it happened again.
3) After talking further with a tech. he stated that it could be the catalytic converter is broken or clogged. Higher RPM it forces enough water past it for cooling and enough enought pressure from the exhaust thru the converter so it doesn't develop the heat issue. This logic seems to hold true.
I haven't yet tried to pull out the converter and check it for defects but that is my next option.
BTW, converters (like anything) aren't cheap! He stated they DO have a bypass kit which removes the converter and puts in a straight pipe and sensor bypass for about $200.
Let me know what you come up with if you find anything too!
Posted on Aug 16, 2010
  • 541 Answers
Change sensor
Posted on Jul 05, 2010
Water is not coming out my exhaust
reverse flush it were the water should come out put the hose in there.
Nov 06, 2013 | Yamaha Waverunner Xl 700 Xl 760 Xl 1200...
I have an 04 yz450f.Ive been having trouble with it idling and have cleaned the carb and jets.I took the tank off emptied it cleaned it out and also replaced the coilpack.Before all of this it would run...
You might want to check the rubber intake & exhaust manifolds for cracks. with the engine running, spray some carb cleaner around both rubber manifolds (Sparingly, short blasts, don\'t soak out of it) and listen for a change in the engines RPMs. if it goes up, or down, that could be your problem bro.......
Mar 11, 2013 | 2004 Yamaha YZ 450 F
I have an 04 yz450f and have a pretty bad backfire. it is mainly when I let of the throttle. I have rebuilt the top end and cleaned my carb. I have owned the bike since it was new and always lived at the...
Give the exhaust system a thorough inspection...leaks especially close to engine where the exhaust is hottest leak out under load...but can draw air in under deceleration....any unburnt fuel will ignite with the fresh air and high temperature.
Mar 16, 2011 | Yamaha YZ 450 F Motorcycles
04 yz 450 backfires and is hard to start when is cold runs better with choke on
Runs better with choke means the mixture is lean,
Has the exhaust been changed.?
Did this problem just begin.?
Check for air leaks on intake manifold.
Clean carb.
Check valve clearances
raise the needle jet one notch
one size up in the main jet.
check one item at a time, and write notes about jetting changes.and improvements
I also run Moreys upper cylnder lube, helps starting hot or cold, and helps stop "cough stopping" with heavy rear brake use
May 20, 2010 | 2004 Yamaha YZ 450 F
I have a 1992 Suzuki GSX-R 750, that wont start
It is in the carbs, A bike will act like that when it needs to be jetted, most jets are not adj, but whoever built the bike, must have messed with the carbs, you can go back to factory settings, which is about 1 1/4 turns out, and try it, you might need to get new jets, you might want to try dyno jet kit, they are adj and work great.. I had to do my bike, the exhaust was burning my eyes, backfired, wouldn't run, factory jets didn't work. But I found a dyno jet kit on ebay, and it works great. But before you take the carbs off, take a piece of heavy paper and cut the air intake in half with the paper to see what it does, then cut by 1/3, then 1/4, just to see if the intake is messing with you. Check it out, hope it helps.
May 09, 2010 | 1985 Yamaha XJ 700 X Maxim
82 yamaha maxim 650 engine is hard to start cold runs on choke and is hard to throttle up off idle will stall but an be featherd up but not easly
weak mixture,dirty fuel,air leaks on induction manifolds,jets blocked,fuel tap filter chocked,float needles sticking,fuel level in carb incorrect,thottles not opening together,air leaks at exhaust pipe joints,
Apr 11, 2010 | 1982 Yamaha XJ 650
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
The exhaust pipe gets red hot after only a few minutes. Anyone else have this problem and how did you fix it This is on a Yamaha 225, a 90''s something bike
Usually this indicates a lean fuel/ait mixture. Remove the main jet and note the number stamped on it. Go to your dealer and give him the VIN from the frame. From that number he can tell you exactly what year, model and engine size you have. Now ask them to check the stock main jet number. If different than what is in the bike then get the stock jet. Check the manifold between the carb and cylinder. If any rubber seals or hoses are hard, then replace them. This will eliminate air leaks on the intake leaning the mix. The image below is for a 1995 model. On the carb main jet and nozzle (in red), make sure they are very clean inside and out.
A “very helpful” rating on this answer? Thanks!
Jul 01, 2009 | 2002 Yamaha TT-R 225
Yamaha 12V Air Pump Logo
541 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
